IBM ThinkPad T30 2366 Notebook Logo
Posted on Nov 27, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I fix a 1802 code - unauthirized network card is plugged in - power off and remove minipci newtork card and will this affect my wireless internet connection? Thanks
Lee Hodgson
Level 3:
  • IBM Master 4,810 Answers
  • Posted on Nov 27, 2009
Lee Hodgson
IBM Master
Level 3:
Answers
4810
Questions
Helped
1782029
Points
15941
Yes it will affect your wireless connection as the computer see's the hardware as unauthorized.
To fix this problem you will need the latest bios update from IBM's support website or go into the BIOS by hitting F1 when you see the IBM logo. Once in the BIOS set it to defaults, save the changes and exit the BIOS, see if that helps.
Good luck and regards.
  • Lee Hodgson
    Lee Hodgson Nov 27, 2009
    Here is another fix if resetting the BIOS doesn't work. Just click on the link i have provided below and follow the instructions on how to do the fix >>>>>>
    http://www.command-tab.com/2006/02/26/th...
    Regards.
Dell NetworkDell Wireless 1350 WLAN MiniPC
The Dell Wireless WLAN Card Utility locates, manages and provides information about wireless networks in your area.
The Dell Wireless WLAN Card Utility allows you to create network profiles, connect to an available network, and diagnose connection problems.
Enable the utility through an icon in the notification area of your desktop, or locate it in the programs list depending on which Dell computer you have.
Turn on the Dell laptop and make sure the wireless switch is in the "On" position.
Right-click the utility icon in the notification area of your desktop.
The icon appears as a set of four green, yellow, red or white bars, depending on the signal strength in your area.
Click "Enable Radio."
Right-click the icon and click "Open Utility" to open the Dell Wireless WLAN Card Utility.
Control Panel
Click "Start" and select "Dell Wireless WLAN Card Utility."
Click the box next to "Enable Radio" and click "Apply."
Click "OK."
http://support.dell.com/support/edocs/network/p70008/en/utility.htm
http://support.dell.com/support/edocs/network/p70008/en/wizard.htm
2helpful
How do i download network adapter for my dell tower, its service tag is C0WST21
please page the URL below in your browser and click download button.
http://download.cnet.com/Network-Dell-Wireless-US-WLAN-Network-Adapter-Card-Wireless-1370-802-11-b-g-WLAN-MiniPCI-Card-Wireless-1350-802-11b-g-WLAN-miniPCI-Card-Wireless-1450-802-11a-b-g-Dual-Band-WLAN-miniPCI-Card-Wireless-1350-WLAN-802-11b-g-PC-Card-TrueMobile-14/3000-2112_4-109107.html
8helpful
2answers
Error 1802 unauthorized network card is plugged in t 40
http://www.thinkwiki.org/wiki/Problem_with_unauthorized_MiniPCI_network_card
2helpful
2answers
My laptop won't connect wireless with my internet after I formatted it. Is this driver related? Dell latitude 120L. If it is, how do I fix it? Thanks!
http://search.dell.com/results.aspx?c=us&l=en&s=gen&cat=sup&k=Dell+latitude+120L&rpp=12&p=1&subcat=dyd%2f1005&rf=all&nk=f&sort=K&ira=False&~srd=False&ipsys=False&advsrch=False&~ck=anav
go here
download wireless drivers
Dell Wireless 1350 WLAN MiniPCI Card, Wireless 1450 WLAN miniPCI Card, Wireless 1350 WLAN PC Card, Wireless (Except US,Japan) WLAN Card, Wi... Download this driver if you reside outside the United States and Japan. This release supports the Dell Wireless 1350, 1370, 1450,1390, 1490, and 1500 series Mini Card, MiniPCI and PC Card devices (not USB). R140745.EXE Hard-Drive 52 MB Verify Operating System and Product Compatibility
System will not boot up.
Thinkpads have readable "FRU" (Field Replaceable Unit) numbers storedon various components, and at boot up time, for those internal devices(fortunately excluding drive, memory, etc) if they do not "respondcorrectly" saying they are a valid IBM part, they will give this 1802error.
It could be that the referenced device has failed, and thus seems to be there but not responding; it could need reseating;
The Lenovo site should be able to help you with a service guide to remove the card and see if that works.
there is also a "hack" to change the bios of machine - I think "prior to T43" to delete the 1802 check:
http://www.command-tab.com/2006/02/26/thinkpad-1802-error-fix/
Be aware any "hack" can disable the machine completely!
If it does turn out to be the mini PCI network card, you can tryremoving it and going with USB (did 600s' HAVE usb? I can't remembermine any more) or try to find a "genuine" IBM replacement on eBay orITxchange.com
4helpful
3answers
IBM R40 2722 1802 Error Message
This is due to the fact that IBM laptops have a list of accepted devices, and the pci card is not recognised in the list. On IBM - Amilo, Mini PCI card slot is usually at the back of computer. Locate and remove Mini PCI wireless card, you will not have integrated wireless after this.
Other solution is to find the option to disable mini PCI in bios settings.
Here is how mini pci wireless card looks like:
Error Message on boot
IBM requires using a "branded" network adapter, meaning one that has IBM's name on it, no matter if it's broadcom,etc. There is a couple of workarounds for this problem which would enable you to use whatever wireless adapter you wish. I would google IBM R40, and error 1802 and you'll find the application you need. Unfortunately, I'm not able to offer it to you here.
Good luck
Top IBM Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
