Broken Mirror?? Color seems to be fine, but I have a cracked glass "look" that is projected on my screen. Is it my mirror, is it worth the repair. please help.
They make a replacement mirror glass available that uses double sticky tape. This has worked great for me. The heated function still continued to work!! In my case I replaced a scratched mirror leaving the old mirror in place. If yours is broken included is a link for a procedure to replace a broken mirror.
Confirm the dimensions before purchasing. Some car manufactures have more than one design for different model cars same year..
As long as the screen isn't broken you can live with the crack. The mirror can be cut to size at any shop..but you will need to match the angle perfectly to the old broken mirror
If you go to a parts house, they can order you a mirror face for around 10 to 15 dollars. It simply sticks to the mirror that is broken with adhesive. It is very permanent and if the mirror is still working and in tact mostly (only broken glass part) it should fix you right up. Look at autozone, oreillys, or even JC Whitney or Pep Boys for example. Been there Done that! :-)Hope that helps.. Thanks!
This is a hard question to answer without the make and model, but let me describe the typical response:
If the set is either an LCD or plasma type, the panels can be replaced. BUT... The cost of that replacement could exceed the cost of a new replacement set. Neither panel type can be "repaired" it must be replaced.
If the set is a CRT based unit, the CRT is not likely to have been broken, but the front screen or the interior mirror may have broken. Either the screen or mirror can be replaced as well.
For a more exact response, please post the make and model of the set.
It's the display screen. The 65v glass mirror is inside the cabinet that reflects the image onto the screen. I think what you want is the
front display screen....... and a leather belt.
