Question about Hotpoint HSS25GFP Side by Side Refrigerator
Ice maker supply system leaking at back of freezer wall.
I have a Hotpoint side-by-side and lately it has started leaking at the back wall of the freezer where the ice maker water supply enters. I first noticed it because of a noise coming from the freezer. Upon examination, it was caused by ice buildup that had spread so far that it touched the fan blade. I melted the ice and removed and examined the plastic fill tube. It is intact, no holes or cracks. It made sure it was pushed all the way back into the rubber fitting in the back wall of the freezer, but once the icemaker was turned back on it resumed leaking. (I visually confirmed this was the leak location.) Any suggestions?
  • 90 Answers
Replace water valve and remove ice from tube leading to icemaker.
Posted on Jan 17, 2008
Frigidaire glrs264za ice in freezer
The ice-maker supply line enters the back of the freezer near the top. There is a rubber piece that fills the ice tray, attached from the outside. If that is cracked you will have a leak. There is also a water line that runs through the refrigerator to the reservoir that supplies chilled water at the door. All of these lines should be checked for leaks that can drip into the freezer compartment.
Apr 01, 2014 | Frigidaire GLRS264ZA Side by Side...
Icemaker 200D1181G026 WR30X10061 model can15. Is there anyone who can test it and rpair it. It jst stopped working. Water supply ok.
The icemaker system on these machines requires 3 things:
A working ice maker. a working water valve, and 28 degrees or better in the freezer.
Nothing else in the frig controls ice production. Most times the water valve goes first. It is recommended to replace it when replacing the ice maker. Replace the water valve now and see if the ice production starts up. If it does not you will need to get a new ice maker, the old ones are not repairable.
IM6 Notes and fault codes
Refrigerator/Freezer
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 01, 2011 | Hotpoint HSS25GFP Side by Side...
Inside my side by side freezer side (hss25gfta ww)
The ice maker water inlet valve has failed allowing water to pass when it is not supposed to pass. The water valve is item 800 of this link. http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5203104&diagram_id=24933031#d24933031
Changing the water valve most always returns the ice maker operation back to normal.
Kelly
Mar 04, 2010 | Hotpoint HSS25GFP Side by Side...
Kenmore bottom freezer refrigerator warming up
Hi
There is a definetely leak in the cooling gas.
Firstly... You will need to find from where the gas has leaked. It is usually on the compressor pipes..... but not always.
Secondly you are right about the Water Valve... it needs to be changed.
Regards
Berry
Feb 02, 2010 | Kenmore 73502 / 73504 / 73509 Bottom...
Ice maker shooting water along wall of freezer
Hi...
You need to check this
Regards
PCmania
Jul 08, 2009 | U-Line CO2075F-B Echelon Refrigerator Ice...
Water coming from ice maker freezing down back wall of freezer
check for levelness of the ice maker also make sure that the fill tube is inserted all the way into the unit
Apr 25, 2009 | GE GSS20IEP Side by Side Refrigerator
Leaking water
Dear Elizabeth,
please rate this following solution if it mends ur needs,else choose fixya.
please perform the following checks,
Water on floor outside of freezer
Water inside the freezer
  • Check for a clogged drain tube
  • If you have an ice-maker, check freezer and ice-maker for level
please rate this following solution if it mends ur needs,else choose fixya.Thank you.
Dec 17, 2008 | Hotpoint FFS70 Bottom Freezer Refrigerator
Hotpoint HSS25GFP Side by Side Refrigerator Logo
253 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
