SOURCE: Keeps flashing F35, when unplugged and plugged
F35 Is an electrical fault in the Control Board.
Try setting the machine on off.
Then remove the plug from the wall for 5minutes. this will usually reset the system and get you going if it is only a glitch in the electrical system.
If this fails to remedy the problem then you have what appears to be a failed control board.
The only way to be sure is to have it diagnosed by a hands on tech.
Or risk your money by swapping it out your self.
The problem is that usually when my customers try this, they end up spending part money and then a service call on top of their failed attempt.
Thanks for using FixYa - a FixYa rating is appreciated for taking the time to answer your FREE question.
SOURCE: My Kenmore Elite HE5t washer flashes SUD
Sometimes the SUDS/F35 is because of TOO MUCH detergent. To clear you have to set the cycle on rinse and then keep pouring cups of water into the detergent container as the cycle is going. You might have to do this a few times because if the SUDS message comes up the water flow will stop. Just unplug and try again. Also when the detergent container is finally clear you will see the little rotators gears move around when the cycle starts.
SOURCE: Sud and F35 error in my kenmore elite h5 steam
I got the f35 and suds code repeatedly and my clothes weren't washed, I ordered from Sears the analog pressure switch that regulates the water coming into the washer and the codes went away, the part is esitmately $125.00 including shipping but you have to order from the Sears parts department.If you print a diagram of the washer it is #38 in the diagram and is easy to replace. You can install it yourself and as a female I did not call service to do it.
SOURCE: My Kenmore Elite he5t steam
Hi
Thanks for using FixYa. Error F 35 means ANALOG PRESSURE SENSOR FAILURE- If this failure is displayed then there is any malfunction of the component detected by the Steamer Electronic Board.
1. Check if pressure hose is fixed correctly.
2. Check if the air trap is not blocked.
3. Check if the hose is not blocked
If it still not works then it is a problem with the water level pressure switch operation. There could be a blockage in the air dome or pressure switch hose. The air dome is located on the back of the tub on the left hand side. If the pressure switch hose and the air dome are clear of any blockages, then there is an issue with the water level pressure switch.
Please do rate the solution if the issue is resolved or else post a comment for further assistance.
Thanks
Rylee
SOURCE: My Kenmore Elite he5t steam washer is about 2yrs
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.^@$$
