Question about Grundig Traveller Clock Radio
Grundig Satellit 650
Hi. This radio works perfectlly on all bands except SW there it workes well till it gets to about 15 mhz then it stops receiving and cant tune. If you turn it off then on again it will let you tune one step (1 Khz) then cant tune.
I have tried adjusting the VCO and it does allow it to tune higher but then looses the bottom end. Im sure the pll is going out of lock becuase the VCO is running out of range but I have no idea were the problem will be. Maybe you have seen this problem before? Hope so..
Thanks in advance
Jose
Australia
  • Anonymous Nov 03, 2008
    I have the exact same problem.
4 Suggested Answers
  • 9 Answers
SOURCE: Grundig Satellit 800 display problem
HI,
THAT IS COMMON WITH PLL TUNERS THAT THE SLIGHTESS
TWEAK ON THE TUNING KNOB WOULD MAKE THE DISPLAY MOVE .COMMON ON DIGTAL PLL TUNERS........
Posted on Feb 07, 2009
kb8dns
  • 494 Answers
SOURCE: Grundig Satellit 800 LCD display doesn't work correctly
If the radio uses memory batteries, try changing these with new alkalines. The microprocessor needs this power to drive the display.
Posted on Feb 10, 2010
SOURCE: Grundig Satellit 700 World Receiver. AM bands are dead.
Ist Local Oscillator (PLL) stops working. It's desiged with bare minimum feedback to keep it's output reasonably clean. Removing (De-soldering) the screening box reduces losses, but it's still marginal. Something in the osc. circuit is temperature sensitive, so squirting it with freezer spray - or putting the set in the 'frig will get it going again. Have one like this, "Repaired" - been going for about 5 years and just quit again! If I get any better luck next time, I'll re-post this!
Posted on Jan 27, 2011
Can u give me the pincode of that area
Feb 04, 2008 | Grundig Satellit 800 AM/FM/SW Radio
I just got grunding 800 radio,no reception either am,fm ,sw please help me.
This is valid for the Satellit 750 by Eton (current owner of Grundig)
When you use it the first time you go through a system code setting to fix the memory page configuration, the AM gap between stations, the type of batteries and FM frequency range.
If it is used in North Ameraica, you are told not to go through procedure but do it any way.
SYSTEM Code setting
Turn Radio off and press a quick short press on the ENTER Button. -- appears on the upper right corner of the display
1. The first code could be 00, 20,25 or 50, meaning the memory is divided into 10, 20, 25, or 50 pages.
2. The second code fixes the AM frequency gap between stations. Enter 09 for 9kHz or 10 for 10 kHz (in North America)
The 3rd code selects the type of batteries used 29 for D size batteries (1.5V each) or 28 for rechargeable batteries (1.2 V each)
The 4th code concerns the FM frequency range: 76 for a range 76-108 MHz (for Japan) or 87 for a range 87-108 MHz
Read your manual to see how the procedure is performed, or try this one valid for the Satellit 750. It might work. Go through all the procedure and press ENTER to confirm system code.
Aug 11, 2010 | Grundig Satellit 800 AM/FM/SW Radio
Jan 30, 2010 | Grundig Satellit 800 AM/FM/SW Radio
Aug 15, 2009 | Grundig Audio Players & Recorders
HI,
Nov 20, 2008 | Grundig Satellit 800 AM/FM/SW Radio
Looking for manual
HI,
DOWNLOAD PDF FILE FOR 800 SATELITT
GO TO GOOGLE ENTER SAT 800 GRUNDIG PDF
YOU WILL GET A MANUAL FREE OF CHARGE....
Nov 13, 2008 | Grundig Satellit 800 AM/FM/SW Radio
I have a Grundig Satellit 500 "Radio Boy"
If you sent it in 3 times, then I would suggest getting a new one if you know for sure that other's work in that area. If other's don't work, then then you have some type of interception between the radio waves and your radio. There is nothing I can do about that, and probably nothing you can do.
Otherwise, you should get a new radio.
Mar 16, 2008 | Grundig Satellit 800 AM/FM/SW Radio
Repairing Grundig Radio receiver Satellit 3400
GRUNDIG SATELLIT ST 1400 SL
Diodo Zener ST601 Volt ?? (SU ALIMENTAZIONE)
HELP Simon
Feb 27, 2008 | Grundig Satellit 800 AM/FM/SW Radio
Grundig Traveller Clock Radio Logo
137 people viewed this question
Top Grundig Audio Players & Recorders Experts
k24674
Greg Cann
Greg Cann
xxxxxx xxx
Are you a Grundig Audio Player and Recorder Expert? Answer questions, earn points and help others
