Question about Mitsubishi VS-6041 60" Rear Projection Television
Cleaning the screen
Hi I do not have the cleaner they gave us for this t.v. is it ok to use a natural cleaner with parsley in it?
    President:
  • 4,402 Answers
TV: Viewing Screen RPTV - damage and maintenance
http://www.hdtvmagazine.com/forum/viewtopic.php?t=6547
Posted on Jan 14, 2008
Everything works except the view finder. Both through the eye piece or the display screen,
hi,
If EVF and LCD screen not giving picture, check the change over switch inside the monitor hinges clean it with contact cleaner spray, if it is OK, open and check the circuit on the mother board,
Feb 28, 2016 | Canon ZR40 Mini DV Digital Camcorder
If I get a dirty mark or a coffee stain, a splash of anything even a nicotine stain on my laptop screen, do I use a chemical to clean my screen? If so, what?
There are many types of electronics cleaners available. However, you should be careful as some that are ammonia or alcohol-based could cause damage to your LCD screen. I recommend a product called "Whoosh" which is made of all-natural ingredients. It cleans your screen without the risk of damaging it. Here's the manufacturer's website: http://www.whooshinc.com/products/106-quick-screen-cleaner.aspx
Mar 17, 2013 | Acer Aspire Computers & Internet
How do i clean the screen
Hi to clean your screen you must use a good screen cleaner and cloth that comes with it you can buy the cleaner from most tv shops or pound land is the cheapest and does the job do not use window cleaner and a dust cloth it damages the screen
Oct 16, 2011 | Philips Televison & Video
Hi i just bought a 32inch lg plasma tv and just wonderin whats the best way to clean your tv without causein any damage please get in touch thanks
Well first off, Id like to appreciate the fact that you are asking instead of just applying windex. Ugh. Best product to use without having to buy anything is a coffee filter. This takes off all the dust. You can use a regular duster on The back to keep it from building up and overheating, as plasmas naturally emit more heat. You can also go to any electronics store like best buy or radioshack and they should be able to sell you a tv screen cleaner. but never use chemicals directly on your screen. Occasionally using windex on a SOFT paper towel and then rubbing on your screen is ok if you have something sticky on it...but dont apply directly to screen. No Liquid of any kind should ever directly touch your screen. Windex dries quickly and therefore is safe sparingly. Notevery day.
Hope this helped! Please take a moment to rate :] Thanks
May 05, 2011 | Televison & Video
Stuffed parsley into the juicer and the motor stopped
Push red reset button on bottom of juicer. The
juicer is not designed for leafy produce, only
apples, carrots, celery, etc.
Apr 22, 2010 | Acme 6001 Juice Extractor
Hi i have aburning smell coming from the machine but the machine works ok
Be sure the lint filter is clean, and the temp sensor blown clean. Sometimes when cleaning the lint filter the some small amount of lint drops by the filter or screen and land on a hot spot. Lint can catch fire so clean with a air hose or vacuum cleaner - Good luck and be safe
Oct 16, 2009 | Hotpoint Aquarius WF220 Front Load Washer
Chain
Yes All motorcycle chains currently being manufactured use Buna-N (Nitrile) rubber for their o-rings and x-rings and all these manufacturers recommend kerosene as a cleaner. Here's the formulation of WD-40: 80% Stoddard Solvent (that is similar to kerosene) 20% light lubricating oil and a bit of fragrance. Here's the compatibility of Stoddard Solvent with rubbers and plastics: Good Compatibility (OK for both static and dynamic seals) Buna-N (Nitrile) Chemraz Epichlorohydrin Fluorocarbon Fluorosilicone Kalrez Nitrile, hydrogenated Polyacrylate Teflon, virgin Mixed Compatibility (OK for static seals, but not for dynamic seals) Neoprene Vamac Fair Compatibility (OK for some static seals) Polysulfide Polyurethane, millable Poor Compatibility Butyl Ethylene-Propylene Hypalon Natural rubber Silicone Styrene Butadiene Consequently, WD-40 is safe and effective as a chain cleaner and corrosion inhibitor. Link: http://www.efunda.com/designstandard...dard%20Solvent If you clean with a soft brush and WD-40, and plan to follow-up with a chain lube, you can reduce chain lube sling-off if you first remove the oil residue that WD-40 leaves. This residue seems to prevent some chain lube formulations from sticking well to the chain.,,,
Nov 10, 2008 | 2005 Derbi GPR 125 Racing
Televison & Video Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
