Green line across the bottem of TV. converge reset or ajustment didn't work
    President:
  • 4,402 Answers
Http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on Jan 14, 2008
I try to ajust the green convergence on reference mark down ,and i can't move this line to left or right. how i can ajust the lamp to the righ or left. thank you
Ur tv 100% have a problems known as a convergence picture peoblems.The tv convergence board it is dead,if any of the colors lines R,G,B mis alignments and u will not able to auto or manually to adjust any of the R,G,B colors lines to alignments any of them up.The tv convergence board must be replace like 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The tvs shops will cost u like $300-350 for parts and labors.
May 29, 2011 | Panasonic PT-47WX51 47" Rear Projection...
Black screen with 3 colored lines going across
Ur tv convergence ICS are dead.U have tools to do soldering,and know how to do soldering?Must replaced 2 STK convergence ICS,and some or all it resistors.Tries websites like Tv repair World.com,Tvrepairkits.com to buy a convergence to repair it ur self.The shop will cost u $300-350 for parts and labors.
Apr 28, 2010 | Hitachi 53UDX10B 53" Rear Projection...
Convergence issue; red 3D effect. In grid convergence mode blue will converge w/green fixed lines and red horizontal will but the verticle red will not adjust far enough left to converge. has ajustment...
Convergence is dead.Must know how to solders?Must replaced ICS and all of it resistors.Tries Tv repair World.com,Tvrepairkits.com for a convergence kit.The shop will cost u $300 for parts and labors.
Jan 24, 2010 | Hitachi 43FDX01B TV
Letters and numbers are 3d and curved picture
Hello
red, green, and blue lines curve across the top of tv is cause by defective convergence STK IC or you have open resistor at convergence section. if you have defective RGB Color vertical ramp probably you have defective STK IC..
Angel
Thanks...
Aug 02, 2009 | RCA D52W23 52" HDTV CRT TV
My projection screen has blue and green lines across the screen id do not know how to converge the lines akai screen where do i go to fix it
Hi, thank you for visiti fix ya.
Your tv need convergence ICs service ( replace).
Can you send me model number tv, please?.
Thank you
Jul 25, 2009 | Televison & Video
Horizontal Green Convergence line on PT-47WX49 is offset to the left 1-2" and can not be ajusted back. The center of the TV viewing picture is the only portion that appears normal.
you will need to replace the convergence ICs and feed resistors. You can get the convergence repair kit for your model at the following link. The kit contains the parts and a CD with the instructions on how to do the repair.
http://www.tvrepairkits.net/
Jul 10, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Toshiba 57h81 green will not focus
Typically this is a convergence problem and can be repair relatively easy. Refer to this video to determine if you truly have a convergence problem. Also make sure you use your TV's original remote to make this adjustment.
Nov 15, 2008 | Toshiba 57H81 57" Rear Projection...
LINES ACROSS TV
Good Day, YOU ALL;
Try this: 1. E2RESET DOES NOT RESET THE CONVERGENCE. THE CONVERGENCE CAN BE RESET BY PRESSING "MENU 12598970", IF THIS DOES NOT RESET THE CONVERGENCE TRY "MENU 125968970"
2. CHECK C2P08 100 UFD 16 V OFF PIN 3 OF IC2P03 (3.2 VOLT REGULATOR) ON THE SIGNAL PCB.
Also you may poor solder connections on the vertical output IC or on the CONVERGENCE IC's.
Hope this helped, good luck, big IRISH.
Jun 04, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Can't correct green convergence
need to replace both Convergence ICs number STK392-110 you can het replacements here and they provide free instalation instructions and free on line tech support so you can do the repair yourself. heres the link.
http://servicemanuals.vstore.ca/
Apr 16, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Televison & Video Logo
57 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
