Question about Frigidaire GLTF2940ES Front Load Washer
Musty odor I have the gallery set stackable washer/dryer combo, it is just about 2 years old. The washer has a musty odor, it seems that water stays in the rubber gasket(?) around the door/drum. Is there something I can do to prevent this? I have not found a lint trap to clean. help gmd
  • 1 more comment
  • gmdunc Jan 17, 2008
    I found similiar advice of all places in the literature that came with the washer!
    where have I heard read the directions?
    thanks for confirming, since I have no little people living here, I am leaving the door open when I go to work. thanx
    gmd
  • Sherri Pacheco
    Sherri Pacheco Jan 18, 2008
    After one year of owning this washer the smell is terrible. The water settles in the rubber and and becomes mildew. If you do not clean out everytime your whites come out with dark lines on them from hitting the rubber upon removal.
  • JB83 Apr 05, 2008
    Same prob with Frigidaire Affinity front load...took old rag, soaked in bathtub cleaner with bleach, rubbed inside rubber seal just inside door, be sure to get in the grooves all the way around, poured liquid bleach directly into gap in rubber seal...ran hot wash cycle with just bleach where you add washing products...smell gone...talked to Lowe's, said leave door cracked, air dry rubber seal after each wash...problem exists everywhere...
    John, Lebanon, TN
  • 5,911 Answers
Unfortunately, this is a common problem with front load style washers. Now...if you pull the rubber boot back where it meets the wash tub there should be several small holes that allow any residual water to drain back into the wash tub. If these holes become clogged with lint and/or debris water will accumulate and mildew. The best advice I can give you when it comes to this type of washer is to become diligent about ensuring nothing gets caught in the the seam of the rubber boot. Routinely inspect this area after each wash for loose items like socks and underwear. In addition, clean this area periodically. What I often recommemd to people is to wait until you get ready to do a load of towels and wash cloths. Clean this area with a dirty towel or wash rag and throw it into the wash to be cleaned. This way you don't have to worry about having any old rags lying around. If you are not in the habit of using hot water settings you should also run a cleaning cycle about once a week on the hottest setting available. Pour a small amount of bleach into the soap dispenser and run the unit with nothing in it. This will help in killing any bacteria. Some of the newer models have now been equipped with a "Clean" cycle just for this purpose. Due to the design of these washers they become breeding grounds for mildew because the wash tubs are dark and if you leave the door closed when not in use it seals out any air that could allow the tub to dry out. When you are not using the washer leave the door slightly ajar to allow the tub to air out. I hope you find this information is helpful. Post back with comments and let me know if this works for you, or if I need to give you better advice.
Posted on Jan 14, 2008
I sell a natural washing machine cleaner that will also get rid of mildew smell from towels and clothing at www.smellywasher.com
Washing machine odor is not model specific but is noticed more in front load washers because of the lesser amount of water used. If detergent or
fabric softener is overused it will buildup on the inside of the outer tub and fungus will grow on it.
Smellywasher cleaner is used by adding 1 tbsp.
to a hot setting and allowing it to complete the cycle. For advice to remove more extreme odor
and more information on the problem go to the
BLOG page at smellywasher.com/ There is enough in one order for 24 cleanings and it has a money back guarantee if you're not satisfied!
Posted on Mar 09, 2008
I crunch several sheets of bounce and throw in the washer in bettwen uses and this seems to work well for me. Always leave the door ajar too.
Posted on Jan 27, 2008
I have a stackable Frigidaire washer/dryer combo and the problem is that when you push the start button, you hear an electrical buzzing but the dryer won't start. When you take the panel off it st
Hello Mike Brady - From what you have described it seems like the dryer is experiencing a wiring failure or a communication error with the control board. Contact a professional to move forward accurately.
Jan 08, 2013 | Frigidaire FEX831CS Top Load Stacked...
How to disable buzzer from frigidaire gallery series stackable washer/dryer?
Here is a site showing all of the steps to disable both buzzers on the Frigidaire Gallery series stackable washer/dryer.
http://www.scribd.com/doc/34420420/Buzzer-Disconnect-Frigid-a-Ire-Gallery
Nov 19, 2010 | Frigidaire GLEH1642DS Front Load Stacked...
Ge stackable washer dryer MODEL wsm2700wbwww
3 year old GE stackable washing machine, had water coming out the top and would not drain or go through cycle, when shut off it drained a little but when turned on again it filled up and over flowed.
Apr 18, 2010 | GE Spacemaker Washer and Dryer Electric...
Water under stackable washer dryer
The front panel comes off and you will be able to trace the water source. These combo units spin immediatly and if the drain is slow the water will spin up over the edge of the tub during drain.
Eric
Dec 24, 2009 | Kenmore 98702 Stacked Washer/Dryer
I have a Frigidaire Gallery Stackable that has a screechy dryer
Sounds like the bearing is gone, call a repiar man or buy new as repairman 100 per call
Sep 03, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
MY FRONT LOAD WASHER STINKS! THERE IS A MUSTY ODOR COMING FROM INSIDE.
Switch from liquid to powder detergent, no fabric softner (I know...I love it too), clean the gasket and run a cycle with bleach only. Leave the door open whenever possible. This fixed my smelly washer, now if it would only spin!
Jun 02, 2009 | Frigidaire ATF6000ES Front Load Washer
Musty odor in laundry
I would say that you are getting a build up of soap and oil from our bodies, on the inside of your wash bowl.
The Tubs pull out of the washing machine really easy and then you can water blast the two tubs.Solves this problem?
Once you learn how to pull the tub out you can also clear a blocked pump.
I have a after market lint filter fitted to my F&P washing machine,works wonders .
ask your local whiteware Man for some hints on a Bowl removal.
A five minute job???
Jul 27, 2008 | Fisher Paykel EcoSmart GWL15
Frigidaire Front Loader Won't Drain
if your washer is digital or with elecronic control board check the the motor control board located at the bottom difiniely you have to call a tech to confirm that. other model like wd5595 and wd 8095 has the same problem and it is the motor control unit that always fails.
Mar 21, 2008 | Frigidaire GLTF1670A Front Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
579 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
