Question about GE GSD3800G - Multiple Color Built-in Dishwasher
GE Profile dishwasher GSD4930X88WW will not start C3 error code
Good day. I have a GE profile dishwasher model in sibject line that is not working. I am a retired Electonic Engineer and sadly have no wiring diagram to help work through the bug.( none on panel of machine ). I have replace the stop check valve that is on the finial output as was suggested for a C3 error code. This has not helped. The unit powers up that goes to a C7 after I reset that the unit defaults to the C3 code. Some time it powers up ( that is digital display only- NO operations active ) then show the C3 fault code first thing.
I am looking for any suggestions along with a wiring diagram / schematic if available. If not can you tell me if all relays / survo's / etc operate on a 110 VAC bases or are there step down voltages that operation the units functions.
I thank you for your help and look forward to NOT washing dishes by hand...!
Take care
Sincerely MR. Clean hands.
  • 23 Answers
The wiring diagram for GE dishwashers is usually found under the dishwasher, take the bottom panel off, then look for a envelope about 3"x5" up against the bottom side of the floor of the dishwasher, right under/behind the front edge. If its not there it makes servicing it tougher. C3 code means the drain sensor is not functioning, C7 code means the temperature sensor is not functioning.
As to the voltages used, I would only know that by looking at the wiring diagram (which I do not have).
Posted on Jan 21, 2008
Receiving F7 error code while cooking turkey model # GLEFM397
FIXED GE Profile Oven F7 error messages - ApplianceBlog
www.applianceblog.com/.../2655-GE-Profile-Oven-F7-error-messages
Jan 13, 2006 - 10 posts - ‎2 authors
My GE Profile built in convection/thermal wall oven constantly flashes F7 errormessages. ... Three of my neighbors and I have the same GE profile double oven (new home development) and we've all have the same problem as you described-F7. ... GE Oven F7 error message solution. LG Electric oven not heating. F7 error code
Jun 9, 2015
FIXED Kenmore Double Oven error code F0 and F7
Aug 31, 2010
More results from www.applianceblog.com
Nov 14, 2015 | Frigidaire Kitchen Ranges
GE Profile Microwave Oven with an F1 error code
F 11 code. it is a touch pad error.
If you just cleaned the control panel it may have water in the panel causing a key to stick.
If after a day or 2 it hasn't dried out - then you will need to replace the touch pad.
Visit www.searspartsdirect.com and enter in your full model number for a parts breakdown and schematics.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 11, 2010 | GE Profile Spacemaker Over-the-Range...
Profile dishwasher not draining at end of cycle.
It would have helped if you provided the model no.
Check this GE website for possible causes. If you do not have the user manual then you can also download it from here, But you will need the model number. (should be etched on the body of the dishwasher)
http://www.geappliances.com/search/fast/infobase/10002419.htm
Dec 22, 2009 | Dishwashers
I NEED TO REPLACE PUMP ASSEMBLY IN MY ge PROFILE DISHWASHER. Can I do this by myself
yes you can take the model # down and get the right pump.. take the water line off and pull it out and put it on the side very easy good luck
Dec 06, 2009 | GE Nautilus 24" Built-in Dishwasher
Is this GE Profile dishwasher recalled?
No recalls on any GE Profile model dishwashers. (there may have been service bulletins, but no recalls) Also, you missed the first two letters of the serial number.
You can go to this web site http://www.geappliances.com/products/recall/ to find info on any GE recall.
May 07, 2009 | GE 25 in. PDW7380JSS Stainless Steel...
Ge profile dishwasher panel won't turn on
out of the blue my GE Profile dishwasher would not turn on. I turned the circuit breaker off for 5 seconds then on and it worked! fixed! saved $200!!!
Dec 31, 2008 | GE Profile PDW8000G Built-in Dishwasher
C5 error on GE Profile dishwasher
C5 - Low Water Fill - This error usually indicates bad water inlet valve. Check for low water pressure to unit.
Dec 21, 2008 | GE Profile PDW8400J Built-in Dishwasher
Error code
you have set it to start after a one hour delay- just press the start delay button until it cycles through past 24h and you will get back to the immediate start mode...
Oct 12, 2008 | GE 24 in. Profile PDW9280JSS Built-in...
GE GSD3800G - Multiple Color Built-in Dishwasher Logo
1,360 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
