Lexmark Wheelwriter 2500
The ribbon is not moving and therefore every strike hits in the same place...pretty much makes typing impossible. I have taken the ribbon off and tried to figure out why it is not moving but with no luck. Any suggestions?
  • 3,594 Answers
If th ribbon is lifting but not feeding you probably need a new ribbon.
DickyO
Posted on Jan 25, 2008
Ribbon sits higher than striking mechanism. Machine is not rotating it down into normal operating position. Any solution?? Tks
Take the ribbon off, watch the ribbon deck while typing and correcting. Is it making the proper movements, lower for print, higher for correction, is the ribbon motor just under the R. side or the deck moving? If the ribbon motor isn't moving check to see if its cable is connected and Put som WD40 on the upper and lower bearings.
DickyO
Nov 30, 2010 | Lexmark Wheelwriter 15 Series II...
Ribbon strike mechanism won't move and strike ribbon when key is hit
You most likely have a broken plastic print solenoid cap.
We sell them for 20.00 with instructions and shipping.
DickyO
Cleveland Business Machines
216-241-0027
Sep 16, 2010 | IBM Wheelwriter 6 Typewriter
How do I store info in Lexmark wheelwriter 2500?
You have to hold the store key while you type the address, then type the info., then touch store again.
You can go to lexmark.com, click on support and you lill find a manual there.
DickyO
May 24, 2010 | Lexmark Wheelwriter 2500 Typewriter
Ibm wheelwriter won't strike. Ribbon is good. Wheel is working. Carriage is moving. Just not striking. I dusted & cleaned as well as I can but to no good.
I HAVE AN IBM WHEELWRITER 6 TYPEWRITER THAT WONT STRIKE THE LETTER. EVERYTHING ELSE WORKS? CAN YOU HELP ME FIX IT?
May 10, 2010 | Office Equipment & Supplies
IBM Wheelwriter 6-Letters striking paper above
Put in a multi part form and type if the carbons come out OK the the ribbon isn't lifting, Wiggle the big black gear on the R. side of the carrier back and forth. They do get tooth for tooth when they get old. If the print on the copies id bad or not there you need a print solenoid cap. We sell them for 20,00 including instructiond and shipping.
DickyO
216-241-0027
Feb 18, 2010 | IBM Office Equipment & Supplies
Ribbon will not move when typing
If this is a wheelwriter remove the ribbon, mark the driver on the ribbon deck with some white out, type and see if it moves.
If it moves try a new ribbon, if it dosen't move put some WD40 on the upper and lower motor bearings if that dosen't help you probably need a motor or a board.
DickyO
Jul 14, 2009 | Lexmark Wheelwriter 1500 Typewriter
I can't get documents to print in color i need color copies
the wheelwriter 2500 typewriter will only print the color the ribbon is, which normally is black.  you may be able to find a colored ribbon for your machine.  try googling it.  good luck with that.
Feb 25, 2009 | Lexmark Wheelwriter 2500 Typewriter
IBM Wheelwriter 3 not striking ribbon onto page
There is a plastic cap on the print solenoid plunger that is probably broken, they are available but a little tricky to install.
DickyO
Sep 22, 2008 | Lexmark Wheelwriter 3 Typewriter
Wheelwriter 30 Series 2
First off make sure the ribbon turns freely.Take off the ribbon and turn the ribbon wheel in the direction of the arrow and see if it turns smoothly. If it turns smoothly the ribbon motor is not moving or the gear is not moving. take off the ribbon and type. See if the black ribbon drive gear on the ribbon deck moves as you type. If not the motor is N.G. or the ribbon gear clutch spring is not grabbing the gear to turn it. Lawrence
Feb 14, 2008 | IBM Wheelwriter 30 Typewriter
Wheelwriter 6
You may need a ribbon motor or motor board, however on the older wheelwriters sometimes the gear mesh gets sloppy and gears jam tooth for tooth. Try moving the ribbon lift gear/cam on rt. side of the carrier by hand with the machine off if it won't move that's the trouble. Wiggle it back and forth and it may free up.
Dec 20, 2007 | Lexmark Wheelwriter 6 Series II Typewriter
110 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
