Question about HP Pavilion dv6000z Notebook
Altec Lansing speakers in laptop
The sound quit on the laptop (it's above the function keys, says Altec Lansing), but when external speakers or earphones are hooked up, the sound is there. HP's troubleshooting steps indicate that the appropriate systems are working fine--checked to make sure there is no mute box checked as well. Any suggestions would be greatly appreciated, thx.
  • 1 more comment
  • HP Pavilion Jan 14, 2008
    Thanks guys, sure appreciate the advice.
  • HP Pavilion Jan 18, 2008
    Thanks for your additional comment ikenfixit, headphones work.
  • chanderb2001 Dec 28, 2008
    I am having HP Pavillion dv6000 series laptop. The Altec Lansing speakers (in built speakers) that are just above the function keys are not working. There is no sound coming from the speakers but if I connect external headphones or external speakers then they are working fine. I tried restarting the laptop but the problem still persists. It seems there could be a problem with the Speaker itself or coonecting cable connecting the speaker with motherboard. Can anyone please help me?
  • 89 Answers
It seems as though the speakers wire connector may have become loose or disconnected. You will have to remove the switch cover above the Keyboard to check. Here is the typical instructions for removing it:
Before you begin any removal or installation procedures:
1. Shut down the computer. If you are unsure whether the computer is off or in hibernation, turn the computer on, and then shut it down through the operating system.
2. Disconnect all external devices connected to the computer.
3. Disconnect the power cord.
4. Remove the battery by following these steps:
a. Turn the computer upside down with the front panel
toward you.
Close the computer.
3. Turn the computer upside down with the front panel
toward you.
4. Remove the three Phillips PM2.5×5.0 screws that secure
the switch cover to the computer.
5. Turn the computer display-side up with the front toward you.
6. Open the computer as far as possible.
7. Lift the rear edge of the switch cover and swing it forward
until it rests on the keyboard.
8. Release the zero insertion force (ZIF) connector 1 to which
the LED board cable is connected and disconnect the cable 2
from the LED board.
9. Remove the switch cover.
Remove the Keyboard:
Remove the four Phillips PM2.5×7.0 screws that secure the keyboard to the computer.
Turn the computer display-side up with the front panel
toward you.
5. Open the computer as far as possible.
6. Lift the rear edge of the keyboard 1 until it rests at an angle.
7. Slide the keyboard 2 back to disengage the tabs on the front
edge of the keyboard from the top cover.
8. Swing the keyboard 3 forward until it rests on the palm rest.
Release the ZIF connector 1 to which the keyboard cable is connected and disconnect the keyboard cable 2 from the system board.
10. Remove the keyboard.
Remove the Speaker Assembly:
Disconnect the speaker assembly cable 1 from the power button board.
5. Remove the two Phillips PM2.5×4.0 screws 2 that secure the speaker assembly to the computer.
6. Remove the speaker assembly 3.
Reverse directions to replace everything.
Posted on Jan 14, 2008
  • 163 Answers
The NC (Normally Closed) contact in the headphone jack could not be making contact.. Or it could be a bad solder joint on the port as well. Most likely will have to change the port itself if the plates bent internally.
  • Ken LaDere Jan 17, 2008
    Did you try on headphones? It may work.. I doubt very much its the speaker wires coming disconnected from the systemboard. If headphones do not work look to the Modem/Sound chip. Its replaceable if you have the components and equipment..
    You're welcome also..
External subwoofer doesnt play any sound
Are you plugging the sub into a 3.5mm jack or USB?
Have you tried to plug the sub into the speaker jack?
The sub works on another computer?
Bad sub or bad jack?
I hope this helps!
Jan 22, 2013 | Dell Inspiron 1545 Notebook
My Altec Lansing AVS 300 external computer speakers quit working on my laptop. They work fine on another laptop. Please suggest a solution to get these speakers to work on my computer.
Check if the sound card is correctly setup with drivers.
Do this by going to Control Panel, Device Manager and check on sound cards.
Can you hear sounds from regular laptop speakers??
If not, the problem is in the sound card, which is already integrated on the motherboard.
This makes it harder to fix, unless your laptop is under warranty.
If it is software related to the OS or conflict with other devices, you are more likely to fix it.
God Bless You!
Feb 05, 2011 | Altec Lansing AVS 300 Computer Speakers
It seems as if everything is connected correctly, but I get no sound from my Altec Lansing speakers. What can I do?
buy your self a external sound card dude, the one on your laptop or pc is prob dead. problem solved..
Jul 27, 2010 | Altec Lansing VS2121 Computer Speakers
Power supply AVS500-A6860 fried
This one might work, but I'm not 100% sure on the connector:
Feb 16, 2009 | Altec Lansing AVS 500 Computer Speakers
Need a driver for the altec lansing 45.1
i'm guessing you have an audio output problem.
you might not have installed the sound card driver or your sound card is not functioning.
this speakers does not come with drivers... just plug in to speaker output which is the green one. turn the speaker on and walah!
Jul 31, 2008 | Altec Lansing ACS 45.1 Computer Speakers
Altec Lansing Altec AVS 500
If you are using windows media player check if your player is configured to have an echo. If it is configured remove it. If it is not configured to have an echo and if you are using any soundcard have that sound card check by an expert or by your vendor and let them check it out if it is still under warranty.
Jun 24, 2008 | Altec Lansing AVS 500 Computer Speakers
Altec lansing computer speakers
ok. write your pc model number. example=emachine t2080....... I will help you when you post it to this forum and to email to notify me.
Jun 12, 2008 | Edirol UA-4FX External Sound System
Altec lansing acs54 installation
Hello there!! jlee432
The 4.1 speakers you has, and output sound , depend on the sound card you has on your laptop. If you has inside the laptop a sound card 5.1 you whould not have problems get it sound, BUT you have to set on multimedia and sound for 4.1 according.
you only have one output sound on your laptop, so you have to use 2 speakers or buy a splitter and get 2 speakers sound.
you also, can buy a pcmcia sound card, 5.1 from creative labs, to solve this. but check if your speakers of course sound of.
good luck
Nov 29, 2007 | Altec Lansing ACS 56 Computer Speakers
One drive for Altec Lansing Technologies Inc. 'ACS-295' dell
Hello there
What kind of help on specific device from altec you need?
be more specific
Nov 28, 2007 | Altec Lansing ACS 295 Computer Speakers
HP Pavilion dv6000z Notebook Logo
2,593 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
