Re: 2001 aztec.The fan control quit working over the past...
Sounds like you need a blower resistor it is under the dash on the passenger side and really easy to change, just has like two 7mm screws holding it in.
please help aztek keeps overheating i cant find thermostat need diagram and my blower fan is not working Please Help Rosemary [email protected]please help aztek keeps overheating i cant find thermostat need diagram and my blower fan is not working Please Help Rosemary [email protected]
You can't post conmments that contain an email address.
The engine cooling fan system consists of 2 electrical cooling fans and 3 fan relays. The relays are arranged in a series/parallel configuration that allows the powertrain control module (PCM) to operate both fans together at low or high speeds. The cooling fans and fan relays receive battery positive voltage from the underhood fuse block.
During low speed operation, the PCM supplies the ground path for the low speed fan relay through the low speed cooling fan relay control circuit. This energizes the low speed fan relay coil, closes the relay contacts, and supplies battery positive voltage from the low fan fuse through the cooling fan motor supply voltage circuit to the left cooling fan. The ground path for the left cooling fan is through the cooling fan s/p relay and the right cooling fan. The result is a series circuit with both fans running at low speed.
During high speed operation the PCM supplies the ground path for the low speed fan relay through the low speed cooling fan relay control circuit. After a 3 second delay, the PCM supplies a ground path for the high speed fan relay and the cooling fan s/p relay through the high speed cooling fan relay control circuit. This energizes the cooling fan s/p relay coil, closes the relay contacts, and provides a ground path for the left cooling fan. At the same time the high speed fan relay coil is energized closing the relay contacts and provides battery positive voltage from the high fan fuse on the cooling fan motor supply voltage circuit to the right cooling fan. During high speed fan operation, both engine cooling fans have there own ground path. The result is a parallel circuit with both fans running at high speed.
Your best bet would be to take your vehicle to a qualified repair shop ! Relay Driven Dual Cooling Fan Diagnostics
Sounds like low speed coil in the Blower Fan resistor block has failed. The Blower Fan Resistor Block is usually located in the air ducting adjacent to the Blower Fan. The Resistor Block consists of 3 or 4 coils of special resistance wire attached to terminals which connect to the wiring that comes from the fan switch and then to the Blower Fan. The block is on the output side of the fan unit so that the airflow from the fan past the coils inside the duct assists in preventing them from overheating and burning out. Access to the Resistor Block is from under the dash. To replace, remove the multi-pin connector and then undo the screws holding in the block. Check air duct for leaves and dirt which may have caused the coils to fail. .Replacement is the reverse procedure
There is not one,it has a blower resister that e\includes the low,med.and if there is one a med-high it is a module,and it has multi wires going to it,and is mounted on the blower box near the blower motor.
When a blower motor does not turn on in low or med. and only turns on high its usally a resistor block. If nothing works it is most likely the bolwer motor itself or a fuse.
Its the Blower Resistor....If it was the switch, it probably wouldn't work at all....But the Resistor will give you those symptoms, of working on high med or low
Disconnect the wire from the fan, turn the car on, test the voltage between the connector to ground (chasis) on all fan speed settings (high,med,low). If you have voltage at all settings (approx. 12.3V on high and less as the speed setting is lower) then replace the fan motor (about $50 at autozone). If there is not voltage on all speed settings you will also need to replace the blower motor resistor (about $12 at autozone). The whole process takes about 20 mins.
