Question about Sony Cyber-Shot DSC-W5 Digital Camera
Sony Cybershot DSC-W90
When I switch on the Camera the message turn power off and on again appears and the lens goes in and out 3 times. I can get into the home menu and view the pics on the memory card but cannot take any pictures. Is there a way of reseting the camera so that it switches on normally
  • 1 more comment
  • JennySian Jan 14, 2008
    Its now got worse. The lens is now stuck out. The lens motor is still working and the lens give a little movement when switching on. but the turn power on and off message still appears
  • A Dave Feb 20, 2008
    My problem the W5 has been well described by others here. The lens will not retract and the instruction appears calling for the camera to be turned off and on again. Doing so only gets the same thing again and again. with no end.
    It occurs to me that there my be some unpublished combination of buttons pushed at the same time as turning the camera on which will bring up the operating system for direct trouble-shooting. If so, Sony would be able to tell us about that. I have only begun to search, but have nothing yet. Has anyone any knowledge of such a thing?
    As things are, the camera is worthless. All I have is a large amount of frustration with the product. Anything that may be a chance retrieve its usefullness would be very nice to know about.
  • Anonymous Jun 03, 2008
    Tried to turn the camera off and lens remained extended. The message 'turn camera on and off' came up. Tried this with no success. The lens is now fully extended, with error E61 showing on the display panel. Help
I had the same problem, I gently pried open the black windows of the shutter with my index finger nail, and applied very gentle pressure (pulling outward) while I pressed the power button. THEN... the whole zoom assembly moved EVER SO SLIGHTLY. So, I repeated the exact same process, with a little bit of pressure... and voila... the lens assembly opened fully and I was able to take pictures.
Posted on May 05, 2008
2 Suggested Answers
6ya staff
SOURCE:
BillB-SA
Bill Buchsbaum
  • 2761 Answers
SOURCE: I have a sony cybershot dsc-w80/w85/w90. I have
Your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may require professional repair.
Posted on Oct 19, 2009
IAM TRYING TO TURN ON MY SONY DSC-W90 CAMERA BUT DOST NOT TURN ON AND LENCE FREQUNLY TRY TO OPEN CLOSE AND I RECEIVED MESSAGE ON LCD DISPLY TRUN THE POWER OFF AND ON AGAIN , EVEN I REMOVED AND FIX BATTRY...
The error message is due to the lens issue. the lens might have stuck due to moisture condensation or dust. It may require service to resolve the issue.
If you wish to resolve it yourself, you may use a soft cloth to clear the dust by manually pulling out the lens part..
If it doen't help, it may require opening the Camera
Jan 22, 2011 | Sony Cyber-shot DSC-W90 Digital Camera
Have a Sony Cybershot DSC-W90 camera. After turning camera on, get message stating "turn power off and on again." Same message over and over again.
For these few days i have saw users asked this problem here again and again. Come to see my article in my blog, Maybe it will help: turn the power off and on again maybe something will helpful
Jan 04, 2011 | Sony Cyber-shot DSC-W90 Digital Camera
Camera lens go in and out about 3 times, I cant take pictures.
1. Remove the battery and reinsert it after 30 seconds. 2. Try resetting the Camera. To reset, refer supplied Manual. 3. If stil not resolved, please get the device serviced.
Aug 06, 2009 | Sony Cyber-shot DSC-W90 Digital Camera
Sony Cybershot Lens Stuck inside!!!
I have the exact same problem with my Cyber-shot; the lens is stuck inside. After trying everything to loosen it (like wedging a razor knife between the sections, even dropping it or banging it against a book, etc) non of which I recommend, I finally got it open by PUSHING on the black telescoping section surrounding the lens itself. For some reason, this worked!
Nov 18, 2008 | Cameras
Turn the power on and off again
I fixed this issue with my Sony Cybershot by gently (carefully) hitting the camera 3 times against a carpeted bench with the lens retracted and the camera turned off. It seems the lens gears were stuck. Now the camera works fine again.
Apr 23, 2008 | Sony Cyber-Shot DSC-P32 Digital Camera
DSC-W90 Sony Digital Camera - Lens Error
Sorry man, I think you're out of luck. Most likely nothing you can service, maybe a professional can fix it though. Still under warranty? Good luck.
Nov 09, 2007 | Cameras
Sony Cyber-Shot DSC-W5 Digital Camera Logo
240 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
john cordey
john cordey
Are you a Sony Camera Expert? Answer questions, earn points and help others
