Question about Canon MX300 Office All-In-One Printer
Canonc mx300 office all-in-one 5100 problem
Im getting the error check printer 5100
i'm presuming this is something to do with cartridges not in properly..
can you confirm this?
thanks
    Master:
  • 788 Answers
Verify that all your cartridges are in properly first.
Try cleaning the encoder/timing strip. It is the plastic strip that runs the length of the printer behind the cartridge carriage, it is full of little black vertical lines. I've also seen that the strip can move out of place, make sure it is centered in it's slot.
Also check the gear that are visible with the printer open, look for an obstruction, use a flashlight it helps. Also look for a stuck piece of paper somewhere, it may be hard to find but look very carefully.
Also try a reset may work:
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal.
If non of this works, try printer a test page from the printer and let me know if that works OK.
Posted on Jan 14, 2008
I need solution asap on alarm check printer 5100 on my canon mx300
http://iusermanual.com/printer/canon-pixma-mx300-printer-manual.htm
here's a link for the manual
good luck
Jul 29, 2010 | Canon MX300 Office All-In-One Printer
Canon mx300 states error 5100 check printer. when you open top cartridge does not move to the left to acess to replace ink. Help
Hi You can Try 2 things.
ERROR 5100 means that there is some foreign object blocking your cartridges carriage that disables it from moving. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there
Next try.
It may be a piece of paper or a scotch tape or a staple wire.
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
May 18, 2010 | Canon MX300 Office All-In-One Printer
My pixma mx300 shows 5100 error message, and I don´t know how to go to the service mode, this doesn´t work for me: Turn on the machine Press MENU Press SCAN COPY SCAN to enter service mode USE...
Next try.
Solution 1:
Solution 2:
Feb 01, 2010 | Canon MX300 Office All-In-One Printer
Error message 5100 on Canon MX300 printer
If the ink cartridges are stuck you can manually slide them back to their default position and check for paper or junk which may have slipped down the paper chute and is blocking the ink cartridges.
Remove the blockage
Reset Printer
Done
I just had this problem and it was easy to fix.
If this not help, buy another printer! Cheaper than service...
Oct 22, 2009 | Canon MX300 Office All-In-One Printer
Finding the ink cartridge
Look on the mfr's website for instructions on how to replace an ink cartridge.
Don't forget to rate the advise!
http:www.aa1consulting.com
Jul 31, 2009 | Canon MX300 Office All-In-One Printer
Error 5100
5100 is a Carriage Home Position Error.
try cleaning the plastic strip that runs the length of the carriage, it may be contaminated.
Use alcohol and a swab
Jun 29, 2009 | Canon MX300 Office All-In-One Printer
Canon MX300 Office All-In-One Printer Logo
261 people viewed this question
old marine
old marine
