The speaker will beep when a the Keyboard buffer is full. Many times this is due to a key that is stuck in the down position. With the computer off, run your fingers over all of the keys, and note that the keys "bounce" back up as you release the pressure from your fingers. Any key that is NOT returning to the "up" position is stuck in the down position. Examine that key for any foreign matter that could be wedged between the keys. You may be able to CAREFULLY pry the foreign matter from between the keys using a paper clip that has been opened to form a stiff wire. Also try pushing down on the surrounding keys at you attempt to remove the object. Once the object is removed, turn the keyboard upside down and shake. I think you'll be surprised at how much dirt and other "stuff" comes out from behind those keys. A small air compressor or can of compressed air will also accomplish this. Just be sure not to turn the can of air upside down or you will also expel the propellant from the can which can damage the keyboard and/or computer.
On another note, it is also a posibility that the membrane which holds the keys in the up position is broken which would require you to replace the keyboard itself.
