Question about GE XL1800 1100 Watts Microwave Oven
Burned magnetron antenna
I have an XL1800 manufactured in 2004. About a year after we had it, during a cook cycle it would make a terrible, loud buzzing noise (like it was going to blow up) - like a shorting transformer. I replaced the magnetron and the same thing happens. I tested the diode (read inf in both directions with a fresh 9V battery in my multimeter) so I ordered another. However, this new diode from GE also reads inf in both directions - anyone have a solution for that one? But my main quetsion is that I noticed on both magnetrons that I pulled out, there is charring on the dome - or antenna (I assume that's what it is - the brass-colored portion that goes into the waveguide).
Is something more serious happening here than the magnetron simply shorting out? How could the dome get burned?!
Thanks a lot for any help.
I just purchased a replacement diode and wanted to test it before I installed it and found my meter didn't have the power either. I did some google searches and found that it is more common that if the diode fails it will be shorted and will have continuity in both directions. If you want to test a hv diode get a dc power supply between 12v and 15v ( I used a auto trickle charger ...but a dc wall adapter will work) . Connect a 1 watt resistor to the positive lead on the diode, then connect the pos side of the power supply to the other end of the resistor. Connect the negitive side of the power supply to the neg end of the diode. connect your meter to the diode pos and neg leads. This will determine proper behavior, at least at low voltages.
The following is the schematic of a simple HV diode tester:
240 ohms, 1 W
+ o-----------/\/\---------+------------o +
__|__ HV Good: 6 to 10 V
15 VDC _\_/_ diode Shorted: 0 to 2 V
| Open or reversed: 15 V
- o------------------------+------------o -
The voltage drop in the forward direction should be at least 6 V with a few
mA of current but may be somewhat higher (8 V or more) with a few hundred mA.
If your DMM or VOM has a resistance scale operated off a battery of at least
6 V, you may get a reading in one direction (but only one) without the need
for an external power supply.
Posted on Jan 02, 2009
  • GE Master
  • 9,098 Answers
The average multimeter does not output enough voltage to forward bias a high voltage diode, so it will seem to read open. This is normal.
It still may need a new high-voltage diode and stirrer, and the cavity may be affected.
GE had a campaign (but not a recall, mind you!) covering several models.
Details are in their bulletin at http://207.234.249.73/mwd/ge_mw_mag_kit_bulletin.pdf
The parts kit (that GE used to pay for) is part # WB27X10489 and is shown in the photo below.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Chances are GE won't cover any of this, but just in case you want to contact them, GE Customer Service is at http://www.geappliances.com/service_and_support/contact/
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jan 20, 2008
2 Suggested Answers
MicrowaveSvc
  • 9098 Answers
SOURCE: Buzzing noise and burned magnetron antenna
Seems you've posted on this several times, and I've answered them all, but I'll cover this one, too.
Even if your model is not on the list, the same problem can occur, requiring a kit. I just think the difference is that GE has stopped paying for the repairs.
XL1800 buzzes but heats
If the magnetron was making louder noises prior then replace the magnetron. While the cabinet is open make sure to look for burned wires, check the continuity of thermal cutoffs, and check the main circuit-board for burned traces or components. The relays in most electronics are known for arcing (spot welding) and staying in the wrong position. Tap them hard with the back end of a screwdriver.
You may have to replace the capacitor too. During all of this use safe electrical practices by having the power cord unplugged. The capacitor could still have a high charge on it so be careful.
May 11, 2013 | GE XL1800 1100 Watts Microwave Oven
Whirlpool Talent Microwave The microwave starts off ok, then during cooking its still turning & the light is on but its not cooking. It can go on like this for 8 or 9 minutes and then you hear a small...
That is the magnetron faulty. The oven stops cooking, as the magnetron lose contact, when the magnetron restart working you hear that loud bang, and it restart radiating.
Replace the magnetron.
You find parts here or here.
