Question about HP Pavillion ZV6000 Athlon 64 3500+ 15.4in WideScreen w/ 512MB/80GB/DVDRW/Flash Slot (PCLHCA6435512WWD) PC Notebook
Hp pavilion zv6000
Hello, I need a advise, not long ago I bring my laptop to get more memory and he was all clean up inside, lots of dust from 2 years of daily use. Was all fine until now,my fan started to make a very soft but constant noise, the chip fan, any sugestions?
    Genius:
  • 1,067 Answers
All fans replace ad blow out more and add new greese on cpu stop heat ok
Posted on Jan 14, 2008
  • 89 Answers
Replace fan and heatsink assembly.
How can i check if memory is faulty on an hp pavilion laptop
may be remove memory and give a good blow lots of dust gets in
Nov 27, 2012 | HP Pavilion dv6000z Notebook
HP Pavilion zv6000 power issue. My laptop fan kicks into high gear whenever the adapter is plugged in. Frequently it suddenly shuts off completely to keep itself from overheating. If I use battery-only...
the PC needs to be cleaned,every year or it will overheat.
lint packs up.
what is the ADAPTeR, we cant guess them. ever.
aH the AC power pack is the ADAPTER?
i bet the battery goes dead with no adapter right
so the acid test is this
no battery run on the adapter
if that fails, the adapte is wrong or dead. or weak
1: wrong size 65w or 100w. less never.
2: wrong voltage ,19vdc is correct for HP. not 12,
3: the jack on the mobo for 19v is cracked ,common on some
i never buy PC with this part , I buy Elitebooks that cure that horror.
what happens is you flex cable.
and the jack flexes and then the solder joint crack
all do, its one bad horror. (mine uses a anti crack flex cable inside)
http://www.ebay.com/itm/DC-POWER-JACK-IN-HP-ZD8000-ZV6000-COMPAQ-R4000-X6000-MOTHERBOARD-SOCKET-CHARGE-/271259462380?hash=item3f2852eaec:g:C8MAAOxy9LxSDsly
Aug 04, 2017 | HP Pavilion zv6000 Notebook
I have a hp pavilion zv6000 latop. I was told the parts inside of the pc are disconnected. what parts should I look for that might be disconnected????
How did these "parts" get disconected? Was someone in the computer?
It may be necessary to bring it to a shop and have them look at it.
Please be clear on what the machine is doing when its on. (error messages, etc.)
Oct 19, 2010 | HP Pavilion ZV6000 Laptop
Sound drivers for hp pavilion zv6000
You need to download the drivers from the Compaq/HP WEB support/download page. Make sure you select your model laptop and the XP or Vista Windows version of the drivers you require and install them. Click on this link to download the drivers: -
www.hp.com/#Support
Jun 09, 2010 | HP Pavilion ZV6000 Laptop
Old hp pavilion (8674 F) desk top. server will
There is no fuse inside.If this is idle for a few years , might be there is some dust in switch so you will have to clean it once and also try with exchanging the power cords.
Thanks
Jan 05, 2010 | Compaq Pavilion ZT3280US Notebook
Hp pavilion zv6000 wont recognize dvd+r
Hi Terry,
The answer is pretty simple, the ZV series is about 4 years old, back then DVD manufacturers decided which formats they would support as it was too expensive to make desktop drives, let alone, laptop drives that supported all formats. That drive only works with DVD-R and I believe DVD-RW. If you want to burn other formats, the laptop will only support them if you add an external drive of a newer make.
Note: Virtually all current models support ALL DVD formats and many support BluRay as well.
Hope this helps,
Chris
Jul 07, 2009 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
HP Pavilion zv6000 won't power up after getting zapped
It sounds like you have a piece of junk, the hard drive mighr be OK , if it is you can put it into a USB hard drive adapter case and use it as an external USB hard drive.
May 05, 2009 | HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
The laptop heats itself a lot
The inside of the laptop may have a lot of dust in it and may need to be cleaned. It might also be worth while to get a laptop cooler. Something like this: http://www.flickr.com/photos/aerotus/98138764/
Nov 03, 2008 | HP Pavilion dv9000z Notebook
Broken laptop screen HP Pavilion ZV6000
I have a HP Pavilion zv6000 laptop too, and I have the same problem. A year ago, the screen was getting loose and finally it just broke. Won't stand up. I've been propping it up against a wall for a year. I can see what is wrong: my laptop has gotten so hot that the back of the laptop where the hinges are has warped and ruined the hinges. Do you notice that? The split in the seem and the actual bend of the plastic? Anyway, the computer itself works perfectly. I was going to buy new hinges and replace them myself, but it was too much of a hassle, and I needed a new laptop anyway. The hinges are inexpensive. And the laptop isn't TOO difficult to take apart (search for the manual. it's easy to find). I took it apart with my Grandpa, and he's old, and I'm a girl. (okay, sexist, gender...ist.) I actually received a new laptop as a gift. Luckily. No solution, other than replacing hinges. I just wanted to let people know I too had the same problem.
Aug 13, 2008 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
HP Pavillion ZV6000 Athlon 64 3500+ 15.4in WideScreen w/ 512MB/80GB/DVDRW/Flash Slot (PCLHCA6435512WWD) PC Notebook Logo
245 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
