Question about Remington MicroFlex R-TCT Electric Shaver
Need to replace batteries
What batteries to buy? How open case and replace batteries? Tnx, Ken
0 characters
1 Points
The battery will only charge to 20% and runs out quickly. It is 10+ years old. I think it needs a new battery. Is a replacement battery available?
I have been unable to find replacement batteries for your product. In most cases, it's cheaper to buy a new device, opposed to buying replacement parts for something that has been used for awhile and run the risk of another part going bad.
May 31, 2011 | Panasonic ES 8056 Electric Shaver
Hello, How do I change the battery on the Remington TF300 shaver? and I don't know how to open the case to remove the old battery.
Remove the foil assembly and cutters. You will find 2 screws on the back near the top. Remove screws and you can then pry the front half of case off. You will then be able to access the batteries. There are two batteries connected end to end. You will find replacements at See link below. You will need to order 2 batteries
Sep 25, 2010 | Remington Shavers
My elderly father's remington razor MS3 2700 does not seem to be recharging, when it is plugged in. When the "on" switch is pressed, the red light flashes and it makes a tired noise. Could the recharge...
This model was not designed to replacement batteries. The case is glued together so opening it usually results in damaging the case.<br /> Instead of replacing the batteries, I suggest replacing the 'lower unit' part. This is the entire handle portion of the shaver and can be purchased for just a few dollars more that buying the batteries. You will find this lower unit part at See link below<br /> <br /> <a href=""></a>
Aug 29, 2010 | Remington Shavers
I need Guidance on opening the case up to check/replace battery. This is a Remington WPG-250 and doesn't have any screws on the outside.
There are no screws holding this together only 8 locking plastic clipbs (4 on each side). To open I started near the battery charger end and used a flat tip screwdriver to gently pry open the case. Repeat on the other side. Unit has 2 Sanyo NIMH AAA batteries (welded tabs in series). I can't determine if these are regular NIMHs or enloops.
Aug 22, 2010 | Remington WPG-250 Hair Trimmer
I have a Braun 5525 rechargeable razor purchased in 1996. It no longer recharges, and in the charge window displays a jagged line rather than a battery image. Is this a problem with the internal cell, and...
In that case, the circuit board in also bad. This happens when the batteries aren't changed in a timely manner. You can buy a circuit board with batteries at See link below.
To open the shaver you will need to remove the two plastic screw covers on the bottom on either side of the port where the plug fits in. Then remove the screws underneath. The outer case will then slide off the bottom. You may need to reposition the travel lock to get it all the way of. Then unsnap the black plastic back of the inner case and remove it. You can then lift out the old circuit board. Reassemble in reverse order.
Feb 20, 2010 | Braun Shavers
How do I disassemble to replace battery?
Replacing the batteries is not an easy job. You need to have a special Torx screwdriver to undo the screws.
The batteries are soldered onto the Control Board (it's unfortunately not just a case of cracking open the case and putting in batteries in an instant).
It may be worth speaking to your local Philips Service Center (refer to
I usually recommend if you're replacing a shaver to spend a little more $$'s to get one that is mains and rechargeable so that when the batteries die, the shaver is still useable.
Nov 30, 2009 | Norelco ReflexPlus 6863 XL Electric Shaver
How to replace Battery
You will also need a soldering iron, as the batteries are soldered onto the Control Board (it's unfortunately not just a case of cracking open the case and putting in batteries in an instant)
You could obtain batteries from your local Philips Service Center (refer to or check your Yellow pages for Battery Suppliers.
Apr 07, 2009 | Norelco Cool Skin 7775X Electric Shaver
Braun 7526 battery problem
Open the shaver:
1) Use a small flat screw driver pry off the bottom (where the cord plugs in)
2) Remove the silver sides
3) Using a small torq driver remove the 4 scews
4) Open shaver
5) Remove circuit board with batteries
6) Remove and replace circuit board with batteries (or solder in the new batteries)
Oct 25, 2008 | Braun Syncro 7526 Electric Shaver
Remington MicroFlex R-TCT Electric Shaver Logo
Top Remington Shavers Experts
Robert McClure
Are you a Remington Shaver Expert? Answer questions, earn points and help others
