You shuld go to your provaider and change new sim card with your number then you can make new code . no other way for that the code its block into the network wen you change the sim you will have new sim serial then the network will accept your new baring code.
When you have a sim in the phone, it could inserted the wrong way around, be defect, or could have dirty or oxidised contacts.
Try to eliminate all causes, and if you are sure the sim is defect just goto your provider with the phone and let them insert a new sim and put your number on that side.
May be the phone is locked with any particular network and you are trying to insert a different network.To unlock from the locked network approach Superunlockcodes.com and remove the restriction in your Nokia C6-01.
No matter what network your Nokia N95 phone currently runs on, you can unlock it---or "flash" it---to run on any GSM network. You will only be able to use your unlocked Nokia N95 phone on networks that use SIM cards---such as T-Mobile and AT&T---and not on CDMA networks such as Sprint and Verizon, which do not provide SIM cards.
Read more: How to Flash a Nokia N95 Unlocking the Handset 1 Remove the back cover and the battery from your cell phone. Locate a silver sticker with a bar code on it. Take note of the 15-digit IMEI number printed on it. At this time, also remove the SIM card and write down the numbers printed on the back of it. The SIM card is the small, white data chip in the silver cradle right next to the sticker. You will need these numbers to obtain your Nokia unlock code.
2 Request a Nokia N95 unlock code from your service provider. If they cannot provide you with an unlock code, you can buy one online.
3 Replace the SIM card, battery and cover. Fully charge your handset.
4 Turn on your handset and type "#PW+".
5 Enter the unlock code given from your phone company or website. Make sure you dial the number exactly as it was given to you. If you dial this number incorrectly three times, you will be permanently locked out of your handset.
6 Dial "+1#". At this point, the screen on your Nokia N95 should read "SIM Restriction Off."
Inserting SIM Card 1 Switch your handset off and remove the back cover and battery.
2 Remove the SIM card.
3 Insert the new SIM card into the SIM card slot. Now that the phone has been unlocked, this can be a SIM card from any U.S. service provider that uses SIM cards.
4 Replace the back cover and battery and switch the cell phone on. The screen should now read the name of the new service provider
Check the SIM card with another phone to see if there are any problems . If not check the SIM connectors and insert in the shown direction- it is possible to insert it wrongly.
If not I suggest that since your Phone is NEW it must be shown for warranty free service to Nokia service.
Hi by what you have said ,to me it sounds like the hand set is barred,if the phone was bought from new i would take it back if it is a second user phone they may have reported it has lost, but try another sim in the phone it may not like that sim. hope this helps.
make sure the sim is inserted correctly if it still wont recognise then your sim card is damaged or some of the small wire points are bent down to far to connect with the sims reading bars
If Nokia said it can not be repaired, it can not. Buy another phone and insert your Sim card in to the new phone so you'll have most of your data at least.
insert vodafone sim and then go to setting call setting and call divert or call barrings and there you will find an option cancel all barrings and done!!!!!!!!