Oct 08, 2008 | Whirlpool Microwave Ovens
MICROWAVE IS NOT HEATING--EVERYTHING IS WORKS FINE
You may have to replace the capacitor as well. During all of this use safe electrical practices by having the power cord unplugged. The capacitor could still have a high charge on it so be careful.
Feb 02, 2013 | GE XL1800 1100 Watts Microwave Oven
I have a GE XL1800 that won't heat.
HI. Your symptoms are a strong indication Magnetron failure. This is the principal heating device, that is used to produce microwaves that , essentially, excite the water molecules in the food, thus, producing the heating effect. When this device fails, generally, the unit will run, but not heat. This device is very fragile, and can injure you if you are not qualified to handle this type of component. There is a High Voltage Capacitor, that is used to help provide the necessary current for optimal Magnetron operation. This capacitor must be discharged correctly. If not, you could risk serious injury, during the repair, if it is accidental touched.
The Magnetron is linked to a cut-off fuse. If the magnetron becomes unstable, this fuse will shut the device down. It is standard procedure to have this fuse test for continuity. If the fuse has blown, this will be the culprit. Replace the fuse. Now, if the fuse continues to show continuity, this will confirm that the Magnetron has failed. I would advise to inspect the Capacitor, and HV diode for visible burn marks, or swollen top(Cap).
Access can be ac hived to these parts by removing the outside cabinet screws. Once the screws are removed, the cover can be removed, as well. Once the cover is removed, the internal components will be exposed for testing, and visual inspections.
WARNING: IF YOU ARE NOT A QUALIFIED SERVICE TECH, THIS WILL NOT BE A NOVICE DO IT YOURSELF JOB. MICROWAVES ARE VERY DANGEROUS, AND CAN CAUSE SERIOUS INJURY. I RECOMMEND TO CALL FOR SERVICE, IF YOU ARE UNCOMFORTABLE WITH HANDLING THE CAPACITOR, OR MAGNETRON.
Mar 01, 2010 | GE XL1800 1100 Watts Microwave Oven
GE SPACEMAKER XL1800 MODEL: JVM1860BF001
MAGNETRON, 99% of the time with your complaint
Nov 20, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Magnetron tube has arced
REPLCE THE MAG TUBE AND ***
Feb 08, 2009 | LG Microwave Ovens
GE Spacemaker XL1800(JVM1850CF001) - Loud Humming noise
You either have a bad magnetron tube (5 or 10 year parts warranty item through GE Factory Service 1-800-432-2737 or www.geappliances.com) or a shorted high voltage rectifier. I think the light being out is a secondary problem.
Dec 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker XL1800 first no inside light followed by loud noise
I agree that the light is unrelated. 99.9% chance you have a bad magnetron tube but it is covered by either a 5 or 10 year parts warranty through GE. Call GE Factory Service at 1-800-432-2737 or schedule online at www.geappliances.com
Dec 16, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Jan 12, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Maytag Rangehood Microwave Loud Humming
Sounds like you just fried your magnetron. Normally when they go bad, they make a very loud noise like what you described. The smell concerns me because you may have ruined the waveguide as well. If the magnetron burns through the protective painted surface of the waveguide, the waveguide is ruined. In most microwave ovens this means replacing the entire unit because the waveguide is not replaceable. Putting a new magnetron in a damaged waveguide will result in the same arcing and eventual failure. In addition to the magnetron, the following components are part of the same high voltage network: HV Transformer HV Diode HV Capacitor Magnetron Thermal Cut-Out Any one of these components could have also been damaged. I DO NOT recommend taking any voltage measurements inside the HV network. Potentials of over 4000 volts can be reached and make it very dangerous for the do-it-yourselfer. Taking resistance readings with the unit unplugged is strongly encouraged. If you decide to pursue a repair, inspect the magnetron tip and inside of the waveguide first. If the magnetron is melted and/or there are burn marks inside the waveguide, a new microwave may be a in order. This actually may be a better option than an expensive repair. I hope you find this advice helpful.
Jul 31, 2007 | Whirlpool GH4155XP Microwave Oven
GE XL1800 1100 Watts Microwave Oven Logo
675 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
vince
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
