SOURCE: lost time/inaccessible files on flip
Have you tried this? (From the Flip website Help section)
We suggest trying the following to regain your full record time.
Connect your camcorder to your computer and open your DCIM/100VIDEO folder. This folder contains the videos from your Flip Video camcorder. When your videos are manually renamed within this folder, they are no longer recognized by the Flip Video program. Please ensure that all videos in this folder are carrying their original name. For example, VID#####.AVI where ##### is any number between 00001 and 99998. Then, delete all videos you have previously saved from this folder. Your videos cannot be retrieved once they are deleted, so please make sure you have the videos you wish to keep saved into another folder before doing this.
Also make sure you have deleted any videos that reside outside of the DCIM/100VIDEO folder within your camcorder's root directory.
After you have deleted all videos, disconnect your camcorder and check on your record time. If you have still not regained your full record time, please reconnect your camcorder and empty your "trash can". Then, power your camcorder on and off 8 times.
This may sound risky, but I did this and my Camera is working perfectly again... If you don't have any videos on it you need to salvage too badly this should do the trick.
1) Plug it in (obviously)
2) Go to My Computer and right click your video camera
3) Click Format
4) I clicked restore device defaults because it sounded safe (but may not be necessary)
5) Click start and begin the reformatting
After this i went from my incorrect 27:11 min. remaining on the camera to the full 60. Still records perfectly and the software is still on it and works correctly. Hope it helps some of you out there =)
SOURCE: Flip Video Camera Won't Start Up
Flip support helped me solve this problem. Their procedure is to take the batteries out of the camera and leave it sit for 48 hours. After 48 hours, put different batteries into the camera and turn it on. Your problem should be solved. It worked for me the first time and now I currently doing it for a second time. Waiting for 48 is no fun, but at least it works and fixing it is not expensive. No explanation was given to me about the problem.
SOURCE: Can not see the videos in the Flip Share window
Connect your flip video camcorder to your computer via the usb arm. you will find your video files in FLIPVIDEO(F:)->DCIM folder. Just copy your videos to your computer.
SOURCE: Record Beep Tone - How To Shut Off
On the Mino HD, Hold down the record button as you turn the camera on. Navigate the menu and turn off the sound under the sound option.
