Question about Epson TM-U220 Matrix Printer
My Printer EPSON TM-U220 does not print....HELP!!!!!
Mi Epson tm-u220 does not print...I send the documents to the printer and it does not detect that they are in queue... it does not detect anything...
The machine configured the port LPT1 esdprt (default) for this printer...is that correct? Do I make any change?
  • 2 more comments
  • Anonymous Jul 24, 2008
    My printer is a Brother-MFC 240C and I've tried checking the obvious, ports, on/off switch, went to my computer- printers- it was 'on line' ; and I checked to see if 'brother' was set as the default printer. Everything looked fine. I even copied and pasted from microsoft works and went to blank document and pasted and tried again onto notepad; yet it still won't print. It isn't making a connection. Please help!!! Thank you. Linda
  • Anonymous Mar 19, 2014
    wdeeeeeeeqw
  • Anonymous Mar 20, 2014
    printer
  • Anonymous Mar 25, 2014
    Was buy a new maintenance tank, but my printer no detect it; I was run the ard reset and the clear counter but the problem persist. please help me
  • 63 Answers
Change port to Printer port Lpt1 not the esdprt. then uncheck enable bidirectional support/ Restart computer and then try to do a windows test page
Posted on Feb 12, 2008
I have just installed Epson TM-u220 PB, but cannot get it to print, i have tried Generic txt and Epson drivers. Using Windows 7. I bought a cable that goes from the printer 25 pin i think to usb other end. Any help would be great please.
Posted on Apr 16, 2011
    Problem Solver:
  • 7 Answers
If that doesn't work then just install a generic text using an lpt port
Posted on Aug 13, 2008
AL ENCENDER LA PC LA IMPRESORA IMPRIME UNA SOLA VEZ, LA SEGUNDA EN ADELANTE YA NO IMPRIME NADA, COMO SOLUCIONO ESO?
Posted on Feb 29, 2008
    Problem Solver:
  • 10 Answers
If you are using lpt1 we expect that your printer is using a parallel cable. make sure that your printer is indeed using parallel cable and then check if there's a communication in between the 2 devices. to find out open your command promt then type in, dir>lpt1, your printer should print with or without a printer driver. if it will print, then possible issue is port configuration.. just make sure from the printer properties that you are using lpt. you can use esdprt lpt1 with bi-dir or lpt printer port without bi-dir support. you should be good to go from there. otherwise you may uninstall and reiinstall your printer driver..
Hope you can now use your printer..=)
Posted on Feb 23, 2008
Can i install two(2) EPSON TM-U220 printer on a terminal?
You can have as many printers as you want but each has to have a port defined. When you installed the driver, you must have defined both as one printer and now it's confused the system. Uninstall ALL printers and start again making sure each has a unique port.
Sep 13, 2014 | Epson Tm-u220 Pos Printer Serial Black
PRINTER TM U220 on a Mac
Epson website should have them available to download
Jul 24, 2012 | Epson TM-U220 Matrix Printer
Unable to install Epson TM-U220B[U220 with UB-U02III usb interface] on Windows 7 AND XP!
Hi!
Are you using a third party USB adapter or a USB interface? On the self test page that you printed does it say USB connection or something that will say about USB? or does it say parallel or serial connection? try to check the dip switches setting if its configured properly. visit epsonexperts.com site for more info.
Dec 24, 2011 | Epson TM-U220 Matrix Printer
Epson TM-U220 not working with window 7
download this driver APD-406aE i did it and it is working perfect with my windows 7 on a TM-U 220B
Jul 07, 2010 | Epson TM-U220 Matrix Printer
Printer prints garbage...
Hi
make sure it is configured to the right port and using the epson driver. go to printer and faxes and properties then ports. check of the correct printer driver is check. what type of cable are you using anyways? com for serial, LPT for parallel.
Hope this help
Jan 02, 2009 | Epson TM-U220 Matrix Printer
Can u give a download driver for pos printer
www.barcodesinc.com/epson/tm-u220-drivers.htm
Oct 03, 2008 | Epson TM-U220 Matrix Printer
How to eject cash drawer pos
Open the Cash Drawer
Hex code
<1B><70><30><40><50>
Apr 03, 2008 | Epson TM-U220 Matrix Printer
Epson tm u220
What type of interface card are you using to connect printer to your computer?
Mar 14, 2008 | Epson TM-U220 Matrix Printer
Epson TM-U220 Matrix Printer not printing in WinXPP
hi basiime
possible issue is port configuration. if the generic text driver works, apd driver should work too.
what may be happen is that when you install the apd driver the other printer drivers that you have were still using the same port that your apd driver were using. example, you have generic txt assigned to lpt1 and then the apd were assigned on the same port, this is were you get the trouble.
what you must do is, first, check any printer driver that you have using the lpt, say for example, you generic text is using lpt1, when you install the apd driver set it to lpt2. apd drivers will create a new port normally called esdprt. try to use that port but if that will not work reassigned the port of your apd driver to lpt2 printer port then uncheck bi-directional support. from there you should be able to print..
hope that resolves your issue.. =)
Nov 27, 2007 | Epson TM-U220 Matrix Printer
Epson TM-U220 Matrix Printer Logo
7,402 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
