Question about Dell Latitude Cpi D366XT PII Notebook
Will not Reboot back into Windows?
My Laptop is Dell CPi A11 version at 192 RAM and 30 GB HDD; It has been running great, but when I put my XP Sp2 Disk back in to "Repair" any corrupted files, now it looks like the OS fell apart on install with the auto reboot points on the Disk? Now everything starts(Boots) normal except at the last point when a Image of Windows starts for 1 second and Windows fails to start? I saw the Partition Table with Boot-up Disk-all is the same as usual since Disk Partition and original XP install. About 20 Gigs of Free Space remain on HDD. I cannot get to my LogOn Screen? I already tried my 6-Disk Bootup followed by the XP CD in the ROM but the XP Disk will not Bootup anymore? Keep in mind that I have the External Floppy hooked up that works good and the Removable CD-ROM stays in place and works for other CD Program installs. I hope this is a piece of cake for one of you GURUs. Please impress me Fast!
Thanks Guys
Roberto
  • supachik Jan 14, 2008
    . Cannot boot into safe mode even using all emergency Disks, AVG, Norton Disk, etc.
    . Normal boot until I reach LogOn screen, then it auto reboots after a second of screen shown-ten computer starts normal reboot again automatically.
    . The 'Repair' option is offered by XP Disk if you do not want a 'Clean' install and lose all you personal settings.
    . I have a small 'Port Replicator' with USB for Laptop and wireless mouse.
    . There are no error messages during all this auto-rebooting which will not stop if I let it go.
    . I used a GUI Utility to see what files are on the HDD still; The GUI results say the Boot.ini file has been deleted? I wonder if the XP Auto install Disk deleted the file without backing it up?
    Keep me posted. I really do not want to blank the disk and partion again if not needed. In DOS the Partition is good and Drives there like usual. What's interesting is that I used my 6-XP Startup Disks and my computer rebooted, but the XP Auto Disk in the CD-ROM did not begin toward the LogON Screen like I expected. I checked the XP Disk on my larger computer and the Files are there. I have three XP Pro Sp2 Disks-tried them all and with the same negative results. HELP
    Robert
  • supachik Jan 19, 2008
    RE: Dell Laptop CPi A OS will not install
    Turns out the removable CD-ROM Drive was defective. It did not read my Program Disk. Put in another Drive and went to changing Partition in DOS-Was able to save my XP NTFS on the Drive and install an early Upgrade Version of WIN 98 from the new CD-ROM Drive and it took finally. From this version I was able to install WIN ME and then my XP PRO SP2. I was too far gone even for my SpotMau Disaster Recovery Disk-which is Awesome as long as there is some kind of Windows to work with. Spotmau let me have a Floppy NTFS GUI Utility Download which showed me that the NTFS Files were still hidden on the HardDrive. When Windows was finally booted up, the SpotMau CD Disk installed. You got to have this CD Utility. It has to be unzipped, then use their Burn utility to put the Program on a CD that autostarts. It probably matches the quality of Diskeeper Pro, DAP Premium and Incredimail in its own right. Also if you want to Partition, this one is you real magic-It's just too easy to use! Check it out! My problem is solved.
    Thanks guys
    President:
  • 1,950 Answers
Say, are you able to boot into safe mode? Also, what exactly happens when you try to boot normally. It simply gets stuck? Are there any error messages on the screen?
Posted on Jan 14, 2008
  • 2 more comments
  • Damen Wong
    Damen Wong Jan 14, 2008
    When you mean "repair", do you mean that you booted into the recovery console?
  • Damen Wong
    Also, I would like to know if there are any peripherals attached to your computer externally except for the floppy disc unit.
  • Damen Wong
    The boot.ini has to be present for XP to load. Could you please try to boot with nothing attached to your computer? Also...what happens when you try to boot into safe mode. It also doesn't enter Windows and reboots with no error messages?
  • Damen Wong
    Damen Wong Jan 19, 2008
    I am glad it worked out for you =)
  • 2,427 Answers
Well you kinda messed up your windws instillation and the only way you are going to get the pc working again as a complete format and reinstall..
1.) boot from the windows xp cd,
2.) delete the partition to remain with one huge unpartationed spcce.
3.)select this unpartationed space and hit enter
4.)do a full format and let windows reinstall it self.
this will remeover everything on your harddrive including the messed up files and boot sector, rewrite you mbr etc..
WARNING IT WILL REMOVE EVERYTHING..
so you will need to reinstall all your drivers and software..
if you need further help or details reply here ..
  • 4 more comments
  • Rishi Roshan Ali Jan 14, 2008
    To boot from cd rom,
    step one Enter the Setup (enter bios, bios settings)
    it says what ket to prees when you turn on the system its eighter del, F1, F2 or something like that it will tell you what key.
    Go to the boot options, and set the cd rom as the first boot device..
    Try reinstalling windows on the same same trive without changing the file system, you will recover all your files where you can back them up and then you can format and reinstall,,, OTHER than that i dont see how you can recover your mbr..
    you can try booting of thw windows cd
    select repair
    then when the command prompt comes up type
    fix boot
    fix mbr
    and that might help you get past the log on screen, actually it should give you a full bot but it will run kinda sloppy
    proberally a defragment might help a bit
  • Rishi Roshan Ali Jan 15, 2008
    OK If you barve enough enough and you want to try this,,
    1.)Put the harddrive on another system where you can get axcess to the files
    2.)copy any boot.ini file from any system and paste in on your harddrive.. other files needed as well as autoexec.exe..
    3.) replace harddrive in your system.
