Question about Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sound level & Picture size
I have just purchased a Sharp 42" LCD TV and have found that with the sound cranked up to full volume it is still hard to hear. Also when I tried to adjust the screen height (as the heads are being cut off and the writing on the bottom is also cut off) going through the menu Setup - Position the position on the menu is not accesable.
Thank you
Steve
  • Anonymous Jan 20, 2008
    I can position mine, but it doesn't work with every format.
  • 4 Answers
The screen height is easy, just press the "view mode" button on the controller and change the scaling thru that. As for sound I'm not sure on that, as I can hear mine just fine, plus I use a surround sound system.
Posted on Jan 24, 2008
Our sharp tv model # LC-42D72U power light flashes green but there is no sound or picture. Looking for your expert opinion on what could be wrong so we can get the part ordered. The board with the power...
Green on light is blinking, but no picture - Television - iFixit
https://www.ifixit.com/.../Green+on+light+is+blinking,+but+no+pict..
iFixitOct 3, 2014 - The Sharp LCD TV LC37SB24U set worked until off button on remote ...The green light is blinking any time power cord is plugged into the wall outlet. ... It does sound like either a bad inverter board or a bad power supply. .... On the clad sidethere is no connections or ribbons that indicate hard current draw ...
Oct 20, 2015 | Sharp LC-42D72U 42 Flat Panel 1080p...
How to add more Sound, to my Sharp TV , even in the background, when watching movies, sound is very low , think its dew to cable service? Or would just like to Add external Rear Speakers?
The easiest would be installing a surround sound or other sound system that will amplify the audio. Also, some cable boxes actually have a volume control that is only found on the remote, try turning this up.
Dec 31, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp LC 46D85U TV with NO SOUND (but perfect picture)
Sound like the TV has a defective audio board. Opening up the TV would most likely void the warranty.
It's best to take the TV back and exchange it for a new one. Personally, I wouldn't want to be stuck with a defective TV ( that just came out of the box ) that they are going to repair for you.
Jul 04, 2009 | Sharp AQUOS LC-42D85U 42 in. LCD TV
Distorted sound, great picture on a Sharp Aquos 42" LCD
i belive that it is the brodcasts problem there is nothing wrong with your tv
Jan 09, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
LG LCD TV no sound
LG tv flatron no sound, picture everything else is fine but no sound what can be done to fix it
Jun 16, 2008 | LG 42LB1DRA 42 in. LCD Television
Sharp Aquos LC-65D64U Picture Quality
You need to change your TV's settings and enhancements. Directly from the store and out of the box, the settings are adjusted for easiest sell in the store. That means that:
Your contrast is cranked to 100. Move this down to 50 to 60.
Your brightness may also be cranked up high. Lower it to a level nearer the middle range but not so dark as to lose detail in the shadows.
Your TV is set on "Dynamic" or "Vivid" mode. Pick "natural" or "normal" or standard.
Your sharpness is at least on, if not cranked up. Turn sharpness down or off, and the same with "Edge Enhancement" and "VSM", all to off.
Lastly, I bet you upgraded size and you are now sitting too close to the TV. Roughly, if you are sitting closer than 130 inches (about 11 foot) you might do some rearranging or save some money and get a smaller TV.
Mar 23, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp LC-42D43U troubleshooting with the maximum volume sound
Found this on another site and it worked, had to switch back and forth a few times but it worked........
I have a Sharp LC-46D43U LCD TV. I think this is a entry level for large lcd tv's. With the volume all the way up at 60, my wife and I could barley hear the tv. I was playing around in the menu and some how have the volume at almost twice the volume. What I did was:
Go into the menu
Go to option
Go to output select
and change from fixed to variable and back to fixed. You may have to do this a few times.
Sometimes the volume goes loud after 1 try and sometimes it may take 10 or 20 tries.
But if I change any settings, even the channel sometimes the sound goes back down to where it was.
Has anyone done this, did it work for you. I don't know very much about electronics and I have now ideal why this happens.
I wonder if this is just something with my tv.
Mar 03, 2008 | Sharp LC-42D43U 42 in. LCD HDTV
Volume issue
Very loud it never gonna be. It's a tv with very small speakers, but I have a lot of customers who complain about that and I checked first the signal source. Sometimes the sattelite receiver or cable box give a sound not so good. The best way to check it is to plug something (an antenna or just a 2 inch wire) in the coaxial plug to see if on the tuner is the same sound. I bet is gonna be stronger.
Dec 29, 2007 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
Sharp Aquos LC-42D62U 42 in. LCD HDTV Logo
257 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
