Question about Matsonic MS8127C (MBMS8127C) Motherboard
Jumpers problem Hi. I dont have manual for my Matsonic MS8127C+ - motherboard - ATX - KT133APlease,tell me about RIGHT jumpers position  for this board. May be via foto Thank you. :)
  • 2,351 Answers
Jumpers problem - 170dd8e.jpg This is a jpg of a modern board. Your board may have more pins. The concept is close. Any difference would be located at the Power led. Your's could be three pins & the speaker could be three pins & neither connector would use the middle hole. I suggest you plug in one connector at a time with a boot up in between. Start with the power switch. Testing is simple, press the case power on button. Pc starts your good no light? Turn the connector around & try again. Next plug in the IDE led. Check for light on power up. Most boards, old & new keep their negetive facing to your right. These negetive wires are colored black & wihte. Positive wires are colored green, blue & red. As long as you do 1 connector at a time you should not have a problem. These are all very low voltage, most just leds. Take your time. It will work out.
Posted on Jan 17, 2008
My motherboard (intel DG41WV) is starting but not giving output to screen. I have cheked cables sokets. Even i have cheked to other screen. but problem is still. all peripherals (fan, cd-rom...etc) are...
Motherboard installed in computer case;
A) Keyboard Jumper Block
3-pin jumper block, Top of motherboard/ left side. Near the mounting hole, and 4-pin ATX +12 Volt power cable connector,
GENERAL example of a 4-pin ATX +12 Volt power cable, and it's respective connector on the motherboard,
[ This power cable MUST be plugged into the motherboard.
It is power for the Intel processor ]
3-pin jumper block.
Starting at the TOP coming down;
Pins 3, 2 and 1.
Jumper cap should be on Pins 2 and 3.
(Enables the Keyboard wake-up feature. Factory default setting is Enabled. Pins 2 and 3)
B) Clear CMOS Jumper Block.
BOTTOM right corner of motherboard. 3-pin jumper block.
It is to the Left of the bottom/left SATA connector.
It is immediately to the Right of the motherboard mounting hole.
Starting at the Top, and going down towards the bottom edge of the motherboard;
Pins 3, 2, and 1.
Jumper cap should be on Pins 1 and 2.
When you changed the SMPS, do you KNOW for a fact it is a good one?
Did you plug the 4-pin ATX +12 Volt power cable, into the motherboard?
What COMS setting/s did you change?
I would go back into BIOS Setup, and set that menu screen back to the factory default settings.
[ Load Optimal Defaults ]
BIOS Settings Glossary,
[Motherboard manual -
Nov 11, 2012 | INTEL - MOTHERBOARDS Computers & Internet
Im have problem in attaching my jumpers can you help me???
I am having a problem attaching the jumpers for the front panel on off
switch etc. for a HP pavilion 8670C can anyone help me.
May 05, 2009 | ASUS P5GC-MX/1333 - Motherboard - micro...
Need to reset Asus k7v bios
Yes, if you consult your motherboard manual this will show you the location of the cmos battery and reset jumpers. You can either move the jumpers from pins 1+2 to 2+3 and then back again after a few seconds or remove the cmos battery for a few seconds. Make sure your pc is off!
Dec 16, 2008 | ASUS VIA KX133 Chipset K7V (K7V/500/SWA)...
I have original cd vith drivers for MS8137c. Write me your adress and I will send a copu to you.
Sep 15, 2008 | Matsonic MS8137C Motherboard
Check the jumpers on the drive, should either be master/slave or all cable select.
Aug 12, 2008 | Matsonic MS8147C+ (N82E16813184008)...
I hope this link can help you understand the position of jumpers where to place it.
Jun 11, 2008 | Intel D865PERL Motherboard
Matsonic ms9158ep sound drivers
plz mother board matsonic ms9158ep sound driver free down load
Dec 19, 2007 | Matsonic MS9158EP (DSMTSMS9158EP)...
These should be them:
Dec 06, 2007 | Matsonic MS8127C (MBMS8127C) Motherboard
Computers & Internet Logo
405 people viewed this question
Top Matsonic Computers & Internet Experts
Computer Links
Are you a Matsonic Computer and Internet Expert? Answer questions, earn points and help others
