Question about Nokia 6300 Cellular Phone
Nokia 6300 'Restricted' Message
Hi, my eBay purchase has just arrived, it was supposed to be unlocked but it appears to be on Vodaphone. When I put the sim in I get 'restricted' error message and it promps me for a code. My imei number is:359538013578410
Can anyone help pls?
Cheers J
  • 4 more comments
  • Goatess Jan 15, 2008
    Hi Paul, thanks for your reply. The phone is on Voda and registered in the UK, thanks for your help and best wishes Jane
    Hi Paul, thanks ever so much for your help, but unfortunately none of the codes have worked. I've even tried dialling 112, but the phone won't let me with the Sim card inserted. Not sure what to do now, but your help is much appreciated. Best wishes Jane
  • cypet Jan 17, 2008
    I have the same problem with a Nokia 6300 locked on prepaid O2 UK. The phone was made in Hungary and its IMEI is: 359810012104583. I would appreciate any help with the codes. Thanks.
    Peter.
  • ned flanders Feb 06, 2008
    hi my nokia 6300 has also been restricted due to me putting in wrong codes because it is locked to orange im in england the imei number is 356436011212699 please help
  • Natalie
    Natalie May 11, 2008
    hi my nokia 6120 has been restricted aswell and has been locked to 3 ..the phone was made in korea and the imei is : 356255010934793
    any help would be great thanks!
  • memosoft212 Jan 29, 2009
    plz help me i have same problem my phone is nokia 6300 need a code of restricted phone my
    :imei is : 0537630356437
    thanks,
  • 4,102 Answers
Could you please tell me what country the phone is from as the codes are diferent for each country and is it deffinately locked to voda as need to know this to get the codes
Posted on Jan 14, 2008
  • paul proctor Jan 15, 2008
    hi jane first i need to tell you how to enter the code you enter it with no sim card in the phone ok.
    The code will look like #pw+???????????????+?#
    after the # to get p you need to press * 3times quick and to get w press * 4 times quick and to get + press * twice quick.
    Now you know how to get p and w and + onto your phone.
    Now for the codes their are seven different codes for your imei number but you only get 5 trys at getting the right code after 5 trys the only way to remove the simlock is by a cable to a computer getting it wrong 5 times wont damage the phone so dont be worried about that.
    Now usually if code number 1 dont unlock it then code 7 will each code is to undo different locks on phone ie one code will be for orange sim and one for o2 but usually code 7 unlocks them all ok but try them in this order 1, 7 , 5 , 3 if its still not unlocked by now but it should be but if not try any other code you havnt tried but from exp it should be no problem ok here are the codes enter them exactly as they are only do 1 at a time and wait 30 sec or more before you enter next code ok this should stop the 5 trys and let you try all of them even switch phone off after each code for 30 sec should let you try all codes but you probably wont need to try more than 2 anyway.
    Here are the codes
    #pw+012933334051335+1# try 1st
    #pw+233145254133640+2#
    #pw+427937446551631+3# try 4th
    #pw+704000326202704+4#
    #pw+425877743320771+5# try 3rd
    #pw+393016016122114+6#
    #pw+909872526710771+7# try 2nd
    Now they are all the codes for your phone if you still need further help let me know ok.
    Now there is 1 other way of using a different sim card in your phone but this dont work on all nokias but you could try it anyway but doing it this way will only let you use the sim card till you switch the phone off then you will need to do it again you could try this way if you like here it is ok.
    With the barred sim card in switch phone on then dial 112 press call then # send , end , send ,end.
    After doing this you should be able to use the sim card untill the phone is turned off then back on again.
    Let me know how you get on i know its alot of info but it does work and will allow you to use different sim cards ok
    Ill have another look for you now ill check all the codes are correct failing this the only problem that i have come across is with the software version on the phone if you could press *#0000# do this with working sim card in this should show you the software version it will give you make of phone then under neath it will have v 3.4 as an example some software versions have restricted the unlock code setting and the only way to unlock is buy using a cable and computer the cheapest place to get this done is in a market or small phone shop as the bigger names like car phone warehouse will charge alot higher to unlock the phone than a small independant trader will charge.
    if you tell me software version i will check for you but sorry if its not possible to use the codes but will double check for you ok
Hello everyone, could someone please help me unlock a nokia 6300 phone my got for my little sister from china . i want to activate it on att in the USA.
thanks anyone . :imei -135790246811220
imeisv:87
email @ rcerskine@juno.com
Posted on Jul 12, 2008
Unlock to nokia 6300
hi guys u can try 12345.its nokia default code.
Jul 14, 2009 | Nokia 6300 Cell Phone
Unlock nokia 6300
Hi, jobinthompu your IMEI: 358052017980938
mastercode:
540201404x
The mastercode can be entered instead of standard security code.
please do not forget to rate this solution if it works.
Dec 11, 2008 | Nokia 6300 Cellular Phone
Nokia 6300 no service provided
i think warranty period then you take will nokia service center
Nov 07, 2008 | Nokia 6300 Cellular Phone
How to unlock a Nokia 6300
goto google and write 6300 mobile unlocking and u will det it
Oct 16, 2008 | Nokia 6300 Cellular Phone
Nokia 6300
try asking your operator. they must know how to solved it.
Jul 08, 2008 | Nokia 6300 Cellular Phone
Unlocking my nokia 6300
Follow the instructions given below & unlock the mobile by getting unlock code in this site http://www.theunlockarena.com/unlock-your-phone/rs13wp2/
Warning : Do not enter any wrong unlock codes on your Nokia 6300 mobile phones. If you enter over a certain amount of wrong unlock codes on your Nokia 6300 mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch on your Nokia 6300 without any sim card.
2 - Don't bother as to what is displayed on your Nokia 6300.
3 - Compose #pw+CODE+1#.
4 - The Nokia 6300 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia 6300 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia 6300
Jun 25, 2008 | Nokia 6300 Cellular Phone
Unlock from vodafone ireland
Hi wardysur,
If u want to get relief , u've to unlock the Vodaphone password, fixed by Vodaphone.
Contact a reputeed concern who'll do it for u.
Thanks.
Supriyo DG
Jun 04, 2008 | Nokia 6300 Cellular Phone
Nokia 6300 Cellular Phone Logo
394 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
