The flashing lights
My miele w504 washing machine decided to flood the utility room this morning. there are two flashing warning lights, saying, check the supply and check the filter, both supply and filter seem fine, I've blown down the waste tube (yuk)- no blockage there. any thing else to try? before I wait for two weeks before an engineer arrives?
  • oldbill Jan 16, 2008
    Thanks Guru,
    The spigot is clear, and the standpipe shecked, -still those lights.......
    Getting dirty with the pump next.
    boomshanka
    President:
  • 1,294 Answers
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too. Check your pump too after refering to your manual.
Rate me pl.....if helped.
Posted on Jan 15, 2008
Water leaking into the drum of my Miele washing machine when it's not in use
water inlet value is leaking. turn off water after use until u replace the value or it could start running hard and flood the room
Apr 07, 2014 | Miele Washing Machines
How do I open my Miele W504 and change the motor brushes
Hi Kieron
Open door then turn off power. Undo 3 bolts around door seal. Remove soap draw. Undo the screws. Peel off door seal at front of machine and fold in towards drum. Metal spring catch located at bottom behind pump filter door. Now open up front of machine (its hinged on the right). Good luck
Feb 19, 2012 | Miele Novotronic Premier 500 Front Load...
Spin light flashhes spin does not work
The Miele W864 model will flash a warning light and will refuse to spin when it considers its load to be unstable....What I mean is... if you put a blanket in it and the blanket is on one side of the drum, the computer decides that if the machine spins, the centre fugal force or whatever they call it, the weight of the thing inside, will make the machine move about dangerously and will therefore not spin... its a safety feature. My spelling is shocking... I will look at the manual. Which says the load is unstable... more or less... waterlogged garments, like blankets can do this.... I normally just fill it with towels, and wash twice or three times because I wont get a good wash when overloaded.xx
Nov 12, 2011 | Miele W864 Front Load Washer
Miele W1203 washer drain and intake lights flashed together and now will not change modes. Can I reset it so that it will work again?
The flood protection device has activated. This is caused by a leak in the machine. It can also be caused if you are not careful when checking the drain pump,water may have gone back into appliance and activated flood protection device. If this is the case Tip machine forward,water in base of appliance will run out, and appliance will work. If Fault reoccurs then you have a leak.
May 17, 2010 | Miele W1203
What do you do if the Miele washing machine's check drain and inlet light is on?
Feb 15, 2010 | Miele Novotronic Premier 500 Front Load...
Washing Machines Logo
196 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
