Question about Mitsubishi WS-48613 48" Rear Projection Television
Mitsubishi WS-48613 No Video
I have a Mitsubishi WS-48613 approx 4 years old. About a year ago it started having a wavering picture when the unit was first powered on and then it would settle down and lock in.
A week ago I turned the unit on and had a black screen with thin rainbow colored lines scrolling up the screen. I removed the back to look for any obvious problems and when I plugged the TV back in I got the blinking green light problem. I replaced the caps on the DM board and the TV now powers up just fine. I still do not get any video on any input, but instead of the black screen I get a normal blue screen when no signal is found.
I removed the input terminal board from the tuner board to see if there were any obvious problems with capacitors bulging or discolored boards. All were fine.
Any ideas?
  • g322789_ Mar 15, 2008
    On my WS-48613 when I turn the unit on I am getting wavering ghost like imaging with lines; sometimes green horizontal lines when white is in background. It has been intermittent but lately getting worse/more frequent. I believe it is my convergence amp but I have no wiring diagrams to replace it myself and I am not paying these high prices to have someone else do it.
  • tmasd2002 Sep 11, 2008
    thanks
    Genius:
  • 1,153 Answers
If you have no video and audio then IC9c25 on Sig. Bd.
Posted on Jan 14, 2008
What year was this tv sold?
I think I got mine exactly 10 years ago
May 07, 2011 | Mitsubishi WS-48613 48" Rear Projection...
TV is approx. 10 years old. Picture has started
This is a model first made in 2001--when it does it go into the customer menu and select CONVERGENCE--what you are looking for is is red or blue skewed and will not adjust?
If this is the case I can tell you what is needed based on the model number you provided.
If you have any questions let me know--I am here to help people.
if this helps you rate this information as I do this here for FREE.
SD TECH
Nov 11, 2009 | Mitsubishi WS-55908 55" Rear Projection...
Same problem
It sounds like the classic "timer problem" that requires a "kit" (mostly capacitors) to repair it. To have someone do it (such as your service person) for you can be expensive and time consuming. Sets that are 5 or more years old usually have other problems too which, simply put, is a complete cleaning of all mirrors, fans, and filters.
Jun 27, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi ws-48613 no power
It seems problem of weak capacitors in power supply and deflection board.
If you have little experience of TV repair and good soldering skills, then check above said boards for weak capacitors.
You also need to have service manual of WS48613 which can be obtained from Manual Zone.
Service manual has schematics and technical information of TV to help in repair.
Dec 12, 2008 | Mitsubishi WS-48613 48" Rear Projection...
Mitsubishi Rear Projection 65" tv picture becomes blurred bouncing right to left and color is red & green. TV is 8 years old approx. Any suggestions. Have not had any problems prevoiusly. First it woudl...
Sounds like possible solder connections on the convergence ICs. If so, you will see the red, green, and blue not lining up on ever input and even the mits menu. If you can bump it to correct, its just a solder connection, but if its out all the time then the ICs need replaced. This is a difficult repair only recommended for skilled technicians (40 solder connections + possible re-alignment needed)
Dec 03, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi WS48613
you need to replace the 4 100uf capacitors on the DM board. You can get the service manual for your set at this link. They will email it to you after purchase and they will provide free instructions on how to do the repair with pictures plus free on line tech support . heres the link.
http://servicemanuals.vstore.ca/
Apr 27, 2008 | Mitsubishi WS-48613 48" Rear Projection...
Mitsubishi WS-65908 picture problem
since this happened after you moved i would look for loose connections on the convergence ic's
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 10, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi WS-48613
Did you try reset? Unplug AC cord for a while,plug in try again...
2) With paper clip, activate reset thru access hole on front of
TV ( consult owners manual) recheck.....................
3) Leave set unplugged from AC overnight.................T.
Please rate this solution........................
Nov 11, 2007 | Mitsubishi WS-48613 48" Rear Projection...
Akai 46 rear projection tv 1.5 years old
HERE WE ARE AGAIN WITH NO MODEL #................
Nov 10, 2007 | Mitsubishi WS-48613 48" Rear Projection...
TV picture goes out and then comes back, TV eventually turns off
Probable bad DM module = repairable by qualified Mits.tech.....
Nov 13, 2006 | Mitsubishi WS-48613 48" Rear Projection...
Mitsubishi WS-48613 48" Rear Projection Television Logo
214 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
