I HAVE FOUND THE ANSWER!!!! I just bought an TCL TV last night and was given the wrong remote. Screen was stuck on "no media" screen BUT I noticed that when I turn the tv on and keep pressing the menu button, the menu screen would pop up for a half second before the no media screen popped up again. So I knew it was able to access it. SO, it took a few try's and with no exact method I turned the tv on, waited til I saw the TCL logo and then simultaneously pressed the menu and channel up button repeatedly. It will open the menu for you and allow you to move between the input channels!!!! It WILL take a few tries to catch it but it worked!!! Your welcome!!!!
Seems like a problem with the main audio/video board. Does the screen come on and stay lit? Please provide this info so that I can confirm the problem and offer you an appropriate solution.
Push the menu button and enter 1370 and push enter and the tv picture will appear on the screen. If it does not push the input button until the picture appears.
look in the back, see if the lamp is actually lit. If it is probably not a tv problem. If you can pull up the menu then you probably are on the wrong input. Are the fans running when you turn it on? IF fans are running might be lamp, if nothing is seen through the back.
First check Tv menu comes on screen?
Connect DVD Player at any a-v input and confirm picture on tv. This will confirm that tv has no problem except in tuning circuit.
Now check Antenna / cable hooked up in RF input of tv properly.
Perform Auto-Search / Auto-Tuning / Auto-channel on TV menu and tune all available channels.
Still blue screen? means TV Tuner looks bad.
I, too, acquired a Phillips without a manual and was experiencing a similar problem. My model is PTV 916, but if your TV has a "source select" button, say a prayer and press the button. From that point, I don't know what else I did, but I do get TV programs now.
The problem with the tv was the mother board had it repaired for $500.00
