Question about Cornea MP800 18.1 in. Flat Panel LCD Monitor
Power Plug Cornea MP 704 I need the power plug and the VGA plug. I have not been able to find it anywhere
0 characters
1 Points
When I turn on my Cornea MP503 monitor on it has a message in a blue box saying Power Saving Mode and then goes blank and light flashes orange-green over and over.
Check the VGA/ DVI cable connection from your Monitor to PC, this also could be caused by VGA card on you PC that doesn't work properly, unfirmed connected to its slot etc, check also for unfirmed connected memory card/ RAM.
Dec 13, 2010 | Cornea MP 503 15 in. Flat Panel LCD...
What would cause my monitor to be in the " POWER SAVING MODE? "
check out if the electric alimentator are fine, the cords and the conections, check the properties too, maybe a stand by settings are on and make you this "power saving mode" if none of the anteriors was... then could be that the monitor have done the limit of hours, if the monitor was new try on warranty, if the monitor doesnt have warranty you can explain more about this trouble so i can help you more given you specific intructions
Aug 12, 2010 | Cornea MP 704 17" Flat Panel LCD Monitor
Screen is black when turned on
You may have failure in the backlight inverter circuits (shorted transistors, failed inverter transformers), power supply (bad caps), bad lamp assemblies. If you are going to DIY repair, please look through my albums so you will know what to look for inside.
Apr 21, 2010 | Cornea MP 704 17" Flat Panel LCD Monitor
Need driver for Cornea MP704
I have the same monitor on one of my test benches. For a long time I tried to find drivers for this because I thought it would make a difference. Finally a year or so ago I found a drivers company which said they had it. For $20 I could download it and many others. I did so and didn't really see much improvement when I installed it. I finally got to thinking that maybe I should look closer at this code I purchased. Well as I suspected this code was actually the Microsoft generic LCD monitor code which had been relabeled. I turned it over to Microsoft. But to answer your question I have never found drivers that are specific for any Cornea monitor. Sorry
Mar 24, 2010 | Cornea MP 704 17" Flat Panel LCD Monitor
When computer comes on the screen only shows power sharing mode
if u r getting this errror after POST then restart the computer and keep pressing F8 key to enter into advanced mode then select Enable VGA Mode Option.
Feb 07, 2010 | Cornea CT 1700 17" Flat Panel LCD Monitor
Power-Supply Plug in on Monitor not present ?
wait, is there not a power port? if ther isnt, it may be on the vga port where it connects to the pc, it may of got cut off, your alternative is opening up the mointer and wireing a new power port
Aug 27, 2009 | Computer Monitors
External Monitor
No. This is almost certainly a setting issue. Go in to the control panels and change the way the monitor is used. I.E. extension desktop, mirror, etc. Then check the settings for the second monitor and make sure it is not set to some huge size or resolution. This is a function of the MacBook and OSX. I had a similar issue when connecting it to a 71" DLP.
Apr 01, 2008 | Cornea MP 704 17" Flat Panel LCD Monitor
Power Supply for Cornea CT1700 LCD Monitor?
cornea lcd monitor, Monitors Projectors, Computers Networking items on ... Power Supply Adapter Cornea CT1700 LCD Monitor (12V 5A) $18.99: 12vAdapters Dot Com ... Items that are listed in a currency other than U.S.
Good Luck, Please dont for get to Vote/Thank You.
Dec 22, 2007 | Cornea CT 1700 17" Flat Panel LCD Monitor
Monitor not powering up
Try another monitor on that same pc, try your monitor on another pc. Next, check the data cable for any short.
May 08, 2007 | Cornea MP 704 17" Flat Panel LCD Monitor
Cornea MP800 18.1 in. Flat Panel LCD Monitor Logo
Top Cornea Computer Monitors Experts
Brian Sullivan
Brian Sullivan
Are you a Cornea Computer Monitor Expert? Answer questions, earn points and help others
