We have an old machine that ran out of toner a couple months ago. We've been trying to get toner for it and recently were successful. We replaced the empty but now the images are coming out very faint. Any ideas? Thank you very much for your time.
Try the toner prog. press the reset putton then type 107 then hold on (C) putton it will open the copier prog choose display settings then see the toner vt & vf if the vt is higher than the vf press set many times and u will find the vf = vr then tern the copier off &on then try it
Www.precisionroller.com or www.tonerpirate.com
most of the time images come out faint is due to worn developer material if your copier uses developer, dirty corona wires,or photo drum has been xposed to sunlight.
I would have deveolper material changed then corona wires if developer doesnt help.
try photodrum last because they are usually expensive.
There isn't any solution posted. Or if there is, I'm not seeing it.
i just purshased a gestetner 2640e in an auction, Where can a find a manual for this and how much is it worth.
Thanks nancy
