Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
To much green
I get green around all figures
  • mikerr52 Jan 14, 2008
    i tried to the conversion which worked but the bottom of screen looks off.the conversion points look off
  • jsherman May 11, 2010
    Is your green out of focus, but not your red or blue? You need to be more specific for us to help you.
    Problem Solver:
  • 14 Answers
Check out the picture at If you see bowing like that when you try multipoint convergence, chances are your two convergence amps are bad.
Posted on Jan 15, 2008
  • 4,402 Answers
Posted on Jan 14, 2008
  • Cary Farah
    Cary Farah Jan 14, 2008
    replace convergence ic
Screen is displaying Red background color with glittery pixels effect around the figures
Please change the T-CON board, if it did not fix the problem, you may have a defective LCD Panel.
Apr 24, 2017 | Samsung LN52A650A LCD TV
What to do when your vectron wave is blinking red and green at the same time while charging.
When you attach the charger the wrong way round it will flash red and green. Turn it around and it will just flash red. Then when charged it will go orange.
Dec 12, 2010 | Master Heaters Air Hogs Orange Vectron...
Picture fuzzy and brighter in center. convergence good on red but blue and green only show in center crosses. green and blue glow around figures.
Ur convergence is dead,must be placed.U know how to solders?Tries these wesites for convergence kit.Tv repair,Tv Repair Kits.
Oct 23, 2009 | Philips Magnavox 9P6034C 60" Rear...
I have the power ground and hot wire all connected but the speaker wires dont corespond with each other. (e.g. green wire goes with green and black wire. I got a tan a black a blue a yellow a grey a...
whatever color they are coming out of your car for example one set is green. choose a color coming out of your cd player to hook up to green. test that if the front left speaker works wrap masking tape around the green wires in car and label front left. do that until you have them all labeled and correct then hook them up according to what you learned. I know it sounds tedious and it is but it's the only way you can figure it out if they are not labeled.
Mar 10, 2009 | 1999 Oldsmobile Alero
Paslode 900420 nailer green light cycles doesn't stop???
Sounds like you need a new circut assembly.
Around 40 bucks.
Feb 10, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Bissell Big Green Machine Model 1672 will not pump cleaning liquid
have a Bissell Big Green 1672, the older canister model. Went crazy trying to figure out how to get to the pump. Finally figured it out. The top green "shell" covers the motor & pump and is separate from the "grey" plastic housing. Using a screw driver, insert it between the small gap between the top "shell" and the housing. If you look at it with it laying down on the top, you will see the small 1/4" gap. Gently pry in between the two and work your way around. It will start to lift up and then you can easily work your way around and it will pop off exposing the motor and pump. Note that the wires to the on/off & pump switches will sill be attached to the top shell. If you take them off note where they came from and make sure they are all on when you put the top back on. I have had my Green Machine for years, what a work horse! To bad they don't make them anymore, the new ones that replaced them just don't have the same durability and power as the older Green Machines.
Dec 19, 2007 | Bissell 1697-7 Powersteamer Pro Deluxe...
No green on my hitachi 57s715
I would check for loose connection around the yoke and convergence ic's (stk392-xxxx)
Dec 01, 2007 | Hitachi 57S715 57" Rear Projection HDTV
Green screen
hi sir you have got a fault in the matrix board it is a kind of three amp. that drives the three colours to the screen so you have the green driver deffect manythings do that maybe a bs dout put transistor or a bad driver ic gain voltage and maybe a dried up capacitor that filters the green input or at last a bad screen green gun these things may be checked only bay qualified person to see the problem please don't forget to rate , remember i am here only to help u thanx
Apr 27, 2007 | Philips 30PW850H 30" TV
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
