Question about Hotpoint Aquarius WMA52 Front Load Washer
Hotpoint Ultima WMA61 loud knocking noise in spin cycle
Hi could anyone help me, my washer is making a very loud knocking noise when it goes into the spin cycle it sounds like a boeing 747 taking off It washes fine and seems ok apart from the noise which is rather annoying any help would be great kind regards.
  • 4 more comments
  • forest angel Jan 15, 2008
    Hi Washdoctor,
    Thanks for the reply, I will try it out. If I get an answer to the problem I will post the results.
    Forest Angel
  • washinghell Jan 23, 2008
    We have tried this and still the noise is there, we have changed the belt and there isn't anything for it to catch hold on, could it be something else?
  • gizmo77 Mar 22, 2008
    there is a loud knocking noise coming from the drum when in spin think it could be the bearings does anyone know were and how to locate them
  • waltonwarbys Oct 13, 2008
    hi , my machine makes a loud noise , like plane taking off , and there are also bits of debree or scale pieces in the rubber seal when its finished.
    yes there is lots of play up and down with the drum, is this the bearings or belt, and is it something i could change myself, many thanks jo.
    also mines a sevis machine not hotpoint,
  • Anonymous Oct 25, 2008
    I have the same noise problem, i have taken the drum out but cant remove the bearing to replace it.
  • Anonymous Mar 26, 2014
    it sounds like a boeing 747 airplane taking off when its in spin cycle. Is that a bearing going out?
  • 139 Answers
Hello I think that the drum bearings have gone on the machine..
To open the door and spin the empty drum quickly by hand and you should hear the noise or say a less amplifed one.. Also another way to check is to move the inner durm up and down to see if there is any play in it..
If you need any further advice then dont hesistate to ask....
Posted on Jan 15, 2008
  • 29 Answers
If noise is continuous, is load too heavy? If thats ok, then check specs of the machine,? does the motor have bearings? chances are it wont, but if it does that could be ne reason.
Posted on Apr 13, 2008
Hotpoint aquarius wml760 noisey when spinning with stuff in but ok empty
more than likely the rear bearing has gone bad and when a load is applied the difference in weight distribution causes the knocking.
Jun 15, 2012 | Hotpoint Washing Machines
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems
Washer noise when spinning
Feb 21, 2011 | Hotpoint Aquarius WF220 Front Load Washer
Hotpoint aquaries wf321 is making a loud clicking/knocking noise when its in the spin cycle, to me sounds like a poss bearing gone or maybe something is caught up?
From the front of the washer, spin the drum by hand, if it feels rough or is noisy or rumbling, then the drum bearings have failed.
It is possible that there is something caught between the inner and outer drum.
Nov 30, 2010 | Hotpoint Washing Machines
Loud noise in final spin
Verify that the inner drum isn't broken. Sopin by hand it should trun smoothly and staight.
Aug 30, 2009 | Frigidaire ATF6000ES Front Load Washer
Washing machine won't spin
Do you hear the motor spinning loud whirring noise,when drum is not,if so drum belt has come off or snapped,if no noise possible brushes on motor need replacing
Jan 18, 2009 | Hotpoint Ultima WD72 Front Load...
Knocking noise on spin cycle
My machine did the same thing, I found it to be the heater element in the air box had come loose inside the casing and was hitting the sides of the air box. Removed air box from machine and resecured the element now all ok
Apr 10, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WF840
all i can suggest with the info you have given, is to remove the lid and check for anything lose like the weight block etc also have you checked the inner drum for play, maybe the bearings have gone please not to all it is not safe to continue to run machines that are making noises, they can only get worse making more damage, what can start off as something silly can eventually write off the machine start with that and see how you go, glad to help, if i have helped please rate me
Oct 03, 2007 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima wt960 washing machine noisy on spin
Bearings faulty or another fault this model suffers from is the concrete balance weight retaining bolts shake loose, if it is the bolts tighten up as soo as possible. Regards Advisor
Aug 21, 2007 | Hotpoint Ultima WF860 Front Load Washer
Noisy spin cycle
several points. did you put in transit bolts for move and forget to remove them? is machine sitting square on all four legs? is it sitting on a suspended floor? if joist spacing is wide, then this can result in vibration.
Jun 17, 2007 | Hotpoint Ultima WD72 Front Load...
Noisy spin loose drum
drum bearing need need bearing kit and drum support £60 plus labour at similar price. Appliance Doctor
Feb 02, 2007 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Aquarius WMA52 Front Load Washer Logo
1,434 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
