Question about Maytag LSE7806A Top Load Stacked Washer/Dryer
Water continues to fill and drain
The water continues to fill and drain It appears to be a syphoning problem how do i repair this?
  • 5,911 Answers
Double check your drain hose and make sure it is not shoved down into the standpipe too far. If the drain hose is resting in the trap area of the line it will siphon. In addtion, if the top of the standpipe is sealed off and does not provide an air gap for the drain line, it will also siphon. It is common for consumers to want to push the drain line down into the standpipe to avoid overflows when the washer drains. This, in fact, causes more harm than good. It is also common for consumers to want to seal the top of the standpipe to prevent odors from the drain line from creeping back into the house. This also is more harmful than good. The drain line should only rest in the standpipe about 4 to 6 inches from the top with enough space between the hose and the perimeter of the pipe to allow for an air gap. It's a simple problem to fix if this is the case. It also beats having to pay a repair guy to come out and correct something you could have diagnosed yourself. Post back with comments/questions if you need further assistance. If it not a simple drain hose issue, I could give further advice on what may be a cure for your problem.
Posted on Jan 14, 2008
My Samsung WF42H5000AW front loader will not change over from rinse to spin. I will continue to go back to rinse over and over for hours. Debris Filter clear and washer drains
Are you sure the load is balanced? or could be a problem with the machines ability to detect out of balance condition. This may involve the motor, (speed sensor) or electronics - or some machines have switches to detect out of balance conditions (weighted pendulums, etc)
Or may be a problem with water level control - for example, when the machine tries to fill to high level for rinsing, it starts to syphon empty, and all the water runs out - then it fills again, syphons and the cycle continues. Syphoning empty is common, and is caused when the end of the drain tube is LOWER than the water level in the machine - or in your case is at a critical point when the machine goes into rinse. Check the installation instructions re waste hose positioning. Check the waste hose hasn't become sealed air tight into the waste pipe with slime, etc too!
Feb 02, 2018 | Samsung Washing Machines
I have a IE washer continue to fill and drain at the same time
most likely your drain hose is lower than the water level. check for correct hight of fitting the hose. Also the water can syphon out if there is no "air- break" between the hose and the stand pipe
Oct 04, 2014 | Washing Machines
The washing macine, continues to fill and never fills up or moves on to next cycle. So is continuously drawing water in to the drum and never filling up.
Your discharge hose is forming a syphon You need to arange a solution to break the syphon effect without causing an external leak such as a "T" piece at the top of the discharge hose with a valve. Shuts off under pressure (when pump is opperating) but opens when under suction (trying to syphon)
Sep 04, 2011 | Hoover HTC243 Top Load Washer
If the load size is set anywhere at or above large, the machine keeps filling until it gets to a certain point and then continues to fill while draining at the same time.
The water is syphoning out the drain. Make sure the drain hose is not sealed to the drain stand pipe it drains into, and make sure the top of the drain stand pipe is higher than the washers tub. Try to extend it with a coupling and a peice of pipe up to 36 inches.
Feb 13, 2011 | General Electric WHDRE526EWW Top Load...
Maytag washer doesnt fill with water. after about 3 inches of water in bottom, it starts draining out.
pull the drain hose out of the wall
it should only be six inches in the wall
or will create a syphone and the washer will continue to fill and drain and fill and drain
try this and let me know how it goes
Feb 09, 2010 | Maytag Legacy Series Top Load Washer
LSR8233JQ0Washer won't fill
The water is syphoning out the drain hose.
Many times when the stand pipe is backing up someone will seal the washer drain hose to the pipe to avoid overflow of the stand pipe.
This causes the water to syphon from the washer.
Or the opening for the stand pipe is just big enough to put the drain hose in and is to tight causing the syphon.
Putting the drain hose to far down the pipe can cause a syphon also.
Jan 20, 2010 | Washing Machines
Have a kenmore stackable that continually adds more water. Water is not staying in. What can I do ?
Hi, You need to check your drain hose. What you're experiencing sounds like either the drain hose is shoved too far down the stand pipe (home drain pipe in/on the wall) or it is lying flat on the floor/ground and syphoning out as quickly as it can fill. either scenario will cause the water to syphon which will manifest in what you're describing. This consiquently will never allow the level to reach the desired setting, hence the pressure switch cannot be satisfied. Try that and see what you find. Hope it helps. macmarkus :)
Nov 04, 2009 | Kenmore 98702 Stacked Washer/Dryer
Water continuously runs and cycle won't start. The washer tub doesn't seem to be filling with any water.
Probably a syphon problem . Check your drain hose to make sure hose is not stuffed too far down drain and air can get between the hose and the drain pipe . If you have tapped the hose to the drain to keep water from comming out the drain pipe , go to home depot or an appliance parts house , and get a syphon break . When a washer fills , but water level doesn't rise in the machine , it's being sucked out by syphoning thru your sewer pipe .
Aug 08, 2009 | GE WVSR1060A Top Load Washer
Washer continuously fills but drains at the same time during rinse cycle.
you have the drain pipe too low into tthe house drain pipe, raise the washers drain pipe up , you only need four inches down into the hous drain
also the house drain pipe needs to be as high as the lid of the machine before you put the washer drain tube into the house drain
you have a syphoning effect
Apr 20, 2008 | Washing Machines
Maytag LSE7806A Top Load Stacked Washer/Dryer Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
