Question about Mitsubishi XD300U Multimedia Projector
No display ---- XD430U
Mitsubishi XD430U:
There is no display after power on. Replaced a new lamp, but still no display.
power on, the the green light is on, for about 20 second, change to red. Some kind of resetting electonic noise for few times, then stop.
Color wheel is in need of repacement
Posted on Oct 26, 2008
Mitsubishi HC2 projector
Was the prvious lamp still working?
Jul 16, 2012 | Mitsubishi HC2 Multimedia Projector
Misubishi wd-52631 DLP TV, it shuts off suddeny. when turn it on again, the green power light is flashing, then steady green, then shut off again. the lamp light is NOT falshing or red. the status light...
Hi, have you replaced the lamp after 2-3 yrs of usage? The lamps used by mitsubishi tend to last around 4000 hrs 1-3 yrs.It is common for the green light to light up.Other common failures are the ballast which is the board that powers the lamp.Also check if its not overheatin, dust out the fans.Heres where u can get the lamp or ballast
Apr 19, 2011 | Mitsubishi WD-52631 52" Projection HDTV
Replaced bulb yesterday worked fine. Today light will not turn on. projector turns on both lights green for 10 seconds, then power goes red and status blinks green for about 5 seconds, then status light...
green green is power on, normal
then it tries to light the lamp, but it can't so the protection circuit comes activated.
you get red and green blinking
Then it goes to standby, red and off.
so something has happened to the lamp, or lamp ballast power supply.
Take the lamp out and check if all is OK with the 2 terminals in the connector, and the leads to the lamp are intact.
Failing that, I would suspect the ballast lamp power unit
Mar 25, 2011 | Mitsubishi HC1600 Projector
When i press power button green light comes on and then red light blinks 2 but the tv does not turn on
Question title shows it is Mitsubishi WD-65737 tv.
When did you replaced lamp in tv?
If lamp has not been replaced in last 2-3 years, please check lamp as it seems dead, that is why tv does not turn On.
Aug 26, 2010 | Mitsubishi WD65737 65" DLP TV
WD-62525, continous amber lamp light. No picture. Lamp is good.
Make sure u replace the lamp cover as the safety switch need to be closed to make the set work. If new lamp did not repair your problem , then it may well be the Ballast Board, Sometimes call the Lamp Driver.
Nov 28, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Red lamp light on Mitsubishi DLP 65" WD-C657
Lamp is always First to go unless power surge gets it Call Mats for Lamp 1-800-628-1118 or Find one on E-Bay got mine there for 85.00 free shipping.
Sep 21, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Alternating power and lamp status lights
...replace the lamp. The lamp is most likely WAYYYYY past its prime so I suggest starting there. Sometimes even if you had just replaced the lamp the new lamp could've blown. When there is no signal running through the lamp circuit there is no signal to the display sensor, which means no image.
hope this helps!
Jan 28, 2009 | Mitsubishi XD300U Multimedia Projector
Open Questions:
Mitsubishi XD300U Multimedia Projector Logo
290 people viewed this question
Top Mitsubishi Office Equipment & Supplies Experts
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
