GE Spacemaker JVM1640SJ Microwave Oven Logo
Posted on Nov 27, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Microwave has a strange oder ( electrical possibly ??? ) and is no longer heating food. It is a ge spacemaker 1400
William Miller
Level 3:
  • GE Master 9,179 Answers
  • Posted on Nov 29, 2009
William Miller
GE Master
Level 3:
Answers
9179
Questions
Helped
4478197
Points
21747
It may be a bad magnetron, high voltage rectifier diode, or high voltage transformer.
We have a sound clip here of what a microwave should sound like when the cooling fan and high voltage section are working.
A loud buzz, hum, or groan is usually a shorted high voltage rectifier diode, but a sound like gurgling into an empty coffee mug is one symptom of a failed magnetron, and yet the mag can be bad without that sound.
Here are some links you or someone you know can use (in order given) for test help, but read the safety warnings first:
http://www.gallawa.com/microtech/diode.html
(if it is NOT shorted or burned looking, it's probably fine)
http://www.gallawa.com/microtech/mag_test.html
(continuity can be good even though mag is bad!)
http://www.gallawa.com/microtech/xformer.html
You can find links to helpful exploded view diagrams and part ordering help here. I'd recommend that your bookmark this link to your favorites.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Accessing some components (especially the oven cavity thermostat) for testing and possible replacement will require you to remove the oven from the wall and take off the outer cover.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
Anonymous
Level 1:
New Friend:
  • Contributor 32 Answers
  • Posted on Nov 27, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
32
Questions
0
Helped
6782
Points
95
Sounds like youre rectifier has gone it will cost you about 60 pounds to repair
8helpful
2answers
Problem with the GE Spacemaker (JVM1640SJ) Microwave Oven GE Spacemaker XL1800 won't heat food anymore....It worked this morning, now won't heat. What should I do?
GE Will replace the magnetron for 9 years! Mine is a 2004 model with a one year warrently according to manual. HOWEVER they did say the magnatron was covered for nine years: call 888-239-6832. When I called they said thats all they get calls for and would send out in 3-5 days. NO CHARGE. I had to ask if there was coverage longer than a year on major parts and that's when they offered the info and I eventually was transferred to the right office. Saved $120 bucks on parts alone.
1helpful
Microwave oven: GE Spacemaker 1400 not heating. Model number JVM1430AB001. Need guidance on troubleshooting and repair of unit. Thanks!
If the oven is making a loud buzzing noise when you try to warm food and the food remains cold, it usually means that the magnetron has failed. Not usually worth fixing since the parts alone can cause as much as a new oven.
Strange smell no heat
actually the two things you mentioned are a pretty reliable indicator :/
The only way to be positive is to check for power from the high voltage transformer. If you are not trained to work around electricity, i wouldn't mess with it because it can most certainly kill.
if there is no power coming from the HV trans, you then trace power back toward the cord. The component that has power going in but not coming out is the culprit.
1helpful
2answers
GE Spacemaker 1400 acts like everything works but does not heat.
Hello :
This happens because of a bad door switch . The plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door .
Check also the turntable . It could be out of it's right place .
WARNING :
1:Don't slam your microwave door because this may cause the fuse to blow and this is the reason of bad door switch problem .
2: A microwave is capable of giving you a serious electrical shock even when it's unplugged , so I recommend you to call a repair technician for help .
please don't forget to rate .
good luck
Our microwave (GE) not longer heats food items.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
r
Wont heat food
It could be that the "grinding" noise was actually "arcing" taking place inside the cavity or uder the cover. The magnatron is possibly damaged or the h.v. diode. Should be repaired by qualified repairman
How to remove ge spacemaker 1400?
1helpful
GE Spacemaker XL1800(JVM1850CF001) - Loud Humming noise
You either have a bad magnetron tube (5 or 10 year parts warranty item through GE Factory Service 1-800-432-2737 or www.geappliances.com) or a shorted high voltage rectifier. I think the light being out is a secondary problem.
9helpful
GE PRofile Spacemaker XL Microwave Oven Model# JVM1460 950 watts
Sounds like the problem is in the high voltage. Most common would be magnatron, capacitor and diode. For safety reasons this should be checked by a professional. Look in your owners manual because some high voltage parts have a longer warranty than 1 yr.
Top GE Microwave Ovens Experts
vince
NOEL
NOEL
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
