Question about Sony Cyber-Shot DSC-P10 Digital Camera
Format error I've had my DSC-P10 on the charger and had no problem until today. Took it off charge and turned on. I get the flashing battery symbol and flashing C:13:01 and FORMAT ERROR. I suspect a bad battery but want opinions before I get one. Was told I couldn't get these batteries anymore. is that true? Sony model NP-FC11
  • minikperi199 Apr 18, 2009
    I was where I dropped my camera. Sonyr DSC-P10. I want to look at the photos inside the camera when I want to take photos and video when you want to save FORMAT ERROR when I was writing. c: 13:01 flashing article is also out. Is starting to sound. My Yad? In case of emergency: (
  • 22 Answers
Check your battery connector or terminal & clean if necessary, check also your memory stick connectivity. It may be caused by no connectivity with the memory stick... ^_^
Posted on Jan 16, 2008
Camileo p10 wont turn on or charge
I had a similar problem with the P10 not charging via USB, I purchased mine second hand so it came with no charger just a USB cable. I assumed it would charge by the USB cable but it did not, the red light flashes but doesn't charge. Luckily I have an external battery charger for a different camera i got some years ago that takes a similar battery , the P10 battery didn't fit properly so I had to place it at a 45 degree angle into the charger making sure the outer contacts were lined up properly and taped it into place. After an hour it was fully charged and the camera is working fine. The charger is a 4.2 volt charger. New external chargers can be picked up on ebay cheaply
Dec 18, 2012 | Toshiba Camileo P10 Flash Media Camcorder
Camileo P10 charging problem
I had the same problem with the P10 not charging via USB, I purchased mine second hand so it came with no charger. I assumed it would charge by the USB cable but it did not, the red light flashes but doesn't charge. Luckily I have an external battery charger for a different camera i got some years ago that takes a similar battery , the P10 battery didn't fit properly so I had to place it at a 45 degree angle into the charger making sure the outer contacts were lined up properly and taped it into place. After an hour it was fully charged and the camera is working fine. The charger is a 4.2 volt charger. New external chargers can be picked up on ebay cheaply
Jul 04, 2012 | Toshiba Camileo P10 Flash Media Camcorder
How to charge a Sony CyberShot DSC-p10 with a USB cable?
First make sure that your USB cable is compatible to your camera, such as the standard of the cable configuration.Then connect to your camera and the charger with the cable,if there's no problem.You can charge it now.
However, if you are outside and want to charge for your camera, why not have a try charge for it with a mobile power?
Jun 11, 2012 | Sony Cyber-Shot DSC-P10 Digital Camera
Hi! I try to turn on my Iphone 3gs, but it wont. I put it to charge and the charging symbol came up, then it disappeared. Then I took the charger out, and then it's blinking for more batteri. I...
Press and hold the Home button and the Power button for about 30 seconds until you see the Apple logo, then let go. It should power on. If not, plug in to your computer and perform a Restore from iTunes.
May 17, 2011 | Apple iPhone 3G
My battery will not charge. I purchased a new
The flashing on a charger usually means that the battery is defective or will not take a charge. I would take the battery back to the vendor and have them check it. A good indication is that if your old battery took even a small charge, it is not usually the charger that is the problem. It points to the new battery being faulty.
Jan 12, 2010 | Sony Cyber-shot DSC-T100 Digital Camera
No sign of phone charging
I finally have spoken to a very nice youn guy from Sonim Tech Support. He fixed my problem of the phone not turning on.
1. Take out the battery, plug in the mains charger and leave for a few minutes (they say 10 but it took my phone a couple of hours).
2. Eventually the charging symbol will come on the screen, either stady or flashing.
3. Immediately put the battery in the carcass (while it is still connected to the charger), and the charging symbol should stay on.
4. Leave the phone for a couple of hours, disconnect the charger, and the phone should turn on as normal.
This was explained to me, the reason for not turning on was that the software had crashed. This solved it.
Sep 01, 2009 | Sendo Sonim XP1 JCB phone extreme...
I am trying to charge the battery. The charger is flashing a red light and the battery won't seem to charge. Placed it in the camera just in case, and it won't turn on.
Well, with my Nikon, the light flashes to show the battery is charging. It stays on when it's charged. My battery and spare battery are 2 years old and working fine. I'd say wait till it stops flashing...hour or 2 in my case, though I never let them run down all the way.
Jun 28, 2009 | Cameras
Flashing battery symbol
I had this same problem today.  I called Honeywell and they said the flashing broken battery symbol may mean low batteries, or it may mean the battery type is incorrect.  They recommend only non-rechargeable alkaline batteries.  I was using rechargeable NiMH batteries.  Even though they were fully charged, I had the flashing battery symbol and the thermostat relay would not work.  I replaced with alkaline, the flashing battery indicator went out, the thermostat works again.
Odd that it worked for 3 months on the rechargeables after first install. I did notice the broken battery symbol came on after the first few days, but I checked the battery charges and they were good, so I disregarded the symbol until the thermostat stopped working today.  Apparently there is something about the NiMH performance characteristic that the thermostat doesn't like.
Jan 31, 2009 | Honeywell Programmable Thermostat Heater
Sony DSC-P10
C:13:01 error code means memory stick/ card is unformatted or broken memory stick/ card. please format memory stick/ card, this option is available in camera menu and try again.
If problem still there, use another memory stick/ card.
May 30, 2008 | Sony Cyber-Shot DSC-P10 Digital Camera
Format Error C:13:01 on Sony DSC-W7
Please try with the new memory stick. Regards, Arpi
Mar 26, 2007 | Sony Cyber-Shot DSC-W7 Digital Camera
Sony Cyber-Shot DSC-P10 Digital Camera Logo
131 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
