Question about Epson Stylus Pro 9600 InkJet Printer
No ink cartridge message
I get a "no ink cartridge" message when i replaced the light magenta cartridge with a new one.
  • 1 more comment
  • downtownrick Jan 14, 2008
    it is a recently purchased epson ink cartridge.
    the printer will not continue to set up beyond the "no ink cartridge" stage
    i am going to get a long q-tip to reach in to clean the contact points for the cartridge chip & i will let you know of my results
  • 4,102 Answers
You could also try holding doen on off button for 5 seconds this should reset the printer do this whilst the new ink cartridge in and see if this solves your problem if not then follow darklord1 sollution as this can be the only other problem you are having make sure there is no dust or ink stopping the contacts from contacting check also that it is fitted correct as it might not be seated in the slot properly if your old cratridge is accepted than the chances are the new one is faulty so take it back and get refund and exchange if poss if you know the old one works then you know the new one is faulty let us know how you get on also remember to try reseting as this an cure your problem
Posted on Jan 14, 2008
    President:
  • 1,944 Answers
Try cleaning the contacts like DARKLORD1 said. I would also try applying a bit of pressure when reinstalling the cartridge. Are you able to print despite the no ink cartridge error message?
  • Damen Wong
    Damen Wong Jan 14, 2008
    Keep us updated after your cleaning.
  • Damen Wong
    If you want you can try to reset the printer.
  • Turn off printer
  • Hold PAPER SOURCE+PAPER FEED+CUT/EJECT buttons at the same time and keep them pressed
  • Turn on printer
  • Release buttons
  • Hidden new menu appears
  • press DOWN, "CLEAR COUNTERS" option should appear
  • press RIGHT
  • press UP, "MAINT TANK" should appear
  • press RIGHT
  • press ENTER (CUT/EJECT button)
  • Turn off printer.
    Genius:
  • 1,601 Answers
Make sure that it is installed correctly. Also, if its not an new original Epson, it will not register. The manufacturers like to sell their new ones.
  • 2 more comments
  • Thomas Christopher
    Thomas Christopher Jan 14, 2008
    Which ink are you using Photographic or ultrachrome?
    Did you buy the right type ink cartridge for your printer?
    Photographic or ultrachrome.
    Along with the message, are there any light on, or blinking?
    If you are using EPSON UltraChrome type ink cartridges, shake the ink cartridge gently before installing it for best results.
  • 2,427 Answers
Hey , try cleaning the contacts on the cartridhe and in the ink well, use a soft cotten cloth and some alcohol or menthylated spirit..
If the cartridge you broght is a compatable or generic cartridge, and not the original, IT WILL NOT BE RECGONISED BY YOUR PRINTER... ACTUALLY ALL PRINTER MADE AFTER 2006 unless if its hacked..
Reinsert your old cartridge and see if it reads it, if it does, EIGHTER YOUR NEW CARTRIDGE IN NOT ORIGINAL OR ITS DEFECTIVE..
  • 2 more comments
  • Rishi Roshan Ali Jan 14, 2008
    just cause its a new cartridge doesnt mean its AN ORIGINAL cartridge or its good,, some resellers try to palm off generic as new, try your old cartridge and see if it recgonises it if it does it means that your "NEW" cartridge is generic(FAKE) or it isnt good .. Just give it a try and tell me what happens
    AND TO RESET PRINTER
    1.) remove the power cabe,
    2.) hold down the power button and put in the power cable,
    3.) WHILE STILL HOLDING THE POWER PUTTON
    press the paper feed button
    4.) press paper feed again
    5.)release power button..
    personallyi believe that the cartridge you brought is a generic or is defective (I'll bet on generic) get it changed
  • Rishi Roshan Ali Jan 15, 2008
    Hey how is the problem coming along, do u jneed further assistance or has one of the experts solution helped
  • Rishi Roshan Ali Jan 18, 2008
    Hey Any luck ?
Printer reports out of Light Magenta ink even after new cartridge installed.
discovered recently that printer cartridges have a use by date on them, and that if you use it the printer will not recognise it, only answer is to insert a new one, or ignore the printer ( l have a by-pass function on mine so still use it until l am ready to replace the offending cartridge
Jan 30, 2013 | Epson Stylus Pro 9900 - 44" large-format -...
I have a canon IP 4200 printer. The ink cartridge light on the Magenta ink cartridge doesn't work so it won't accept/recognize that a new ink cartridge has been installed. Is this something that...
It sounds as though you have a break in the carriage ribbon cable. A new carriage would hopefully cure it but its just possible the logic board has failed and is not sending any signal to the magenta ink tank. Its certainly repairable but you would need to know the costs and the labour charge to see if its worthwhile.
Aug 27, 2011 | Canon PIXMA iP4200 InkJet Photo Printer
Error message - "some ink
All the ink tanks should be red with no flashing.
The tanks that are flashing or have no red light on , need to be replaced.
Feb 14, 2011 | Office Equipment & Supplies
"wrong cartridge"- Printer is giving us a "wrong
Hi Sherri
I am having the same problem with my MP780 mine started doing the same thingafter deciding to use Calidad inks the large black ink leaked into the yellowink (stick to canon inks).
What I have done so far with no success -
Replaced the ink cartridges with new ones supplied by Calidad, still the sameproblem.
