Green light flashing
We set the timer to turn our tv off and after it did we can't get the tv back on.... the green light just flashes for @ 15 mins.
  • amanda9 Jan 14, 2008
    It's a Mitsubishi WS-73513 73"
  • amanda9 Jan 15, 2008
    well unfortunatley I don't. soooooo I guess I'll have to get someone over here to fix it I wish that I did I'd rather fix things in my house than have a repair person come in to..... thanks for the help! do you know @ how much money there going to charge me to do something like that? if not that's fine, I'm glad you told me what you did.
  • 8,617 Answers
What model set do you have? Is this a Mitsubishi?
Posted on Jan 14, 2008
  • Sonny Berry
    Sonny Berry Jan 14, 2008
    You have (4) 1000uf capacitors that need replacing on the DM board. Its a fairly easy repair if you can solder.
  • Sonny Berry
    Sonny Berry Jan 15, 2008
    Sad to say, They are probaly going to charge between 4 and 600.00. They will no doubt tell you that you need a new DM board about 400 plus the labor and diagnosis. Truthfully its only about 3.00 at radio Shack for the capacitors. Sorry If you could solder I would be more than happy to explain the entire proceedure to you.
6ya staff
SOURCE:
Sound goes off after 15 Min
Assuming it is not hardware but soft settings...
1) Check and make sure that your TV does not have the timer set.
The Timer feature allows you to set a day and time for the TV to turn on automatically and the device and channel to display when it switches on. If the TV is already on at the requested time, the TV automatically tunes to the channel you designated in the Timer menu.
When the Timer turns on the TV, the following message is displayed: "Press a button for the TV to stay on." Press any button on the remote control within five minutes if you wish the TV to remain on.
Note: The TV clock must be set before you can use the
Timer feature (see preceding page to set the clock).
On/Off
Press down arrow / up arrow to enable or disable the Timer.
2) If not working, try SYSTEM RESET. Press SYSTEM RESET button on the front panel with pointed object (e.g. straight paperclip). TV turns off, green LED flashes for about 1 minute. When it stops flashing turn the TV on again. All settings other than Parental Lock need to be set again using the manual.
3) TV RESET. If all else fails for soft error. Your manual describes this last resort for soft type error. It could be hardware problem needing more expertise.
Manual can be viewed on a computer at
http://www.audiolabga.com/pdf/V32-V32L_Service_Manual.pdf
Aug 05, 2014 | Mitsubishi WD-62531 Projection Television
Green light flashing won't turn on
Likely has bad 1000UF capacitors on DM module. this will prevent rebooting.
Apr 08, 2014 | Mitsubishi WS-65611 65" Rear Projection...
On/off green light flashes. Picture comes on for
the timer is set for a short time, try to get to the menu quick and turn off the timer it may take several tries.
Mar 06, 2010 | Televison & Video
I turned on the TV but just got a black screen but could hear audio just fine. Turned the set off and unplugged it. When I plugged it back in the green timer light started flashing and would not stop...
Nonstop blinking is likely a DM or format board - format board most likely. I have rebuilt several of these by simply replacing all the caps, about 70 of them, and takes about two hours start to finish... But this set does need to boot. It takes about 70 seconds of flashing green light before you're able to press the power button - even when everthing is working as it should..
Hope this helps!
Bill
William Rayburn, CET
Premium Technologies
PO Box 442
Long Beach, WA. 98631
360-642-4993
Aug 22, 2009 | Mitsubishi WD-52525 52" Rear Projection...
My tv won't turn on, the timer keeps flashing
http://www.jyerdon.com/tv/
If it`s a 65513 mitsu, this will fix the flashing green light, most of the time, e-mail me with any questions, good luck
[email protected]
Dec 28, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Timer in auto start.
if it is the 2000 rs the manual can be downloaded from scytek.net
1. Turn on ignition.
2. Within 5 seconds, press the valet switch 5 times.
· The parking lights will provide three blinks, indicating that you have entered Programming.
3. Press the valet switch 12 times (engine run time)
· The parking lights will flash each time the valet switch is pressed.
4. Within 5 seconds, press the transmitter button corresponding to the desired time ( left button 15 min, right button 25 min)
· The parking lights will flash to indicate the setting.
1 flash = 15 min
2 flashes = 25 min
5. When you are finished, turn off the ignition to save the changes.
all of this is based on that it is the galaxy 2000rs m,
Nov 19, 2008 | Scytek 2000RS-M Remote Control
Mitsubishi wd52527
does the light flash for 1 min then pause for a second then blink for another min?
Oct 18, 2008 | Mitsubishi WD52527 52" Projection HDTV
Tv cuts off and green light flashes
If your set was manufactured around July 2005, you may need a firmware upgrade to solve this issue. On the Sony website you can enter your model # and serial # to see if you TV is affected. If so, it is easy to have done and may be free from Sony. It sounds like the issue they described in the writeup on the required formware update. I had mine done within few months of when i bought it (purchased in Dec 2005) and it has been working flawlessly since.
Donnieboy999
Jul 19, 2008 | Sony KDF-E42A10 42 in. LCD Television
Assistant
is this electricity pocket plugged up to a timer ? or take the tv back to the shop... lost the receit just look for the same tv on computer
Feb 20, 2008 | Toshiba 28N33 28" TV
No picture for 15 mins
Dont know if its the same model but Ive seen a few with a cold solder joint on a switching relay in the Vertical circuit do this.. (Be careful if its a CRT TV.. 27.5KV is common off the flyback transformer).. 27,500 Volts.. Good luck!
Jan 29, 2008 | Philips Magnavox 27MS343S 27" TV
Televison & Video Logo
172 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