    4.) BOOT OFF THE WINDOWS XP CD
    5.) SELECT REPAIR
    6.)SELECT YOUR WINDOWS INSTILLATION
    7.)TYPE fixboot or fix boot
    8.)enter fixmbr or fix mbr
    9.) enter fixboot or fix boot again
    10.) TRY BOOTING type exit and your system will restart..
    That will get it to boot and you will be able to get off your personal data ...
  • Rishi Roshan Ali Jan 18, 2008
    HEY ANY LUCK?
    HEY ANY LUCK ?
6ya staff
SOURCE:
Yahoo messenger not working on dell d810
Hello TAYZM,
Please let me know if your computer meets the following specs:
Microsoft Windows XP Home Edition
CPU Intel Pentium M 755
Memory
RAM 512.0 MB
Max RAM Supported 2.0 GB
Storage
Hard Drive 40.0 GB HDD
Optical Drive CD-ROM
Questions:
Do you have external hard drives?
Have you added RAM?
-What browser are you using?
Version?
Add ons?
Does your Windows XP have all of the Service Packs?
http://windows.microsoft.com/en-US/windows/service-packs-download
Do you have any anti-virus software on your PC?
Do you have any malware avoidance software on your PC?
Do you have any backup/restore (registry) software on your PC?
What programs do you use most frequently?
Which version of Yahoo are you attempting to install?
Have you Un-installed the non working version?
Thanks!
Jimm
Nov 21, 2012 | Dell Latitude D810 Notebook
Need to know how to install infernal on windows 7
Put the Disc in the drive of your Pc, click install? the game came out in 2007, it should have no problem running on a computer running windows 7, unless its does not meet the minimum requirements
System requirements
Pentium4 1,7 GHz
  • 512 MB RAM
  • 128 MB Graphiccard with DirectX 9.0c & Pixel Shader 2.0
  • 2 GB HDD
  • Windows 2000 (SP4)/XP (SP2)/Vista
May 12, 2011 | Computers & Internet
Can the Dell Latitude D610 run any of the following games: Age of Conan Star Trek Online Champions Online Aion
Check your system if it meets the following requirements
Age of Conan
Required
OS: Windows Vista/XP
Processor: 3GHz Pentium IV
RAM: 1GB RAM
Video Card: Shader Model 2.0 and 128MB RAM: NVIDIA GeForce 5800 or ATI 9800
Recommended
Processor: Intel Core 2 Duo 2.4 GHz (E6600) or better
Video Card: NVIDIA GeForce 7950GX2 or better
RAM: 2GB or more
Enhanced for: DirectX 10, 64-bit processors, multi-core
Supports Parental Controls on Windows Vista
Start Trek
System Requirements
  • OS: Windows XP SP2 / Windows Vista / Windows 7 (32 or 64-bit)
  • CPU: Intel Core 2 Duo 1.8 Ghz or AMD Athlon X2 3800+
  • Memory: 1GB RAM
  • Video: NVIDIA GeForce 7950 / ATI Radeon X1800 / Intel HD Graphics
  • Sound: DirectX 9.0c Compatible Soundcard
  • DirectX: Version 9.0c or Higher
  • HDD: 8GB Free Disk Space
  • Network: Internet Broadband Connection Required
  • Disc: 6X DVD-ROM
Recommended System Configuration
  • CPU: Intel E8400 Core 2 Duo or AMD Athlon X2 5600+
  • Memory: 2GB RAM+
  • Video: NVIDIA GeForce 8800 / ATI Radeon HD 3850+
  • Disc: 6X DVD-ROM
To check your system hardware> click on start>all programs>accessories>system tools> system information.
Thanks for using Fixya
proton
Mar 27, 2010 | Dell Latitude D610 Notebook
Laptop shows only 4gb ram & 300 gb hdd
This is the limitation of a 32 bit (x86) Operating System. A 32 bit OS can detect upto 3GB RAM only.
You may either try installing the x64 Bit of XP Operating System or Vista Service Pack 1 or 2 for 32 bit Vista Operation System to resolve the issue.
After installing the SP 1 or 2 of the Vista OS in the Computer, the OS will detect 4GB RAM.
Good Luck!!!!!!!!!!!!!!
Oct 12, 2009 | Acer Computers & Internet
Upgrading my old laptop
this are the things that will help you upgrade your laptop. first of all replace the ram memory with a higher configuration.then get your hard disk reformat by reinstalling fresh operating system like windows xp-sp2 or windows vista.install all the latest updates and drivers and its done. please do not forget to rate the solution.
Jun 12, 2009 | Dell Inspiron 2200 Notebook
Sata hdd not Detect
To install Windows XP on SATA or advanced IDE hard drive, you will need to insert a driver diskette at the time of starting the installation process and pressing "F6". For more details visit the link below:
http://ufixitnow.blogspot.com/2009/04/oem-driver-support-during-windows-xp.html
Apr 09, 2009 | Microsoft Windows Xp Home Edition Sp2...
Add ram memory to a Dell Latitude CS Series
go to crucial.com and use there online tool..that will help u!!
Nov 16, 2008 | Dell Latitude CS Notebook
Non detection of hard disk in dell laptop while installation of win xp sp2
I haven't heard of not being able to delete a partition before. You could go to the manufacturer of the hard drives website and find the software to do a low level format or you could download a linux distribution and use the installer to remove the ESIA partition.
I would need to know the model of hard drive and laptop if you need any further assistance.
Sep 08, 2008 | Computers & Internet
Hard drive swap and repair
use a back up service for that...you can find one through this link, called Mozy @ home
May 05, 2008 | Dell Latitude D600 Notebook
Dell Latitude Cpi D366XT PII Notebook Logo
108 people viewed this question
Ekse
Clive
Clive
Alun Cox
