Hp deskjet prints symbols/wingdings instead of text
I have an HP deskjet 9650 that has begun to print symbols/wingdings instead of text. I tried turning it on and off but no use.
  • Anonymous Apr 10, 2008
    My Desket 970cxi InkJet Printer prints out wingdings instead of text. We tried to turn it on and off, and even delete the printer and reinstall it. We can't get it to work and any suggestions would help!!
  • 233 Answers
Sounds like a driver problem.
1. reboot your "Computer"
2. re-install driver
3. test print.
hope this helps
thanks for rating
Posted on Jan 14, 2008
Adobe PDF reader tends to print webdings/wingdings in its version 8 incarnation. Download FOXIT reader free from and try to print your document from that instead of Adobe. This nearly always fixes the problem. antosarmy
Nov 25, 2009 | HP DeskJet 5550 InkJet Printer
Hp deskjet 9650 not compatible with Vista 64-bit
Hp Deskjet 9650 printer owner, sorry to inform that there is no Microsoft Windows Vista operating system printer driver solution available for your printer. But there is an alternative way to workaround it so that you can do basic printing with your printer.
As a workaround, an alternate printer driver solution included in Microsoft Windows Vista operating system can be used to perform basic printing to the printer. However you might find that some of the product features are no longer available when using this alternate printer driver, but that is your best option right now.
The alternative HP printer driver that will work with your printer is HP Deskjet 9800.
The Next thing you do is: Install the driver for HP deskjet 9800
1. Verify that the Universal Serial Bus (USB) cable is NOT connected to the printer.
2. Click Start , click Settings , and then click Printers .
3. Click Add a printer .
4. Click Add a local printer .
5. Select the Use an existing port check box.
6. In the Use an existing port drop-down list, select LPT1: (Printer Port) and then click Next .
7. Under Manufacturer on the Install the printer driver dialog box, select HP .
8. Under Printers , select the appropriate alternate driver for the printer (deskjet 9800) and then click Next .
9. In the Printer name text box, type the printer name and then click Next . The printer driver starts to install.
NOTE: The name of the alternate driver displays as the default name. Change this name to the name of the printer, if desired.
10. After the screen stating that the printer was successfully added displays, connect the USB cable / Parallel cable to the printer and to the computer.
11. On the Found New Hardware screen, click Cancel .
12. For USB connected printer, please proceed to step three . For Parallel port connected printer, please proceed to step four .
NOTE: If multiple pop-up windows display, click Cancel on each window.
Next is: Configure the printer
1. In the printer folder, right-click on the name of the printer and then click Properties .
2. Click the Ports tab.
3. Change the port from LPT1 to the newly created USB port, click Apply .
Last step: Print a test page
1. Click the General tab.
2. Click Print Test Page .
Good luck Cheers!!!
Print to small on hp deskjet printer
Reinstall the driver, hp constantly updates their drivers, with bad drivers sometimes itwill even print the "wingdings" font instead.
- Canis
Mar 09, 2009 | HP DeskJet F380 All-In-One Printer
from Windows Desktop, click Start, settings, printers, locate and right click on the icon for your printer. Go to Properties, Advanced, then print processor, make sure that the options WinPrint, and Raw are selected, then click ok back out, try printing again.
Daniel (rydf)
Apr 30, 2008 | HP DeskJet 6540 InkJet Printer
well..assuming that the text is the same on all, this might be a settings issue, with the print spooler. That's in the set up of the printer, under properties..look into that, and perhaps you'll want to spool the whole job, instead of printing immediately?
print spooler memory is finite, so the longer jobs will take longer.
Mar 17, 2008 | HP DeskJet 5650 InkJet Printer
Hp-dj 9650 won't print
please reinstall printer software
Sep 22, 2007 | HP DeskJet 9650 InkJet Printer
4,216 people viewed this question
