Question about Sony KV-9PT20 9 in. Television
Sony KV-9PT20 my vertical is slowing shrinking, any ideas? Thanks, STan
  • Stanzman Jan 15, 2008
    Jaime, what I found was IC202 9v regulator in the vertical circuit going bad. Thanks for your input.
  • 2,336 Answers
Check for cold solder joints near or around the vertical section as well for leaky capacitors.
Posted on Jan 15, 2008
Sony KV-XJ29M50 top half vertical problem i.e shrink
Check and replace all electrolytic capacitors at its vertical output section. There will be 5 or 6 numbers. Replace all of them at the same time.
Apr 14, 2012 | Sony KV-XJ29M50 29" TV
KV-9PT20 have a different service menu handshake?
It is an old model of 1994 and does not have service menu facility.
Not fault of remote, TV has no service data adjustment menu option.
Apr 14, 2009 | Sony KV-9PT20 9 in. Television
After a few minutes picture shrinks to single line on screen and then powers off
Since the set works initially, there are likely poor solder connections at the vertical IC. If this is not addressed soon, the IC will fail and need to be replaced. The vertical IC is a small flat IC with about 11 pins or so that may be marked LA7837 or something similar. Try resoldering the pins first. If that fails to resolve the problem, replace teh IC. Feel free to post the marking here so I can verify you have the correct one.
Dan
Jul 30, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sound, no picture...please help!
(Pasted from the one before -)
Since I can't see your screen, I'll guess.
If the picture shrinks away in the vertical, fast or slow, it is in the vertical control circuit.
If the whole picture shrinks in both axes simultaneously, the high voltage circuit is the culprit.
This section is responsible for producing the accelerating voltage for the beam so if it is dropping out (quite common after years of use) there will be nothing to speed the beam to the phosphor to produce light.
Turn up the intensity when the picture drops out to see if you have any trace of light.
If not, it is the latter problem.
If you can still see a horizontal line that flickers a little (from video content) then it is the first problem described.
IF the flyback (HV) transformer is still available, it will cost somewhere between $25-$100 US (many lower cost sources have disappeared) plus labor.
Depending on whether the fault was the flyback or the high power transistor that drives it, there could be additional parts needed.
Since you indicated that it operates OK for a while, it could also be something as primitive as a failed solder joint and these can be tough to find (=$$ labor).
Jun 02, 2008 | Sony KV-32XBR250 TV
SONY KV-XF21M80
maybe the bytes of the memory are not enough for this case^_^
Feb 21, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
120VAC dead
There should be a small fuse on the circuit board inside the tv. Sometimes the fuse is soldered direct to the board and not in a holder. Hope this helps you,,, Mechanic
Jan 18, 2008 | Sony KV-9PT20 9 in. Television
SCREEN GOES BLACK AFTER 1 MINUTE
In electronics dust has nothing to do. cleaning will not solve your problem your problem is due to trouble in vertical section. mostly it is due to electrolytic capacitor in vertical section is defective.it is common problem. also check supply to vertical section. "THE SCREEN SHRINKS TOWARDS THE TOP OF THE SCREEN FOR A FEW SECONDS BEFORE THE PICTURE TURNS UPSIDEDOWN THEN TURNS BLACK." is called fold over. regards thanks
Sep 12, 2007 | Sony KV-32S42 32" TV
Up and away
problem in your vertical circuit look for cold solder joints.
May 29, 2006 | Sony KV-27S46 27" TV
Televison & Video Logo
62 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
