Question about Sony BM-23MK2 Handheld Cassette Transcriber / Recorder
Corroded batteries For the first time ever, the batteries in my Sony BM-23 corroded.  With difficulty, I was able to remove the top battery.  The second battery is not cooperating. * How can I remove the second battery? * Will I need to have the recorder repaired?
  • 233 Answers
If it is really stuck inside the only way is to open it up
be "Very" carefull when opening, only open it enough to where you can stick something thin in the battery compartment to push out the battery, then use some rubbing alcohol and a Small file to clean the contacts.
good luck
thanks for rating
Posted on Jan 14, 2008
2001 BMW R 850 C misfires
Hi, Anonymous and the usual suspects are:
1. Severely discharged or a damaged battery should have 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a cursory reading of 12.5 volts or more but little or zero amperage the battery is faulty and must be replaced, AGM batteries fail in this scenario more so than lead-acid batteries.
2. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
3. Spark plugs in bad condition or partially fouled.
4. Spark plug cables in bad condition and leaking check for spark leakage in the dark
5. Spark plug gap too close or too wide.
6. Faulty ignition coil, module, and or sensor.
7. Loose, dirty, or corroded ignition module connector at crankcase.
8. Faulty CKP or CMP, MAP, ETS, ATS, TPS, O2 sensor.
9. Dirty air filter.
10. Intake air leak.
11. Water, dirt, or rust in the fuel system.
12. Carburetor contaminated, sticky float, plugged jets.
13. Carburetor vacuum diaphragm torn, cracked, not seated or installed improperly.
14. Multiple carburetors out of sync.
15. Fuel filter clogged.
16. Old or contaminated fuel.
17. Fuel tank vent system plugged or carb vent line closed off.
18. Gas cap diaphragm valve faulty.
19. Vacuum line from intake manifold to fuel valve is broken, cracked, pinched, or missing.
20. Carburetor controls misadjusted.
21. Incorrect valve timing.
22. Valve springs floating, weak, or broken.
23. Damaged intake or exhaust valve.
24. Incompatible performance parts.
25. Control module may be in "LIMP" mode
26. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
BM Bikes BM Riders Club
R850R Fuel Pump and Filter with Water in the Gas
BMW 1200 Repair Manual
BMW Parts Microfiche
http://mybikemanuals.com/bmw/2005-bmw-owners-manuals
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Nov 25, 2017 | 2001 BMW R 850 C
How do I fix my PCM-M10 Sony audio recorder? I haven't changed the batteries for a while and it looks like they are corroded. The recorder won't switch on. Is it fixable?
Carefully remove the batteries and remove the corrosion. Outdoor is better to reduce being exposed by breathing it in. After removing corrosion, add new batteries and try again.
Oct 03, 2015 | Sony Pcm-d50 Portable Linear Pcm Recorder
Start and solenoid good, battery good, cables clean. turn key and solenoid clicks, even sometimes if you turn key off, you can hear clicking noise from solenoid. any suggestions?
Solenoid clicking would indicate solenoid faulty or low battery.....since you say battery and solenoid are good I would check voltage at the solenoid! Could be break in wire or earth bad!
Aug 16, 2015 | 2001 Chevrolet Blazer
HOW TO REMOVE CORRODED AAA BATTERY FROM MINI MAGLITE?
Try some baking soda with a few drops of water, it should loosen it up.
Oct 08, 2014 | Mag Instrument AAA Mini Maglite...
Why will my Canon EOS Rebel 35mm camera not turn on?
Probably battery compartment corrosion. Check for corroded contacts and clean them with a nail file or similar "tool". If that doesn't help, the corrosion has probably run into the circuit behind the contacts. If I remember well, that compartment is removable without great difficulty. I would get one of my relics but don't have the time today to dig through all those boxes!! Let me know if you need further help.
Jul 23, 2014 | Canon EOS Rebel G 35mm SLR Camera
Battery charging flashing
When you say the battery has been stored for two years, I hope you removed it from the camera before storing it. Otherwise, the terminals may have corroded and damaged more than the battery. If nothing is corroded have the battery checked. Sitting unused for that length of time may have shortened the battery's lifetime considerably.
Dec 07, 2013 | Olympus Stylus 790SW Digital Camera
Starter/battery
Remove the starter & have a parts store test it,
if you don't have that ability to do yourself on the
vehicle
Have the battery tested also
There are other items,any on a 23 year old vehicle
Ignition switch worn out,wiring issues,fusible links corroded
Think you need help from experience folks
Aug 28, 2013 | 1991 Nissan Pickup
Honda xr80r starting problem after top end rebuild @
1. Fuel tank empty.
2. The fuel tank has old dead gas.
3. Fuel tank bottom contaminated with ethanol sludge, dirt, water, rust, etc.
4. Fuel supply valve/petcock turned off.
5. Fouled spark plugs.
6. Engine flooded as a result of overuse of the choke.
7. Vacuum hose to the fuel supply valve/petcock disconnected, broken, cracked, or pinched.
8. Fuel valve/petcock or filter clogged.
9. Fuel line to carburetor or throttle body pinched, kinked or blocked.
10. Carburetor float stuck.
11. Fuel injectors clogged.
12. Fuel injectors stuck open.
13. Quick disconnect check ball stuck.
14. Compression below 75 PSI.
15. A stuck-bent-burnt valve.
16. Severely discharged or a damaged battery should have 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a cursory reading of 12.5 volts or more but little or zero amperage the battery is faulty and must be replaced, AGM batteries fail in this scenario more so than lead-acid batteries.
17. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
18. Loose or corroded wire connection at the coil or plug between ignition sensor and ECM module.
19. Spark plug cables in bad condition and shorting check for spark leakage in the dark, cable connections are loose or connected to the wrong cylinders.
20. Ignition timing incorrect due to a faulty ignition coil, ignition module or MAP, CMP, CKP, O2, TPS, ETP, IAC sensors.
21. Faulty neutral, clutch, kickstand safety switch.
22. Faulty fuel pump or fuse or relay.
23. Faulty or corroded run/stop switch.
24. Tilt sensor needs a reset.
25. Security system not disarming alarm needs a reset.
Other four stroke wont start top end rebuild
XR400 Wont start after top end rebuild
Honda XR80R Service Manual
https://www.partsfish.com/page/oem-parts-for-honda
http://www.hondampe.com.au/docs/owning_a_honda/owners_manuals/motorcycles/XR80R-2003.pdf
Apr 14, 2012 | Honda Motorcycles
Car intermittenly will not start unless you jump it off...has new starter, new battery, & ignition switch....
Consider inspecting battery cables. They may look ok, but could be corroded and oxidized inside. If so, they have difficulty passing adequate current to starter/ground. I've always had issues with exactly this with 87 Cressida and 95 Camry.
Sep 18, 2010 | 1985 Toyota Cressida
Battery corroded inside microphone
My experience with repairing Sony microphones for a television station is that once the battery corrosion eats the copper anywhere within the mic, the circuit (not the mic) is toast. I would send it in to Sony direct as they will have the parts and expertise to turn this around quickly for you.
Oct 03, 2006 | Sony ECM-MS957 Professional Microphone
Sony BM-23MK2 Handheld Cassette Transcriber / Recorder Logo
190 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
