Question about Protron PLTV-37 37 in. LCD Television
Sound but no Picture
Im having a problem with my set..I have sound bit no picture..What could be the problem/ Model PLTV=37c Protron 11/2 yrs old.
Pete
  • 1 more comment
  • Anonymous Apr 03, 2008
    my protron pltv-32c died while watching TV,picture went away..still have sound..
    reset sat box,no luck.
    reset tv no luck..
    no display on screen when selecting menu or channel display.
    installed smaller tv and it works fine
  • maryboros May 22, 2008
    no remote control and have half pictures with another background?
  • amylaurie1 Apr 16, 2009
    If it's the input module (we have same problem but can access the menu), what does this mean; where can you purchase parts to fix this? Thanks for any help!!!
  • 3 Answers
Most likely it is the board on the lcd panel. The first question though is, can you get menus? If yes, it is the input module, if no, most likely the panel controller board. There are several makes of panels in these sets, so once diagnosed, we would need to know what panel you have to help further. I can help you figure that out once you let me know if you get menus or not.
Posted on Mar 05, 2008
  • Marcia Dolph Nov 26, 2011
    Hope you are still answering here. I'm having the same problem. Am able to get the menus, Is this something we can fix on our own. OI have no problem taking the thing apart! Thanks much
  • D.R. Huard Sep 06, 2014
    There are 4 boards in those sets. Power supple, T-Con (up on the top of the panel) and two together under the cover, the input board and Main video board. If you have menues then the video board is okay. You have to take the two boards apart and replace the one that has all the inputs and the TV Tuner on it. Yes you can do it yourself. No voltages that are dangerous to you except under the power supple cover. Good Luck
6ya staff
SOURCE:
Protron pltv 37c
Check this code [1288]. If you wish to get more, check these links. http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Sep 29, 2013 | Protron PLTV-32 Television
Trouble with sound and picture
You can probably get an original remote here:
remotes.com
It sounds a lot like you have either an analog signal on a ATSC input or vice versa and this would also prevent audio from being properly processed.
Dec 04, 2011 | Protron PLTV-37 37 in. LCD Television
Tv has no sound
Let verify first to narrow down to where the problem can be. First, make sure the MUTE function is not activated, then check the on screen sound set up menu to make sure the speakers are not set to OFF. If the setting is OK, then attach the powered PC speakers to the Audio Line out RCA jacks (Red and White) to see if you can get the sound there, if you do, then the problem can be in the power amp circuits, if you do not get the sound at RCA jacks, then the problem can be in the sound processor circuit. Please post back what you find.
Parts: www.shopjimmy.com
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Jul 20, 2010 | Protron PLTV-32 Television
Get sound but no picture. All cables and wires seem to be secure. Don't know what the problem is.
It can either be the backlight inverter board or the power supply is not supply 24vdc to the inverter board.
Oct 27, 2009 | Protron PLTV-26 26 in. HD-Ready LCD...
No sound on protron lcd tv
Go to the set up menu and select audio. check that the speakers are ON.. Then make sure that stereo is selected. If the set is set to alt sound there wont be any sound.
Jun 13, 2008 | Protron PLTV-37 37 in. LCD Television
No Picture (power indicator does not light up)
I have a Protron 37: LCD TV. The power indicator does not change to green (the red light is showing) and the TV will not turn on, either by remote or using the power button on the TV. The TV is about a year and a half old. Can you please help me?
Thanks
Mar 31, 2008 | Protron PLTV-37 37 in. LCD Television
Protron 37" LCD, PLTV-37C
You can look it up under the Spectroniq PLTV-3750 TV. Protron changed their name but kept the set up the same. Hope this helps...
Jan 18, 2008 | Protron PLTV-37 37 in. LCD Television
Protron PLTV-37 37 in. LCD Television Logo
180 people viewed this question
Top Protron Televison & Video Experts
Ekse
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
