Question about Canon PIXMA iP90 Mobile Printer
Paper wont load
I put paper in after start up or before, turn printer on, it will load load paper
and try to print it states printer not online? It worked fine past 3 printing times?
    Genius:
  • 1,601 Answers
Please check the following items:
Check item 1:
The cable may not be securely connected between a printer and a computer, or be about to be unconnected.
Check that the cable is securely inserted into the ports of the printer and the computer respectively.
If a USB hub is used, connect the printer and the computer directly.
Check item 2:
Print jobs may be queued.
Delete the print jobs queued in the computer. How to delete the accumulated and queued documents in the computer (Windows)
Check item 3:
The computer settings may not be corrected.
Check the computer settings. How to confirm the computer settings (Windows)
Posted on Jan 14, 2008
My Star TSP600 Thermal Printer is displaying a flashing Error light. Power light on, new roll of paper loaded correctly, self-test was ineffective - nothing printed. What's my next step?
i know you stated you put the paper in correctlyin the printer but if the thermal reactive side of the paper is not facing the print head the thermal paper won't print on the wrong side of the paper. it will load into the printer and seem ok but the heat on the wrong side of the paper will not react and show any writing. Can you try turning the paper over in the printer feed holder so the other side of the paper faces the print head and give it another test .
Jun 21, 2016 | Star Micronics TSP600 Thermal Printer
Lexmark printer wont print
Leading cause of paper jams is debris / foreign objects that accidentally fell into the paper feed area. Please try this approach to fix the problem:
  1. Remove the sheets of paper from the feeder.
  2. Grab a flashlight and look inside the feeder for any debris or foreign objects.
  3. If you're willing and physically able, you may also carefully turn the printer over. Any debris should just freely roll out from the feeder.
  4. If feeder is clear, place the printer on the table. Open the printer cover and remove the cartridges.
  5. Check the cartridge area for any obstructions in the paper path.
  6. Close the printer cover.
  7. Re-brick your printer by pulling out the power supply - the black box where the power cord is plugged into. Re-plug after 30 seconds.
  8. When the printer turns on, reinsert the cartridges and load some paper. Try to print again to verify that the problem is fixed.
Jan 04, 2012 | Lexmark X4650 All-In-One InkJet Printer
Load error
When trying to print on continuous stationery, the display may show "Online Single Load". This will occur if the printer is expecting to print on single sheet paper even though you may want it to print on continuous paper. To clear the error follow this procedure. • Take the printer off-line by pressing the Online key • Press the Setup key • Press the key under "Paperway" in the display • Select Tractor 1 (or Tractor 2 if fitted/required) • Press the key under "Set" • If the job still refuses to print try loading the printer with a single sheet of paper to clear the command. To do this remove the tractor feed paper and close the cover on top of the tractors but not the outside cover. You will see a guide into which put a single sheet of paper and press the key under "Load" in the display. • The printer should commence printing. If it does not, then press and hold the key under "LF/FF" to eject the single sheet. Now follow the instructions above again to select the Tractor. The display should read "OnLine Tractor Load". Load the tractor fed paper into the Tractors and press the key under "Load". The printer should now be ready to print. Check your software settings for the correct paper path type. Ensure that the display does not show "Manual" otherwise you will have to clear this error in the same manner as you have for Single sheet
Dec 06, 2011 | Tally Dot Matrix T2265C Printer
Wont print ready light and alarm light flashing
When the printer "Ready" and "Alarm" LEDs flash as shown, please check the following points:
1.Paper Jam: Clear the paper jam referring to "How do I clear paper jams?"
If the printer does not automatically resume printing, press the control panel button.
2.No Paper/ Misfeed:
-The paper cassette may be out of paper or not properly installed.
-If it is empty, load a new stack of paper into the paper cassette.
-If there is paper in the paper cassette, make sure it is straight.
-If the paper is curled, straighten it before printing. Sometimes it is helpful to remove the paper, turn the stack over and put it back in the paper cassette.
-Reduce the amount of paper in the paper cassette, and then try again.
-Make sure you use paper that meets Brother's recommended paper specifications.
-Reinstall the paper properly, and then press the control panel button. The printer will start printing again.
Dec 06, 2010 | Brother HL 1430 Laser Printer
Changed cartridges, printer doesn't align or function
Something seems to be physically wrong in the mechanism.
Try the rolling wheels and the belt on which the cartridges run.
Jul 19, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Paper Wont' Load
Do not put anything in the tray but the paper. Most printers are shipped with moving parts taped so they don't move and break during shipping. make sure all tape is removed by following the quick setup issued with the printer.
Jul 23, 2009 | Canon Pixma MP480 All-In-One InkJet...
Printer wont print
Try to turn off the printer, and then totally disconnect it from power. Let sit at least 5 minutes and then reconnect and try again.
Jul 23, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Paper won't load. and Stops printing before it can start.
Try turning the paper around. Some times the corners of the paper get slightly bent and the paper wont load.If turning the paper around does not work, switch your paper. Hope this helps.
Feb 03, 2009 | Canon PIXMA iP1600 Printer
HP psc 1300 printer
I had to turn off my computer, unplug the printer power cord and computer cord. I restarted the computer and pluged in both cords to the printer and it worked.
Oct 07, 2008 | Office Equipment & Supplies
Printer is not working
Try pushing the print head carriage with a bit of gentle force. It is getting stuck, and hence the error. You may have to open side and top covers to reach this. Note: this is not the cartridges, but another device that moves back and forth on the slider carriage.
May 15, 2008 | Canon Office Equipment & Supplies
Canon PIXMA iP90 Mobile Printer Logo
82 people viewed this question
old marine
old marine
