Screen tv is curve inward and does look distrosion
I have a Mitsubishi screen tv 60 inches. I thrue an item to the screen and the inward plastic screen ben indward. Now the tv look with a curve and you can not read the clear letters on the menu. I took it apart strait it, but if flip back inward again. what do you suggest.
    President:
  • 4,402 Answers
Convergence amp ic bad.
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on Jan 14, 2008
I have a Phillips 60" rear projection TV. recently
Tv have a problems known as a convergence problems,it is dead.The tv convergence board it is dead,that why ur tv picture are R,G,B colors lines mis alignments,have colors shadows picture or 3D picture lood alike?The tv convergence board require changes 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The shop will cost u like $300-350 for parts and labors.
Jun 01, 2011 | Philips Televison & Video
NEED FRONT SCREEN THAT FITS OVER SCREEN
I'm trying to remove the screen from mine, do you have an owner's manual that shows how?
Jan 12, 2010 | Mitsubishi VS-60707 60" Rear Projection...
After a move to a new home the screen broke. need
Howdy,
Yes, you can still get them from the Factory. I just checked and Mit's has all items in stock.
The SCREEN- LENTICULAR IS; 491P103030: $171.10. The LENS-FRENSEL IS; 491P104030: $212.80. The Diamond Shield IS; 760D639020: $77.90.
Dec 29, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Mitsu. 60-inch VS-60609 Green Light goes out..tv goes off.
You are dealing with bad solder connections. The solution is to pull the board, put it under a magnifying glass and resolder all suspicious connections. before going too far with pulling the chassis, look over all the boards near the egde under the tubes. Be sure there is no liquid present, if there is give it up the set is toast. If not then continue on and place piece of plastic draped over the front of the left and middle boards to about 5 inches in towards the center just before putting the back on the set.
Dec 21, 2008 | Mitsubishi VS-60609 60" Rear Projection...
Mitsubishi VS-4561 picture curved inward
Its Your Convergence Chips!. And Maybe a few Resisters!. Common Problem with this kind Of Set!.....
Jun 30, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi
you need to do self test first look in threads and also ctechnicians.com to get error codes.
Dec 30, 2007 | Mitsubishi VS-50611 50" Rear Projection...
Mitsubishi VS-60603 60 inch Projection TV
You would have to completely take the Mirror out or Mylar backing and being careful not to damage anything, trying to move and reassemble when you get at the new location.
Dec 05, 2007 | Mitsubishi VS-60609 60" Rear Projection...
Screen is curved inward on all 4 sides and there is a red, and a blue line that is curved at the top of the screen
This is a convergence problem.. possible deflection problem... you might need a tech to look at it...
Nov 19, 2007 | RCA HD56W66 56" HDTV
Year 2000 mitsubishi 64 inch tv
Have convergence IC's changed in your 60" TV. I only use ORIGINAL IC's, not generics or knock offs. Most companies that fix have no idea what the difference is.....
Oct 31, 2007 | Mitsubishi VS-60703 60" Rear Projection...
Televison & Video Logo
74 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