Removed and cleaned the print heads manually and to my surprize after soakingin warm water and multiple cleanings for over 1hr black ink is still coming outof the yellow ink head.
I still get the same message after all I have tried...
One thing I did manage to do is prime the yellow ink and got it flowing throughthe head again but it's still mixed with black... I wonder if you may have runout of magenta and dried the head...
Try priming the magenta ink by removing the head (don't touch or wet the metalcontacts at the rear, the ink heads are on the bottom) place on a clean lintfree cloth (or I just used damp tissues then dry tissues) you should get onelong black strip and two cyan, two magenta and two yellow strips on the tissue,if you do not then try priming by replacing the magenta cartridge and gentlypumping the cartridge up and down repeat until you get the ink flowing.
Replace the head and cartridges, press ok, turn the printer off then reset.
Let me know if it works or if you come up with another solution that works as Iam still trying to figure out how to fix mine.
Good luck
Dec 21, 2010 | Canon PIXMA MP780 All-In-One InkJet...
I replaced an ink cartridge because the printer stopped working and showed a message that the old cartridge is empty. However after putting the new one in but the printer still refuses to work and shows...
maybe the cartridge is wrong, release it and clean the electrical contacts, put them again one by one, if notting happen, try this
Solution As the printer operates, it moves ink from the ink cartridges into a printhead reservoir. The printer does not deliver a message when an ink cartridge goes empty, because it still has ink in the reservoir. The printer continues printing until the ink level in the reservoir falls to a first trigger point - then a message appears advising the printer owner to Replace Cartridges Soon . At this point, other cartridges that are empty but have not reached the trigger point are also mentioned in the message, to save trips to the retailer. After the first trigger point, the printer can continue printing until ink levels in the reservoir reach a second trigger point. At the second trigger point there is only enough ink left to perform vital servicing tasks, and a new message appears, saying Ink Cartridges Empty . The options offered depend on the usable inks remaining. If no options are offered, the cartridges indicated must be replaced before printing can continue. The Ink Cartridges Empty options are described in the table below: Ink colors out Option Print mode possible All Cancel None Black
AND
Cyan, Magenta, or Yellow (any or all) Black only Continue with other colors Cyan/Magenta/Yellow mode (composite black)
Text and photo quality will differ from those printed when all colors are available Light Cyan or Light Magenta (either or both) Cyan, Magenta, or Yellow (any or all)
(Black still available) Print with black ink only Grayscale
Apr 07, 2010 | HP Photosmart 3210 Printer
Error message after replacing black ink cartridge
This happened to me twice, You can possibly have no ink in your cyan,magenta and yellow , you would then have to replace them to work the set. I had to do that and it worked =]
Jul 18, 2009 | Epson Stylus NX400 InkJet Printer
Wont print with all new ink cartridges
If the error message is only "magenta/cyan low", it doesn't cause any error. The low message stays after replacing ink cartridges if they're replaced too early (before they're indicated as actually empty), it doesn't cause the printer to not work.
However, some other problem might be faulty, or there might be another error message. Try emptying printer queue and print from Ink Management -> Menu/set (twice) to check wether the problem is with communication from pc or if the printer actually is unable to print.
May 29, 2009 | Brother MFC 210C All-In-One InkJet Printer
I recently replaced the magenta cartridge in my HP 3210 Photosmart printer because the light indicated it needed to be replaced. However, the printer still won't print, and the message still says that I...
If you turned the machine off and replaced the cartridge, you can get this error.
Could you try the following procedure below please to clear the error, thanks.
  1. Turn on the unit.
  2. Open the top cover to access the print cartridges.
  3. Remove the new cartridge that is causing the message.
  4. Reinsert the cartridge and close the cover. The following message will appear on the front panel: "Press 1 for new cartridge or press 2 for a used cartridge."
  5. Press the 1 on the numeric keypad of the HP product.
If the message, press 1 for new cartridge or press 2 for a used cartridge, "does not appear after removing and reinstalling the new cartridge, and the low ink warning message still displays,
follow the steps below:
  2. Open the top cover to access the ink cartridges.
  3. After the cartridges stop moving, unplug the power cord.
  4. Remove both cartridges and close the top cover.
  5. Plug the power back in. The unit will reinitialize and a message will appear to insert the cartridges.
  6. Open the top cover and reinsert the ink cartridges. Close the top cover. The message,
  7. Press 1 for new cartridge or press 2 for a used cartridge," should appear.
Hope this helps
Regards.
Apr 18, 2009 | HP Photosmart 3310 Printer
HP Officejet d145 print head problem
Did you replace the PRINTHEAD, or did you replace the INK CARTRIDGE? They are not the same on the D145.
Good chance that you may have replaced the ink cartridge, not the magenta PRINTHEAD which sits under the ink cartridge.
PS - in my experience, non-HP ink cartridges clog up HP printers with separate printhead mechanisms... any possibility here?
Jul 26, 2008 | HP OfficeJet d145 InkJet Printer
Canon Pixma MP530
I am in the same situation. When 'Check Ink' comes up, the yellow cartridge blinks.  If I take it out and put it back again, the printer will work.  Then after a while on idle mode, the problem will show up again.  Pretty annoying.
WF
Sep 27, 2007 | Canon PIXMA MP530 All-In-One InkJet...
Epson Stylus Pro 9600 InkJet Printer Logo
70 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
