Question about Toshiba TP55G60 55" Rear Projection Television
Picture when first turned on there is what looks a dark film over the screen that disipates over time, it used to go away completly but now it hangs in a corner
  • Toshiba Master
  • 8,617 Answers
You have a bad Capacitor. Look real good at the capacitors in the video circuits for signs of swelling or leakage. You may need a ESR meter if you cant find the faulty one by sight. An ESR meter will allow you to find bad caps in circuit.
Posted on Jan 14, 2008
My polaroid camera won't eject the film. Are the cameras broken or is the battery dead?
When you take a picture of darkness, are you using flash or uprating the film ?
More seriously, as the film is thirteen years out of date, I seriously doubt if it is still viable. The chemicals within the film pack will have deteriorated over time, and it is my guess that they may well have leaked into the film pack's internal mechanism, thus preventing the photos being ejected. Try again with fresh film.
Jun 14, 2016 | Polaroid Cameras
The films that are being processed are coming out blank, how do you fix this?
If you are shooting with the new film from the Impossible Project, you need to turn the button which makes the photos come out light or dark all the way to the dark side. At most cameras this little button is next to the lense. It's hollow and you should be able to see a little lense inside of it. You probably took your photos with the button to the light side, which causes your photos to come out lighter (this was useful for taking photos with a dark background). I also recommend you to buy a flash for your camera. I use a Polaroid as well and I noticed how my photos didn't get overexposed when I used my flash. Odd isn't it.
Oct 16, 2013 | Konica Photography
Do i need to rewind film after taking a picture on my diana f+ ??
If you are using 120 film (medium format) you only need to advance the film as far as possible. Then remove the film from the camera and wrap the excess paper around the roll and seal.
When you finish all the pictures on the roll of 35mm film you will need to rewind the film completely before exposing it to light. You can do this by taking the camera in a pitch dark room, removing the film and turning the knob on the top of the film roll until the film has been completely wound back into the the roll.
Mar 29, 2011 | Lomo Diana F+ 35mm Film Camera
How do you change the lens?
If you decide to change the lens in the middle of a roll, just do it in the dark, like in a closet or using a "film changing bag"
Here is a link to one such bag
Photographers who needed to load sheet film while in the field, use as well as motion picture, second assistants when loading film into film magazines when in the field, away from the studio Source(s): proFotog
Mar 09, 2011 | Cameras
My x 370 wont transfer pictures onto the film? The camera looks like it's in good condition. The roles come out blank!
Film cameras directly expose film to light to produce an image: they do not "transfer pictures onto the film", but your phrase is a big clue as it suggests you've only used digital cameras in the past and so may have made a very simple mistake with film loading.
If the film is blank as in transparent, then the film has not been exposed. If it's completely dark then it's been over exposed.
I suspect you mean that the film is unexposed as it's by far the most common fault: cameras like the X-370 have completely manual film loading; the film has to be manually engaged onto the take-up sprockets before closing the back of the camera. After that, correct loading is confirmed by watching to ensure that the rewind crank (top left knob as viewed from rear) rotates every time the film winding lever is used. Note that the frame counter will advance even if the film isn't correctly loaded. Once the film is used up, the winding lever won't operate and the film must be rewound back into the cassette before opening the back of the camera. To do this, you press the recessed button on the underside of the camera and use the rewind crank to rewind the film until you can feel no more resistance at all.
You'll find full instructions on the Norman Butkus website where he's provided a downloadable .pdf manual for your camera for free download.
Hopefully this has solved your problem; if so all I ask in return is for you to rate my answer. If it hasn't, then please add a comment and I'll try to offer other solutions to your problem.
Oct 30, 2009 | Minolta X-370S 35mm SLR Camera
Wierd color issue
hello! it would be good if you will inform the company wherein you had puirchase that gadget right away. there might be some technical problem with it. companies always provide a warranty, you consult it to them right away..thanks! feel free to contact me for more inquiry.
Apr 10, 2009 | Acer X193W LCD Monitor
Canon AE-1 Dark Pictures
You my friend, need a user guide. Try this link:
Pages 23-26 will cover basic shooting. There is much to learn in the world of photography, so read the manual well and practice.
Dec 30, 2008 | Canon EOS-AE-1 35mm SLR Camera
Dark picture image, dosen't respond to briteness control
are you able to see the picture in a dark room ? does it appear bright enough then ? if so the lights behind your screen have dimmed or gone out completely. this may just be the power supply for the lights or your lcd panel may need to be replaced
Nov 19, 2008 | Sony KLV-S32A10 32 in. HD-Ready LCD...
Pictures have brown instead of color look, why
You have a bad film pack. Replacing the film pack with a new one should fix the problem. Nothing in the camera can change the color of a picture. The camera can over expose pictures (wash out the picture), under expose pictures (dark pictures), or the picture can be out of focus (blurry).
Nov 16, 2008 | Polaroid One600 Pro Instant Camera
Dark screen/picture.
This 30" flat screen TV set may have a problem in the high voltage circuit of the TV set. You may be able to adjust this by taking off the back of the TV set. Look for the block where the large red wire runs up to the top of the picture tube. On this block will be two controls. one will say screen and one will say focus. Try and slowly turn the control that says screen or S on it clockwise and see if you can make the picture brighter. Turn up the control till you just start to see faint lines in the picture, then back the control down till the lines go away. If the picture does not come up when you turn this up, and all you get is a blank screen, you will need to have this set repaired by a qualified repair person. Good Luck
Jul 14, 2007 | Sanyo HT30744 TV
Televison & Video Logo
26 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
