Question about Canon PIXMA iP2000 InkJet Printer
IP2000 print head won't center
I have a Canon iP2000, no cartridges installed. When I open the front cover, the print assembly won't go to center position. It will move back and forth, but won't stop in the middle...
  • vinny1234 Dec 19, 2008
    my comp. keeps telling me that an ink cart. is not properly installed and when i open the front door the carriage does not go to the proper position. I think its a mechanical problem
  • lin47 Dec 30, 2008
    Mine keeps saying print head not installed, and it is! I tried unplugging and reconnecting. Didn't work.
Try to unplug the printre while the print assembly is on the middle
Posted on Mar 11, 2008
How to change ink cartiridges
  • 1
    Turn on the Canon iP2000 if the device is not on. Allow it to power up for about 30 seconds.
  • 2
    Gently lift the cover of the unit with your hands. Lift only the top cover of the printer.
  • 3
    Wait until the print head moves to the center of the unit. It automatically moves to this position, allowing you access to all the cartridges. Do not try to move the print head manually, or remove a cartridge before this part stops and the light turns green.
  • 4
    Remove the section of orange film on the side of the new ink cartridge. Twist off the small plastic guard on the bottom of the ink cartridge.
  • 5
    Remove the old ink cartridge from the ink cartridge holder with your fingers. Press the tab on the cartridge forward and then pull it up and out of the holder. Slide the new cartridge into its place. Push down on the top of the cartridge to snap it into the unit. Close the cover when finished.
Sep 03, 2012 | Canon PIXMA iP2000 InkJet Printer
Changing cartridges
1) With the power on, open the front cover. The print head should move to the center.
2) Prepare the new cartridge for installation by removing the tape(s). Do not touch the area of the ink cartridge that was protected by the tapes.
3) Insert color cartridge into the right slot, then the black into the left slot. Push up and in until the cartridge clicks into place.
4) Close the front cover. Wait until the printer finishes preparing the new cartridge(s).
Dec 20, 2009 | Canon Pixma iP2600 Photo InkJet Printer
I have replaced both the colour and black ink cartridges in my Canon Pixma IP 200 printer, but now it won't print anything. I have tried the computers cleaning programs but that has not worked. Any...
The print head is clogged.Try to unclogging manualy.Open the cover and first remove the ink cartridges.Then open the holder and remove the print head.Run hot tap water and put the print head with the nozzles up to stream water.Hold that 5 mins then turn the print head around
with the nozzles down.Hold that for every color of 5 mins.Then put the print head in hot water with the nozzles down.Left it water about 15 mins and then you must very nice to dry.When the print head dry put it in printer and start cleaning.If this not help you need to replace the print head.It's part number is QY6-0054.
Nov 05, 2009 | Canon PIXMA iP2000 InkJet Printer
Canon 1560 error - orange light blinking 5 times
It's mean "Print head not installed/Defective print head".First open cover and remove the ink cartridges.Then open holder and remove the print head.Clean the contacts on printer and print head using piece of cotton and some alcohol.Then put back all again.If the problem persist you need to replace the print head.It's part number now is QY6-0064, because the old QY6-0042 is discontinued.
Oct 29, 2009 | Canon BubbleJet i560 InkJet Printer
Canon Pixma ip2000 Inkjet printer wont print black. Replacing cartridge did not fix the problem.
Remove ink cartridges,then print head.
Clean print head with dry cue tips.
Apply strong suction over black print
jets on print head.
Replace print head and cartridges.
It worked for me.
Oct 17, 2009 | Canon PIXMA iP2000 InkJet Printer
The printer won't print and gives error code 5100
HI,
it seems that our printer has a problem.
let a service technician open your printer and look if they can still fix your printer head or needed to change?
thanks
Mar 20, 2009 | Canon PIXMA iP2000 InkJet Printer
Put in cartridge error
Hi celcono,
Many times this happens because the Print Head needs reseated.
Here are the instructions from Canon on reseating the print head.
Reseat the Print head Reseating the print head is seldomly required to do.
  1. Make sure the machine is powered on.
  2. Lift the Scan Unit until it locks into place (1). The Print Head Holder moves to the center.
  3. Open the Paper Output Tray (2).
  4. Open the Inner Cover (2). The print head holder (3) should be centered.
  5. Lift up the lock lever and take out the print head. The print head can be removed with the ink tanks installed.
  6. Reinsert the print head back in position and press down the lock lever.
  7. Close the Inner Cover (1) and the Scan Unit (2).
    CAUTION: Press the center of the Inner Cover until the cover locks into place.
  8. After the Scan Unit is return to its original position, the LCD displays a message asking if you replaced an ink tank.
  9. Press [+] and select [NO] to exit.
Regards,
-SHG
Dec 25, 2008 | Canon PIXMA MP130 All-In-One InkJet...
Canon Pixma iP2000
try cleaning the print head as follows, otherwise a new print head.
OK, Canon will hate me for posting this.
1. Remove ink cartridges
2. Remove print head
3. go to sink or tub (stainless steel, not plastic type), pick up a roll of paper towel on the way.
4. Fold several layers of paper towel and place on flat surface.
5. Run hot water until HOT!
6. Turn hot water back to a dribble.
7. Run the dribbling hot water through print head, be careful not to wet the gold contacts.
8.When water running through print head is clear, place print head on paper towel.
9. Repeat number 7 and 8 until no colour shows on paper towel.
10. Gently DAB print head (DO NOT WIPE) inside and out with dry paper towel until dry.
11. I normally replace print head after drying, but you may wish to let it air dry overnight.
12. Replace print head in printer and install cartridges
13. Start printing.
I do this to all 4 of my Canon printers every 6 months or so.
If any colour fails to print after this process it means your print head probably needs replacing.
Jun 28, 2008 | Canon PIXMA iP2000 InkJet Printer
PIXMA IP1500 - CANON PRINTER
Confirm that the ink tanks are installed properly When replacing the ink tanks, confirm that the new ink tanks are installed properly. If the ink tanks are not locked into place, paper may not be fed properly, or ink may not be supplied to the print head.
  1. Check that the printer is powered on and open the front cover.
  2. Wait until the print head moves to the center.
  3. Check if the ink tanks are installed properly.
    Ink tanks installed correctly
    Ink tanks installed incorrectly
  4. When installing the ink tanks, push the top of the ink tank until a click sound is made.
    Note: If the ink tanks are not installed properly, paper may not be fed properly, or ink may not be ejected.
  5. Close the front cover.
Jan 09, 2008 | Canon PIXMA iP1500 InkJet Photo Printer
Canon PIXMA iP2000 InkJet Printer Logo
444 people viewed this question
old marine
old marine
