Question about Car Audio & Video
2005 dodge status factory radio is lock
I got 05 doge factory 4 cd changer and is lock i d'ont know wath to do to unlock another person give me a stupid anser pleas help
  • carm 302 Jan 14, 2008
    i need a solution a s p
  • 2,039 Answers
You need the code remove the radio call dealer they should ask you the number behind the radio they should be able to give you the code put the code in it should work
Posted on Jan 14, 2008
I have 2005 dodge strutus and my radio is lock
unloack it by doing a hrad reset using the manual
Jan 14, 2008 | Car Audio & Video
How plug pioneer cdx- fm 673 in factory radio 2015 dodge challenger
You plug the cd changer modulator box into the factory radio antenna jack. Connect the factory antenna into the modulator box. The connect the modulators power and ground wires to the appropriate sources. Depending on what kind of connector dodge used you may have to purchase an set of antenna adapters. The modulator uses a standard Motorola plug. Various car manufacturers have created their own special plugs...i honestly do not know if dodge has done this or not.
Oct 09, 2016 | Pioneer Car Audio & Video
Location of cd changer in 1998 dodge dakota slt extended cab
If it still has the factory radio in it, then the CD changer will be part of the radio, and the CD's go into the slot located in the face of the unit. The factor Dodge / Chrysler radios where double DIN, meaning that they are about 4"(100mm) tall, vs a single DIN that is closer to 2" (50mm). Most aftermarket radios are single DIN and use a filler plate to cover the extra room. If it is an aftermarket radio, and has a CD changer, then it is more than likely located under a seat, in the glove box, or in the center console of a vehicle.
Apr 22, 2014 | Car Audio & Video
2005 Sportage - Doors lock/unlock while stopped at light, radio cuts out,
replace IC of car door lock... this is a little black box inside the steering wheel cover
Jun 12, 2013 | Kia Cars & Trucks
2005 malibu, factory radio removal and keyless entry disabled'?
You can put in a new cd player with the controls for the onboard info center with this dashkit.
http://www.sonicelectronix.com/item_12569_Metra+99-3303.html
Jul 19, 2010 | 2005 Chevrolet Malibu
05 G6 radio reads cd changer errror
Im having the same issue ..and actually seen this issue on alot of message board or websites..starting to think its a manufacture issue
Apr 17, 2010 | Buck Pontiac G6 2005-2007 05 Stereo/radio...
I changed the battery in my 05 dodge caravan and now the cd changer doesn't work.it ''gears'' up when you turn on the power but the mode button only recognizes am and fm and not cd any fix?
sounds like a bad radio that shouldnt happen bttery has no effect on changer opperation if the radio powers up the changer should work as long as its a factory radio w an internal six disc changer.
Feb 19, 2010 | 2005 Dodge Grand Caravan
05 dodge ram with infinity system amp turn?
There is two ways you can do this you can find the turn on wire for the amp and hook it up to the amp turn on wire from the radio (this is the bootleg way and sound might cutout when you turn the radio up)
The best way to go is to go to best buy or your local sound shop and get a bypass harness for a dodge infinity system(go this way so you won't have rny problems)
Aug 08, 2009 | Sony XR-C9100 CD Changer
2005 dodge caravan rbq am-fm radio w/6 disc cd changer
Contacted local dodge dealer about my in dash 6-disc changer problem. Chrysler seems to have an "exchange" program. They will remove your existing radio, install a "factory reconditioned" unit and send yours in to be repaired and sold to someone else. The dealer told me that my CD's would EVENTUALLY be returned to me from Chrysler. The cost I was given was $265 plus sales tax for the exchange unit, and the labor to remove and reinstall. He said about a half hour labor. Compare this to the $604 for a factory new unit. Hope this helps everyone with this problem. I was told by the Service advisor that it is common for this problem.
Sep 28, 2008 | Car Audio & Video
Car Audio & Video Logo
147 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
