Question about GE XL1800 1100 Watts Microwave Oven
Reversed polarity a problem?
We just realized the polarity of the outlet that feeds our microwave was reversed. Can anyone hypothesize on whether this could be leading to HV problems? The MW produces a loud humming/buzzing, no heat. The dome on top of the magnetron shows some charring. Have replaced magnetron once already.
  • GE Master
  • 9,098 Answers
The polarity won't matter to the normal functioning, but to ensure safety in case of a short, it should DEFINITELY be corrected.
You probably have a bad magnetron (again) and possibly a bad high voltage rectifier diode too.
GE had a campaign (but not a recall, mind you!) covering several models.
Details are in their bulletin at
The parts kit (that GE used to pay for) is part # WB27X10489 and is shown in the photo below.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:
You can find helpful exploded view diagrams and order parts by entering your full model number here:
Chances are GE won;t cover any of this, but just in case you want to contact them, GE Customer Service is at
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jan 20, 2008
How to get full power from outlet???
If you are getting your microwave to turn on then you are just fine on your outlets. They should be putting out 120v. You just have an under powered Microwave.
Dec 14, 2015 | Microwave Ovens
Sharp carouse ii microwave makes a stress noise and not heating
Your high voltage power diode has most likely failed. That or the magnetron itself has failed where as the oscillator is stuck. My bet is the power diode is what has failed.
First off short out the capacitor AFTER removing the outer chassis with a screwdriver. Hold the screwdriver back on the handle and short across the 2 capacitor terminals. Locate the power diode that will be the wire that is metal. Remove it from the capacitor. Use a meter and read continuity of the diode. Reverse the test leads and read continuity again. In one polarity it is supposed to read like a wire (ZERO Ohms) and in reversed polarity it is supposed to read infinity. (Open) If you get open or short in both directions it has failed.
Diode PN is:
You can change this part and still have a problem with the magnetron... usually though a diode change brings them back to life.
One more thing to do is check the capacitor.... you probe the terminals with the meter on R x 10,000 and watch for a brief jump in resistance and then the meter drifts to infinity. Reversing the leads your looking for the same result each time you reverse the test leads. If you get this reading... the capacitor is probably good.
Thanks for choosing FixYa,
Sep 05, 2011 | Sharp Carousel R530EST Microwave Oven
Magnetron Ready to be Reinstalled but...
The sensor you detail has no polarity. It can go "either way"
For goodness sake be careful, I don't want to scare you but more servicemen, & would-be-servicemen die each year "trying" to service Microwave ovens. They are lethel, or rather the Main Capacitor is, it stores enough Joules to kill someone 10 times over.. Always ensure it is discharged to earth before working on anything.
Be careful.
Jan 21, 2010 | Microwave Ovens
Microwave fuse blowing???
You really need to check that circuit for ground and neutral faults before using it again.
Aug 29, 2009 | Panasonic NN-H275 Microwave Oven
Microwave F-7 Code
F7 is q Power to magnetron
1. Unplug microwave oven or disconnect power.
2. After 40 seconds, check to see whether this solves the problem.
3. Unplug microwave oven or disconnect power.
4. Check cooling fan operation
5. Check resistance of the magnetron thermostat.
6. Check the magnetron.
7. Check P2, P4 and P27 connections.
8. Check wiring to the 1100W inverters and control system. See
“Checking Inverters.”
9. Check operation of all interlock switches.
10. Replace inverter, if defective.
11. Replace all parts and panels before operating.
12. Plug in microwave oven or reconnect power.
13. If problem persists, unplug microwave oven or disconnect power.
14. Replace electronic control.
15. Replace all parts and panels before operating.
16. Plug in microwave oven or reconnect power.
17. If problem persists, unplug microwave oven or disconnect power.
18. Check for reversed plug connection on controls or loose wiring.
19. Replace all parts and panels before operating.
20. Plug in microwave oven or reconnect power.
Aug 08, 2008 | Whirlpool GH6177XP Microwave Oven
Microwave Buzzing When Not in Use
Are you using a 3 pronged outlet and is it grounded? If you have a 2 holed outlet and are using a ground eliminator adapter, try turning the plug around to reverse the polarity. If this helps, then it would be advisable to have an electrician to ground your oven.
May 22, 2008 | Whirlpool MH7140XF Microwave Oven
GE XL1800 1100 Watts Microwave Oven Logo
189 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
