Question about Epson AcuLaser C900 Printer
Epson Aculaser C900 - Paper Jam Notice, but no Jam?
HI,
I´m having a problem with my C900 Aculaser. When i want to print, the printer stops ejection to early (about 3,5cm) of A4 paper size. Then he always says "Paper jam, open AB". When i manually trie to take the paper out, he also says Paper Jam.
Can anybody help me?
thanks,
mike
  • 2 more comments
  • burnok100 Jan 24, 2008
    Guys,
    I have the same problem with my C900.
    Before that, I replaced the photo conductor unit, installed it, and my printing was in a mess. The printing page starts around 3 inches from the top edge of the paper, and the printer always displays "Paper JAM"... the printer always displays this message. I need to pull the paper out from the tray to get it. The spooling starts late... (i think)
    Then here's where i lost it... I can print texts in color, but the Black texts never prints.??? I tried printing texts in color, and it is ok. Pictures are really BAD. I tried removing the back side panel (the "AB" door) , and i can see that the rollers did absorbs the black texts..
    I do not know where's the problem.. Hardware perhaps?.. i only replaced the photoconductor unit.. The Epson service people is also not much help.
    Can anybody help..? Thanks !!
  • Anonymous Feb 19, 2009
    This is not the solution
  • Trevor001 Apr 08, 2009
    Hi
    I have basically the same problem the only differrence is that a black page prints fine, and gets ejected, while if I try to print colour it is very faint and the last 20 to 30 mm of the page stays in the printer and I get a paper jam error.
    thanks
    Trevor
  • Anonymous Apr 30, 2009
    I have exactly the same problem. Sometimes it will print 3 or 4 pages and then it jams for the last 3 or 4 inches an I have to pull it out. Can anyone help? Please.!!!!!
  • 734 Answers
Step1
Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
Step
Turn off the printer.
Step
Remove any paper trays. Inspect them for wrinkled or damaged paper.
Step
Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
Step
5
If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
Step
6
If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly (see A). The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
Step
7
If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though.
Step
8
Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
Step
9
If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
Posted on Dec 04, 2008
Problem printing multiple copies of a single page document
I have a similar problem with an old HP LJ1300. They have not updated the driver correctly and don't intend to fix it. I can't find any reference to AcuLaser C900 on Epson's support page. So maybe they stopped supporting the C900.
May 06, 2010 | Epson AcuLaser C900 Printer
Hullo I have a c900 aculaser, printing fine and now on all colour images, there is no image just block of colour and a series of broken repetitive lines. Help! Christine Willis tel 01803 866577
Unplug your printer power cable, restart your computer and plug the printer cable back and on it and tryt to print. this may help. thank. let me know if it works
Jul 02, 2009 | Epson AcuLaser C900 Printer
Papr Jams and wrong size report
We just solved this problem with our c900.
Basically, a paper jam has caused some probs with the sensors and rollers. After playing with the thing for about 4 hours, i ran some really thick photo paper through it and after a couple of trys where it just screwed up in the back, it then fed through and printed correctly. After that it was fine with all paper types, no more messages, and no more paper getting screwed up in the back. Ian
Jun 19, 2009 | Epson AcuLaser C900 Printer
Noisy printer
yha u have to change taplone tap on rollers.it is broken so create noise.
Mar 25, 2009 | Epson AcuLaser C900 Printer
Epson AculaserC900
I did much the same and am looking to see if there is a solution here! Tried cleaning the glass filter, which pulls out about 250mm and is located just below the transfer unit - small grey tab, behind waste collector. It helped, but still a slight white band on the print.
Oct 22, 2007 | Epson AcuLaser C900 Printer
Epson C900 print shifted down page -
OK after messing about with the drivers I got it to work. I downloaded a driver from Epson singapore and it made no difference. So, I re used the driver from Epson UK and hey presto the thing works again. Why? Good question. Maybe the people in Epson have no idea either.
So, I suggest deleting the driver rebooting the system and reinstalling it. I hope you get it working.
Oct 08, 2007 | Epson AcuLaser C900 Printer
Error Code 6001 ~ 6999 are simply service required errors and are very general. I would imagine that if the tray is missing the printer will produce a fault. For starters it will think it has no paper and therefore will not try to pick up paper from the tray. If the tray is opened during operation I believe the printer stops, therefore there must be a sensor for the tray - no tray means sensor is operated. Best guess - fit a tray.
Apr 07, 2007 | Epson AcuLaser C900 Printer
Epson AcuLaser C900 Printer Logo
1,490 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
