Not sure if you have done this so give this a try.
* If possible, plug your Starlogic monitor into another working computer. If the Starlogic monitor works then it is the port on the original computer that has gone bad. The solution would be purchasing a new video card such as PCI or AGP video card. (Assuming all other aspects of your PC are working fine) *However, if the monitor does not work then you know your monitor is dead. You will need to buy a new or used monitor. **You may want to barrow someone's monitor and test your original computer just to make sure the port on that original computer is fine.
The computer needs its screen resolution reducing or changing in aspect ratio to suit the StarLogic monitor. Use a previously-working monitor and reduce the resolution on the computer to 1024 x 768 pixels or less (right-click an unused part of the desktop, click Properties and select Settings; slide the resolution slider to the left to adjust). The StarLogic monitor will now work; plug it in - do the resolution adjustment again as above, but increasing the resolution until you are happy. Going this way around, your computer will failsafe back to the previous (lower) resolution if the monitor says Out Of Range again, so you cannot lose the display along the way..
You're monitor is dying and you need a replacement (Starlogic brand is notorious for dying early and giving poor performance)
You're graphics card is going out. If you have an extra monitor laying around, take out the Starlogic one and plug in the other to see if the same results occur, if not, it's the Starlogic monitor, if the problem still persists, you need a new graphics card or need to update your current drivers.
I can't find a website for StarLogic anywhere, so either they have gone out of business (not likely as there should be some reference to them somewhere) or they are imported from a foreign manufacturer and rebranded with the StarLogic name.
If you are getting a "No Signal" message, someone may have inadvertantly pressed the wrong button on the monitor. Use up arrow of button #5 below to cycle through RGB (normal VGA connection) and DVI sources. Down arrow will result in "No Signal" message.
There are five buttons at the bottom of the screen on this monitor. From the left:
1 - sound volume
2 - degausser
3 - power on/off
4 - monitor set-up
5 - RGB/DVI source
